Question about Ruud Heating & Cooling
I nedd termostat wire diagram for this esplit system urfb-036jas
I nedd wire the condenser, air handle whit Honeywell thermostat
    Master:
  • 613 Answers
All thermostat wiring is the same except some small differences with heat pumps, but try this
Posted on Dec 08, 2013
  • 49 Answers
SOURCE: Replaced thermostat on FA4ANF030 with Honeywell model rth3100c does not work
If you have a heat pump do not put your blue wire on b. Put it on x or c. If you don't have an inline fuse you may have blown your transformer.
Posted on Dec 04, 2007
  • 49 Answers
SOURCE: Intertherm to Honeywell thermostat
Typically if you have a yellow wire in the "y" terminal blue is used as common or "c". As far as your jumper from rc to rh, that will depend upon what type of heat you have. If all of your heat and cooling come from your packaged unit outside, yes you will need the jumper. If this does not work maybe you have a bad breaker or transfomer.
Posted on Oct 14, 2007
SOURCE: Wiring diagram needed RV rooftop coleman
Motor1258,
Thanks for the response, to be more specific, the nine pin connector was damaged, but I was able to connect the wires back to main unit panel. I am ready to hook to the hunter thermostat and do not know which wires to connect to. This is my problem and I do not want to short something out. Hope this helps, I want to get it installed again. Thanks again for caring....Jerry
Posted on Aug 16, 2008
  • 252 Answers
SOURCE: need wiring for honeywell pro 3000 in trane xe1200
the pro 300 is a single stage thermostat and can not be wired to control 2 heat stages seperately
Posted on May 16, 2009
johnsonr1
  • 91 Answers
SOURCE: Need to know wiring diagram for a weathertron
this link has a good diagram of the wiring. It should help you.
http://www.hvacmechanic.com/forums/hvacr/messages/17573.htm
Posted on Nov 05, 2009
Honeywell wiring diagrams
WE R GOING FROM A HONEYWELL TAYSTAT500 THERMSTAT (HEAT PUMP) TO A NEW HONEYWELL to (WHOLE NEWHEATING/AIR CONDITIONER) WITH A HONEYWELL RTH8580WF1007 THERMOSTAT? WHERE WOULD THE C WIRE BE. WE DO NOT HAVE A WIRING SCHEMATIC FOR THE OLF THERMOSTAT. IT HAS 7 WIRES. HELP?
Jan 10, 2014 | Heating & Cooling
I need to hook up my heating system to a honeywell th8320 up 1003 thermostat. Where can I find a wiring diagram for this unit?
Go online to Honeywell and they should have instructions for hooking up the thermostat you have.Hope this helps, please rate my advice on fixYa.
Aug 03, 2011 | Honeywell Heating & Cooling
I have a honeywel t8002c termostat w heat already connected. The ac unit needs to b reconnected. Two wires for the ac to b connected. Was connected before but moved the termostat thus winter and didnt...
You need to connect to the Y terminal and the C terminal for A/C unit. The best was is to connect thermostat to furnace and then connect the two wires to A/C off furnace circuit board at Y and C terminal.
May 13, 2011 | Honeywell Heating & Cooling
I need the wiring diagram for this thermostat, there are four wires that are hooked up red,white,blue for yellow and green. They connect to a honeywell relay that has five connection, y,g,w,c,and r, do i...
On the fan relay hook up the red to r terminal the white to the w terminal and the green to the g terminal , now the blue needs to hook up to one of the two wires going to the outside condenser unit and the other going there goes on the c terminal . The blue does not have to go on the honeywell rrelay just wire nut it to the wire.
May 13, 2011 | Carrier TSTATHCP Programmable Thermostat...
I have a Ruud Model # UACC-036JAS. Any idea on
Hi, yes the number you are showing me 036 indicates its a 3 ton unit. For every ton of cooling, you will have 12,000 btu's of cooling. 36 divided by 12=3 ton unit. Its showing me also its a Ruud Handler 2.0 ton which would be a Model# UACC-024JAS? If your mobel number is the one you gave me, UACC-036JAS, this is a 3 ton unit, absolutely no questions. I hope I have been of help to you. I am a licensed air conditioning / Refrigeration /Heating Contractor. Let me know if I have been of help.
Sincerely,
Shastalaker7
PS If this is a split system with the indoor air handler and condenser outdoors, both coils must be the same tonnage for it to work for you properly. You can't have a 2 ton indoor evaporator coil with a 3 ton condensing unit.
Jun 28, 2010 | Ruud Handler Air Conditioner
I currently have a Honeywell T874C1000 and want to replace it with a programmable thermostat. It controls a cooling only air handling unit with an outdoor condensing unit. No heat.
All you have to do is note which wires are hooked to which terminals and exchange them i.e.-R(Red) to R terminal, Y(Yellow) to Y terminal, etc. The only wires you should need are the Red, Yellow, Green, and sometimes Blue if the thermostat is powered by the unit and not batteries. Here are the most common wiring procedures:
Red(R)=Power
White(W)=Heat
Green(G)=Fan
Yellow(Y)=Cooling
Blue(B/C)=Common/Ground
Hope this helps!
Jun 26, 2010 | Honeywell Programmable Thermostat Heater
The heater is not keeping the temperature
OK maybe it's not the thermostat. Without a make and model number of your heating system we will be shooting in the dark. If you have a furnace or air handler, check the air filter. Get in front of the heating system and give us details as how it is running, noises, temperature of components, etc... We can isolate the thermostat by jumping the wires going to R and W on the thermostat. If the system chugs away we know that the heating system is fine (with the exception of the air filter) and is not the problem. If it still has a problem getting to temp, then it is a heating system issue. Get back to us with info. Thanks.
Dec 29, 2009 | Honeywell Programmable Thermostat Heater
I need a wire diagram of a central heat and air with a heat pump
W- White (heat)
Y- Yellow (condenser)
G- Green (Indoor fan)
C- Blue (Common 24v)
R- Red (24VAC)
O/B (Only needed if system is a heat pump)
May 07, 2009 | Honeywell Heating & Cooling
Not enough screws on my control board
I sounds like the thermostat you have is heating only. You need to buy and install a heating/cooling thermostat. The new thermostat will have a sheet with wiring diagrams to choose from.
Apr 23, 2009 | Honeywell L4064B2236 Fan/Limit Control...
Heating & Cooling Logo
59 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
