Question about Whirlpool Refrigerators
Whirlpool Side by Side refrigerator interior refrigeration section light glows orange and makes noise
Light in refrigerator section glows orange and makes noise
    Champion:
    Habit-Forming:
  • 275 Answers
Have you tried replacing the lamp to see if problem goes, is so then its probably coming from the door switch.
Posted on Nov 22, 2013
peyton32034
  • 410 Answers
SOURCE: WHIRLPOOL GS6SHEXNL00 SIDE BY SIDE REFRIGERATOR LIGHT
funny you asked this question i just had this same problem this week at a customers home. you need the electronic control board located in the compressor compartment behind the refrig. it is mounted in the white box on the left hand rear corner. the whirlpool part number is 2304095 and it is around 175.00 i'm not sure who a local part supplier around you would be if all else fails you could get thru sears..
Posted on Jan 07, 2008
SOURCE: whirlpool gold refridgerator light not working and is making funny noise
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
Posted on Jul 30, 2008
SOURCE: Refrigerator making a whinning noise.
this is the way firidges are made. **** isnt it..
Posted on Aug 08, 2008
SOURCE: Whirlpool Refrigerator Door Seal surface is HOT.
If the air flow on the condenser under the fridge is too low, the hot gas won't be cooled enough before it goes to the door jamb to stop condensation. Remove the plastic cover under the doors and look at the condenser (tube/wire thing underneath). If it is clogged with fluff, get a vacuum and nozzle and give it a good clean so the air can pass through. Other than that, your condenser fan may have stopped.
Posted on Mar 27, 2009
  • 2468 Answers
SOURCE: I have a whirlpool side by side refrigerator model
you need to replace the main/board for sure located in the lower rear left hand wall of the unit in a plastic case, it will have 3 wire harnesses unplug the unit,undo the plastic container and unplug the the board and there will be a burned spot on the case and burned trace on the circuit board, reason being,this is very common on any of these sideXsides,if a light blows out in the refrige compartment it puts a surge on the board and burns the circuit trace open,this makes the digital temp read-out go dark and if the lamps light at all they "strobe" dimly or not at all,and you will hear a clicking of the relays in the rear area trying to latch the light bulb circuitry, but cant because the main/mother-board is defective now
Posted on Mar 02, 2010
I have a Whirlpool ED5KVEXVQO2 Side by Side refrigerator. It is still very cold but making odd noises and smells like rotting oranges, mainly in freezer. Is this freon?
refrigerant doesn't smell much at all. remove all drawers, clean and defrost, rinse inside with sanitizer. you may find somethimg fallen where you can't see it normally. also check and clean outside as well, particularly around the compressor and condenser where it gets very hot.
May 04, 2014 | Whirlpool Refrigerators
GS6SHEXN500 fridge light and display on temp control flickers and sounds like relay making noise
The problem could be very well a relay that has the contacts pitted or weak causing the lighting in display and the interior lights to flicker. Here is a GS6SHEXNS00 Parts List and the relays I can see are in a covered control box near the compressor on page 17 and 18 on the parts list 2304056 Electronic Control I will be here if you should have any questions, Thanks Sea Breeze
Apr 01, 2013 | Whirlpool Gold White-on-White 21.9 cu. ft....
Timer is making a rattling noise. where is it located on an ed25gwxxwoo frig
usually behind the light shroud in the back of the fridge section . Check under the kick panel under the doors.
Oct 27, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Our Smeg SR640XA side by side refrigerator is making strange puffing noises at the bottom section of the freezer. It puffs four or five times and then it sounds like something is dribbling in the back of...
It is the defrosting heating elements and sensors that has gone bad.
Check for glowing light at bottom of the back panel. Turn the freezer section off and contact Smeg!
Mar 14, 2010 | Smeg FA561X Side by Side Refrigerator
Our whirlpool refrigerator makes popping noises several times a day why
If comming from freezer section , then defrosting . Water dropping down onto the hot defrost heater . Defrosts either 8 or 10 or 12 hrs.
Jul 19, 2009 | Whirlpool GS6NBEXR Side by Side...
Whirlpool gold refridgerator light not working and is making funny noise
switch of your refrigerator then try replacing the light that doesn't work then try to switch it back on. the light might be the cause of the noise. it might be grounded. replacing the light might reduce the noise then observed the noise for a week then if it still making noise that's the time for you to get a technician that could fix your refrigerator.hope it helped... send us a message for more concerns thank you...
Jun 03, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Glowing light and warm air freezer side
HI thanks for your question. you found your freezer in a defrost cycle, which is normal function.the defrost cycle happens every day every 10 hrs. on for about 20 min. then resumes the cooling cycle. so its normal. thanks the appliance doc, please rate my answer. thanks.
Oct 12, 2008 | GE Monogram ZICS360NRRH C... Bottom...
Red glow (from defrost heater?) at bottom of rear panel in freezer
This is from the GE Appliance "Knowledge Database" Web site:
Refrigerator - Explanation Of Red Glow
In a no frost refrigerator, the defrost timer activates defrost heaters in the evaporator section (rear of freezer) which heat up and melt the frost off the evaporator coils. This process lasts for approximately 25-45 minutes and usually happens up to twice a day.
During this time, there will be no running sounds, no fan noise, and you may hear water dripping or sizzling as it hits the heaters. On side by side models, you may even be able to see an orange glow at the bottom of the freezer.
This is normal.
Aug 06, 2008 | GE GSS20IEP Side by Side Refrigerator
Heating element in a refrigerator?
The orange glow you see is your defrost heater. Your refrigerator goes into the automatic defrost mode three times a day. This keeps the unit frost-free.
Oct 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
