Question about Vocopro PA-MAN-II Wireless PA System, 4 Ch - FREQ 3
CD port will not open
CD will load and play but will not eject from the player
6 disc CD player won't play, eject a loaded CD or load a new CD
You may have to remove the radio and disassemble it remove the jammed CD. Unfortunately, there is no easier solution for the problem.
Aug 31, 2016 | Car Audio & Video
There is a cd in the drawer and it plays great. But i cant get the drawer to open to change it
You may have a load / eject motor issue.
That being said there should be a pinhole to eject the CD. Straight out a paper clip and insert into the hole and press the manual eject button
May 06, 2016 | Audio Players & Recorders
CANT OPEN THE CD DOOR
Take out the complete mech, look for a small pulley wheel under the tray and turn it with your finger until it releases the disc
Apr 19, 2014 | Kenwood Audio Players & Recorders
CD drawer will not open
This is most commonly a belt in the drawer mechanism and is easy to fix IF you have the right belt in hand and can access where it goes.
A technician will be able to help.
Dec 08, 2012 | Audio Players & Recorders
JVC xl-fz258 won't open to eject cd, won't play
The basic problem is that the drive mechanism has failed. The problem with CD ejection can be caused by binding in the tray or a weakened ejection motor
Dec 02, 2012 | JVC XL-FZ258
I have a 2004 Mazda 3 w/ a single disc CD player...which has not been working for several months. There is a cd in the player but nothing happens when I press the eject button nor the CD button; won't...
Possible that the cd disc has jammed due to a change in the disc- warming can bend some cd's, also if the cd is struck inside as the loading mechanism is struck. In both cases the set must be pulled out if there is no hope with trying to retrieve the cd softly assisting while ejecting. If you do not hear any noise while the eject is pressed then the loading drive is faulty , you need to remove the cd , open to check, If this is mechanical then you can softly push the cd out, if not the electonic section needs a check.
May 03, 2011 | 2004 Mazda 3
LG car CD, MP3, WMA Receiver wont play or eject CD's??
please observe when you push the eject button display applys the open or eject cd?.if yes something wrong with your mechanisum.it has several microswitches and bad contact of them occur this type problem.sometime loading mechanisum stuck because of loose belts.open the cover of your cd player and check cairfully.
come back with results.
nuwan
Jan 08, 2009 | Car Audio & Video
Stanton C303 wont eject CD
Remove the power completely replug and then quickly turn it on press eject emediatly..... this should work
Jan 01, 2009 | Stanton C-303 Single Top Loading CD Player...
Sony CDP-CX300 CD won't play
The rubber drive belt for the c/d load mech is streched or broken,
replace the belts there is another that drives something else so change them both while you have it open
Sep 17, 2008 | Sony CDP-CX300 CD Player
Vocopro PA-MAN-II Wireless PA System, 4 Ch - FREQ 3 Logo
197 people viewed this question
Top Vocopro Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Vocopro Audio Player and Recorder Expert? Answer questions, earn points and help others
