Fm radio works fine but the dab will not find any stations, I have tried different aerials and still no good
What's the make & model of the radio?
Most DAB/FM radios work from the same antenna, so if you receive FM stations, you should receive DAB stations in your area.
It should be noted that DAB transmitters work on lower power than conventional FM transmitters, and so you may be in a weak reception area (for DAB). It should also be noted that DAB uses different frequencies than regular FM stations and household appliances such as laptops,WiFi, microwave ovens, etc can affect DAb reception.
Posted on Nov 20, 2013
  • Dave Perryman
    Dave Perryman Nov 20, 2013
    Hi Paul, the make of the tuner is a Teac T-H300 dab mk2
    It has a separate aerial socket for the dab radio.
4 Suggested Answers
  • 1116 Answers
SOURCE: I have 6 preset DAB
You can download your manual for the radio at this link:
http://lowryelectronics.webeden.co.uk/#/gsdab0904/4536733630
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Posted on Jun 01, 2011
  • 71 Answers
SOURCE: DAB radio model Sharp FV-DB1E
This is SwannerX and I have solved the problem by locating the DAB radio receiver to a higher position ( some 6ins. higher only ) and orienteering the aerial in an opposite direction.
All 25 stations now tune O.K. and signal quality still reads in the high 90's and signal strength shows 9-10 bars. This is not substantially any more , but it has done the trick!!!
I am still very puzzled why it would not work again in the original position where it has worked well for many years.
Obviously DAB requires a good strong signal as I am living very close to the transmitter at Mounteagle in the Black Isle and the set is upstairs in the house to achieve the highest signal into the set's whip aerial.
Another annoying query I can give you is this :- Every time I do a full AutoTune operation on the DAB receiver , it ALWAYS comes ON tuning BBC Asian 1st. so that station comes up as a 'Favorite' on the Radio's screen. No matter how many other stations I select and listen to for at least 20secs. say, the BBC Asian one STILL is listed as a FAV.
Is this a peculiarity of the Sharp design or a function of the transmission system?
Maybe this BBC Asian is on the first freq. the DAB Radio scans, but I would have thought it would come ON every time with the last station which was selected before it was switched OFF.
What do you think ???
Posted on Feb 26, 2008
  • 71 Answers
SOURCE: how to reboot hitachi dab radio
Sounds like what happened to my Sharp DAB receiver recently . - Swtch OFF completely from all power sources and proceed with the recommended RESET function.
Move set and/or aerial to be sure of a good strong signal before attempting a complete re-start and full AutoTune as per the instruction manual.
This operation certainly cured my problem although I never have found out what caused the failure in the first place!!!
Posted on Feb 29, 2008
Why will my radio new 3120 not pick up dab stations at all really tune and all I get is radio 2 have tried for a week to get magic fm thank you
If you have replaced a normal car radio with a DAB then your existing aerial is not suitable due to the required frequency range. You need a DAB aerial for cars. There are many types available, internal or external. Don't bother with converters as this will only give a marginal boost to the fm aerial.
Jun 06, 2016 | Cars & Trucks
Can not get DAB radio too work on my Vita audio but FM radio works fine
This may be because you live in an area where DAB reception is currently poor, but to check this, please use our postcode checker (see 'check your DAB coverage' panel on the right) to see which DAB stations you should be able to receive. If reception for your area appears to be good, then it may be down to local conditions or building materials. Buildings constructed from steel and reflective glass are not good for radios with internal aerials as they reflect and greatly reduce the strength of signal. In such a case an external aerial will greatly improve reception, but most importantly, if you are using the supplied telescopic aerial, you should ensure that it is properly fitted and fully extended upright.
Secondly, when our products are first powered up from new, they automatically scan the DAB network to see which services are available. During this process it is important that the radio is not touched and that the aerial has been correctly fitted and extended as instructed. If this has not been done then it is likely that not all stations will be detected and only the strong ones displayed. To correct this a new AutoScan/AutoTune or System Reset should be performed as instructed elsewhere in our Q&A's.
questions answers
Sep 04, 2014 | Audio Players & Recorders
Radio appears not to work at all. No sound.
check to see if you have 12 volts at the memory (yellow in most cases) wire it should be powered all the time the red wire is acc. key on
Jan 17, 2014 | Yamaha MCR-042 Micro Component System...
Teac 300mk2
how about a filter to the radio and electric frequency antenna! radio shack has them like a booster!
Nov 18, 2013 | Computers & Internet
Dewalt dc011 recently the fm stations stopped working...only hearing static. i returned the radio back to home depot for a new one. just trying avoid it happening again. the only thing I could have done...
as it is a tough radio to take the knocks it probaly gets knocked around a bit- make sure the antenna is not loose! or damaged have you rotated it a bit too much and snapped the wire inside? try AM to prove it (if Fitted), AM doesntuse the external aerial
Good Luck!
Jan 14, 2010 | Dewalt DC011 AM/FM Radio
How to reboot hitachi dab radio
Feb 29, 2008 | Audio Players & Recorders
Feb 22, 2008 | Audio Players & Recorders
696 people viewed this question
 Grubhead
Grubhead
