My feedback - Computers & Internet
Excessive feedback
On mic? On guitar? Take top frequencies off EQ, point mic away from speakers. Use decent dynamic mic or feedback resistant condenser such as Sennheiser e865. Try Behringer feedback shark
Feb 06, 2014 | Music
Too much feedback
Can you explain your terminology? Feedback or Standing Waves? Typically, Feedback is audio feedback through the speaker and back into the microphone of the CB or out of the external speaker into the mic. It can also be RF Feedback that is caused when the system. If it is audio feedback, it could be that someone has installed a T
"talk back" option and that's why you are getting feedback, if it's audio feedback.
Jun 03, 2013 | Cobra 18 Wx St Ii Mobile Cb Radio
Controller giving feedback?
If you are not using a microphone, then you are not the feedback source.
That being said, a blue-tooth headset still qualifies as a microphone, and is capable of generating feedback.
If using blue-tooth, then switch to a standard wired headset to determine if the feedback diminishes.
Regardless of headset type, be sure to have game chatter through the headset only setting as opposed to through the TV speakers, and keep the TV turned down. There will be an obvious lag between TV speaker and headset microphone which can create a feedback loop.
If other gamers can hear your TV when you are talking, then the TV output is too loud and will create feedback opportunities.
If none of the above applies, then the feedback is generated elsewhere.
Hope this helps!
Apr 22, 2012 | Microsoft Xbox 360 Wireless Controller
Need to find and replace the DPFE-15 sensor. Dealership diagnosed when service engine light came on and saaid this is what needed replacing. Problem is I do not know where to find it on the engine.
Exhaust Gas Recirculation (EGR) System The exhaust gas recirculation (EGR) system is designed to:
  • reintroduce exhaust gas into the combustion cycle.
  • lower combustion temperatures.
  • reduce the formation of oxides or nitrogen (NOX).
The amount of exhaust gas reintroduced and the timing of the cycle varies by calibration. Timing and volume are controlled by the following:
  • engine rpm
  • engine vacuum
  • exhaust system back pressure
  • engine coolant temperature
  • air charge temperature
  • throttle position
The EGR valve (EGR valve) (9D475) is vacuum-actuated. The vacuum hose routing diagram is shown on the Vehicle Emission Control Information (VECI) decal. The EGR system is a differential pressure feedback EGR Sensor system. Differential pressure feedback EGR Sensor is a subsonic closed loop EGR system. The differential pressure feedback EGR system:
  • monitors EGR flow rate by the pressure drop across the metering orifice located in the EGR tube.
  • uses a differential pressure feedback EGR sensor as the feedback device.
  • uses the EGR valve only as a pressure regulator, rather than a flow metering device.
  • controlled pressure is varied by the valve movement using vacuum output of the EGR vacuum regulator solenoid (9J459).
  • allows for a more accurate assessment of EGR flow requirements.
Differential Pressure Feedback EGR Flow Diagram
Differential Pressure Feedback EGR Sensor Removal
  1. Disconnect engine control sensor wiring (12A581) from Differential Pressure Feedback EGR Sensor.
  1. Disconnect Differential Pressure Feedback EGR Sensor hoses from EGR valve to exhaust manifold tube (9D477).
  1. Remove retaining nuts or bolts (depending upon application) and EGR Differential Pressure Feedback transducer.
Installation
  1. Follow removal procedure in reverse order.
  1. Tighten retaining nuts or bolts (depending upon application) to 5-7 Nm (45-61 lb-in).
    Differential Pressure Feedback EGR Sensor, 3.0L (2V) Engine
    Differential Pressure Feedback EGR Sensor, 3.0L (4V) Engine
    Item Part Number Description 1 6049 RH Cylinder Head 2 - Differential Pressure Feedback EGR Sensor 3 - Nut (2 Req'd) 4 - Stud Bolt 5 - Bolt (2 Req'd) 6 - Differential Pressure Feedback EGR Sensor Bracket A - Tighten to 5-7 Nm (45-61 Lb-In) B - Tighten to 8-12 Nm (71-106 Lb-In)
    Engine Emission Control Component Location-3.4L SHO Engine
    Item Part Number Description 1 95607-05200 Nut 2 - EGR Sensor Hose 3 - EGR Sensor Hose 4 95027-08016 Bolt 5 - Differential Pressure Feedback EGR Sensor 6 9J433 Differential Pressure Feedback EGR Sensor Mounting Bracket 7 9D474 EGR Solenoid Vacuum Valve (2 Req'd) 8 A4670 Vacuum Tube Assembly 9 9424 Intake Manifold 10 9J459 EGR Vacuum Regulator Solenoid A - Tighten to 5-7 Nm (45-61 Lb-In)
Hope this helps
Aug 14, 2011 | 1999 Ford Taurus
Do i leave feedback ferret on all the time or take it out when feedback is measured
Normally you find where feedback occurs, notch it out with the EQ and recheck for feedback. When system is stable you can take out the ferret.
Feb 04, 2011 | Peavey 32fx USB 32 Channel Mixer
How do i change the feedback given to a company?
Hi there!
If you already left Feedback and if it's negative, you can ask the seller to send you the Feedback revision request and you can then revise the Feedback.
Please check my tips and tricks.
Thanks!
Dec 23, 2010 | eBay Auctions
Why has my feedback rating gone down??
Hi there!
Feedback percentage is based on the Feedback that you receive within 12 months. Check the Feedback that you received within 12 months in the Feedback profile page and then check if you received neutral or negative the rating will go down as the Feedback you received past 12 months rolls off. Please check this link http://pages.ebay.com/help/feedback/howitworks.html
Nov 02, 2010 | eBay Auctions
P1109 error code
DTC P1109 Secondary Port Throttle System
Did you get a subcode?
-0F Swirl Actuator Malfunction
-08 Swirl Actuator Supply Voltage Range/Performance
-05 Swirl Actuator Feedback Circuit High Voltage
-02 Swirl Actuator Feedback Circuit Low Voltage
-29 Swirl Actuator Feedback Signal Malfunction
-28 Swirl Actuator Feedback Signal Malfunction
-21 Swirl Actuator Feedback Signal Range/Performance
-54 Swirl Actuator Feedback Powerstage High Temperature
Oct 29, 2010 | 2004 Saab 9-3
How do i send feed back for an iten i have purchased
Go to your my ebay page. then go to the won section. From there you can pick the item to leave feedback for. Just click on the item to take you to the auction page then you will see leave feedback tab.
Jan 30, 2010 | eBay Auctions
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
