Question about Dyson DC23 Bagless Canister Cyclonic Vacuum
Beater bars not turning
Beater bars are not turning - suspect a bad belt - how do you change the belt
  • Official Brand Answer
  • 2,572 Answers
Hi there, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your DC23. This model doesn't include a traditional user-replaceable belt - the drive system is engineered to last for the lifetime of the machine.
If your machine is a DC23 Motorhead, please take a look at the video above to clear any obstructions from the brush bar and cleaner head, and to reset the machine.
If your DC23 includes an air-driven Turbine head, please follow the steps shown in our online Support guide to make sure everything is correct with your vacuum: http://www.dyson.co.uk/support/dc23/dc23-animal/my-machine-is-not-working/turbine-head-not-working-properly/check-the-plunger
If you'd like some further advice from our experts after you've given this a try, please contact the Dyson Helpline directly - you can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
If a repair or replacement part is needed, we'll be happy to confirm if this is covered under your vacuum's 5-year warranty.
Best wishes,
Jack
Dyson Online Customer Service
www.dyson.com
Posted on Nov 19, 2013
4 Suggested Answers
  • 231 Answers
SOURCE: Dyson vacuum DC17 beater bar won't turn
sounds like the brushroll motor has gone bad. disassemble the head and check the continuity on the brushroll motor
Posted on Feb 27, 2010
EwingElect
  • 276 Answers
SOURCE: beater bar motor will not engage
Check your clutch to make sure it's engaged. There should be a knob on the foot of the vacuum that can be turned to stop the roller.
Posted on Mar 22, 2009
  • 8 Answers
SOURCE: beater bar does not turn but belt is not broke
i think there is 2 belts one for clutch ,one for brush
Posted on Jul 28, 2009
Installing new belt
+>> Unplug the mains lead from electrical socket <<+
• Turn cleaner over in flat position.
• Release lower plate by rotating the 3 lower plate latches to the UNLOCK position.
• Remove lower plate and remove any dirt that may exist in belt area.
• Remove beater bar by gripping the belt side of the beater bar and carefully lifting it out.
• Remove worn or broken belt.
• Clean beater bar and the end caps.
• Loop new belt around motor shaft and beater bar belt groove.
• Reinstall the beater bar by inserting the end cap of the beater bar to the slots at both ends of th beater bar.
• After reinstalling the beater bar, turn it by hand to make sure that belt is not twisted or pinched and that all rotating parts turn freely.
• Reinstall lower plate by hooking front end of lower plate into slots on front of nozzle.
• Press lower plate onto nozzle and secure by rotating the 3 lower plate latches to the LOCK position.
Jan 12, 2013 | Panasonic Mc-Ul594 Eco Max - Bagless...
The brush on my Electrolux Versatility will not spin. You can spin it by hand, but the motor will not spin it.
Hello, W/D here.
Since the brush will not spin, but the motor works, either the belt has come off of the motor shaft, the belt is worn past it's useful life, or the beater bar has seized.
1. Turn off the power (unplug).
2. Remove the bottom plate. With the plate off, use your finger to test the tension of the belt. It should be tight, and roll when you roll the beater bar by hand.
3. Remove the beater bar and belt. Inspect the beater bar, particularly by the bearings. Remove any twine, hair, etc.
4. Inspect the belt for abnormal wear. If there is any significant wear in the belt, replace it.
5. Reassembly is in the reverse order. Place the belt on the beater bar. While holding the beater bar close to it's position, place the belt on the motor shaft. Rotate the beater bar bearings to their proper position and install the beater bar. Replace the cover plate.
Best regards, --W/D--
Jan 29, 2011 | Electrolux EL8502 Versatility Bagless...
Trying to change belt
The procedure for changing a belt will vary depending on the type of vacuum you have. However, I can give you some general guidelines. Unplug the vacuum and turn it over. Generally there will be some type of cover you need to remove to expose the beater bar. This cover can sometimes be removed by taking out screws and sometimes there are plastic tabs you need to push in with a screwdriver to loosen it. Once this cover is removed you will probably see the broken belt. You need to buy a replacement belt of the same size. You can probably look up your vacuum online to find out what size you need. You can also take the old belt to the store and match it up with the available new belts. Once you have a new belt you need to remove the beater bar. The ends of the beater bar will probably fit into some type of indentations or slots. Pull on the beater bar and it should slide out. Place the new belt around the beater bar. Also hook the belt around the metal motor stub located near the rear and to one side of the exposed underside of the vacuum. Now insert the beater bar back into its original slots. This will require pulling hard on the beater bar to stretch the belt forward and away from the metal motor stub. Replace the cover and you’re good to go. I hope this helps you out
Mar 30, 2010 | Vacuums
How do yu change the belt
Hello. W/D here.
On the baseplate that surrounds the beater bar, you'll see three large plastic screw heads. Turn these and youll feel the plate loosen. Raise the plate from back to front; it hinges toward the front. This gives you access to the beater bar. Remove the beater bar, making mental note as to how it comes out. You want to pay attention to the ends so you can get it back in easily. Remove whatever remains of the old belt. While you have it opened this far, inspect the suction cavity behind the beater bar; this is where they are most likely to stop up over time. Also take a moment to inspect the beater bar and remove the things that tend to wind up on the bar and at the ends. Slip your new belt over the motor shaft, and then slip the beater back under the belt. It will be tighter going back with the new belt. While the belt is on the motor shaft and the beater bar, slide the beater bar back into the sockets of the vacuum, and replace the base plate.
That's all there is to it!
Aug 13, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Change belt on a eureka
With the vacuum unplugged, turn the machine beater side uo. On the plate that surrounds the beater bar, look for release tabs to open the plate. Flip them and set the plate to the side. The beater bar rides in sockets. Remove the bar, install the new belt around the motor shaft, then work the beater back into the sockets. Replace the plate. Test your work by rotating the beater bar by hand, making sure that it is reinstalled correctly.
Best Regards, --WoobieDog--
Jul 10, 2009 | Eureka Vacuums
How do i change the belt on the bissell powersteamer 1697w????
Ok taking the cover off is good. I believe the the little red thing is the beater bar. This beater bar has brushes on it an extends the width of the vacum. Pull the beater bar out straight. Some times it is tight. Next is to place the new belt around the spindle in the back and slide the beatrer bar into the belt. No twists! Besure to have the beater bar with the seperated area with no brushes inline with the belt.Now place the beater bar in place. Make sure you turn the beater bar so on the side the slotted portion slides all the way in place. Replace your cover. Turn it on and try it.
I believe this will work. Let me know.
desmjs
Dec 14, 2008 | Bissell 6594 PowerForce Bagless Upright...
Beater Bar Does not turn
YOU MAY HAVE A POSSIBLE BAD BELT OR THE MOTOR THAT RUNS THE BAR MAY BE BAD, THE OTHER POSSIBILITY IS THE SWITCH THAT TURNS ON THE BAR MAY BE BAD. OR A WIRE COULD HAVE COME OFF THE MOTOR. i THINK YOU DO KNOW THAT THE BEATER BAR DOES NOT RUN WHEN ON WOOD FLOORS.
Dec 03, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Vacuum turns on and suction in hose works, beater bar won't turn
If you hear the motor in the head running and the beater bar isn't rotating, you probably need a drive belt. With the power off, make sure you can rotate the beater bar freely by hand, if it isn't bound up.. then locate and remove the baseplate screws to gain access to the beater bar itself, you'll see a drive belt pulley system and chances are, a broken belt. Replace it with a new one by pulling the beater bar assembly out of the housing and plcing the belt onto the motor shaft pulley as well as the beater bar pulley.. nest the beater bar back into the holder and reinstall the cover. Hope that helps !
Aug 14, 2008 | Eureka Vacuums
Beater bar
You may have a bad switch, one part of it is not turning on the brush roll motor. It could also be the brush roll motor.
Feb 08, 2008 | Clarke CombiVac 12 Bagged Upright Vacuum
Vaccuum stopped running
Belt jumped off beater bar and jammed it! Disconnect belt, does imotor run. If yes, reconnect belt turning beater bar by hand to see if it is smooth. Carefully, reassemble and run it!
May 28, 2007 | Eureka 4386AT Upright Vacuum
Dyson DC23 Bagless Canister Cyclonic Vacuum Logo
480 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
