Question about Sony KDF-E55A20 55 in. LCD Television
Sony Service bulletin E29102171 - Sony KDF-E55A20 55 in. LCD Television
Sony kdl55hx800 tv keeps turning off. Standby light flashes 7 times. Whats the problem? Is there a service bulletin?
This is a protection error indication. May have to download a service manual for this model and look at it for the area of problem. Most probably, this is in the Line Out section.
Jul 11, 2012 | Sony Televison & Video
BLUE PATCH SHOWING UP IN LOWER LEFT CORNER -- GETTING LARGER AND DISCOLORATION INCREASING
This is called the blue spot defect.. NOT trying to be smart but it is known by Sony. It requires replacing the light engine. contact Sony customer relations. Your set is part of a fix . service bulletin e27964821 It expires march 2011. The repair will be free of charge to you once Sony issues your local service center a repair action work sheet.
Please leave feedback
Feb 21, 2011 | Sony Grand WEGA KDF-50WE655 50" Rear...
The sony model KDF-E55A20 has no sound or picture. The power led flashes red six times consecutively after being turned on.
Your thermal fuse has popped and needs replaced. This TV has a service bulletin regarding this issue. You should contact Sony for the replacement part/kit.
Mar 14, 2010 | Sony KDF-E55A20 55 in. LCD Television
Fujitsu Plasma Screen won't power up
This is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem in a similar model from Fujitsu. -see link below
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
A competent service technician should be able to implement the service bulletin.
A similar service bulletin is probably available for your model. Request bulletin from Fujitsu 'service@fujitsugeneral.com'
May 18, 2009 | Fujitsu Plasmavision PDS-4242 42 in....
I have a sony trinitron kv36fs13. Text on the screen is distorted
You need the original remote to get in the service menu. Sounds like a deflection yoke problem Sony has an 8 page bulletin on this depending on ser# of tv. Est cost of repair is 250.00-300.00 not for the novice. Recommend calling Sony service center.
Apr 16, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony 60
There is a bulletin that addresses this problem, but you must follow it EXACTLY as it invoolves changing settings in the service menu and you could easily make your TV unuseable if you change the wrong thing. if you want the bulletin i could send it, but I would recommend you have a Sony qualified tech do the adjustment
Nov 03, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Red ghosting
There is a bulletin that addresses this problem, but you must follow it EXACTLY as it invoolves changing settings in the service menu and you could easily make your TV unusable if you change the wrong thing. if you want the bulletin i could send it, but I would recommend you have a Sony qualified tech do the adjustment
Oct 31, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Sony service bulletin
You will get the Service Manual to your email by Pando.
Hope this will help.
Best regards,
Arpi
May 31, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Turns off after awhile
Apr 12, 2008 | Fujitsu Plasmavision PDS-4214 42 in....
Sony KDF-E55A20 55 in. LCD Television Logo
275 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
