Question about Memorex Audio Players & Recorders
Won't operate, wiring is fine
Does not respond; tried a new one from the store, still nothing.
  • 2,113 Answers
Did you turn off the tamper switch?
Posted on Nov 18, 2013
My control won't activate the light on my Hunter fan. The light comes on via pull chain fine, and the control works the 3 speeds on the fan, but the light won't respond.
Check the wiring on your receiver to make sure the light wire is connected.You have to have the light on with the pull chain and then use the remote to turn it on/off.
Jan 06, 2013 | Hunter 52" Ceiling Fan With Light And...
99 dodge Durango won't start
At www.reliable-store.com get complete guide on whether to repair or not,
service it, and how to repair etc, along with wiring diagrams, electrical diagrams, torque specs, error codes, everything.
Feb 28, 2018 | 1999 Dodge Durango
I have an astrostart remote hst5224 that has a new battery and it beeps...but nothing else
This remote can operate up to four different vehicles, the default is 2, make sure you are in the correct mode. This is changed by pressing the "P" button on the back of the remote for two seconds, each press advance the mode one position. do this till you find the one that works. There are only four to try
Oct 03, 2012 | Cars & Trucks
Vacuum was working fine one day, next day it won't come on
You can try doing this first, plug it in to your outlet and switch it on. If it will not start, try to move the wire near the plug to see if the problem is a lose wire in that area. If it responds in moving the wire you have to replace the plug of your vacuum. Message me if you need further assistance. Thanks..
Jul 22, 2012 | Vacuums
Rad fan won't turn on when the car is at operating
The first thing I would check would be the temperature sensor that sends a signal to the relay to turn the fan on. Of course make sure you have plenty of water in the radiator or the sensor won't work at all. I have seen anti-freeze come through the sensor and corrode the wires shorting them out. So it could be broken wires, unplugged wires or a bad sensor. I am not sure exactly where the sensor is at on the Pacifica but your local parts store could show you. It is usually in the intake or cylinder head.
Sep 06, 2011 | 2004 Chrysler Pacifica
MojogiMy GHD1621F2 freeview recorder is frozen on one programme, won't respond to the remote at all (have new batterys) and won't respond to buttons on front. Turning off and on doesn't work...
Hi mojogill,
It sounds like the receiver may be locked up. If the buttons on the front do not work, then try unplugging the receiver for 5 seconds and plug back in then check to see if everything is working fine.
If you need any further assistance with this, feel free to contact me at thomas.faust@dishnetwork.com. Thanks!
Tommy Faust
DISH Network
May 25, 2011 | DISH Network ViP722 DTV Receiver /...
Replaced battery, bike started fine. Let it sit overnight, won't start. Won't even crank, just clicks once then nothing, the Neutral light shuts off and the lights started flickering.
To begin with, I'd have that battery load tested to see if it's any good. I've seen brand new batteries that were bad. It it checks OK, check all the connections that go to the battery. Be especially attentive to the smaller wires that attach to it. I've seen battery acid eat the wire out of the insulation leaving the insulation intact and the wire appeared fine. If the wire bends too easily, be suspect. If the wires have the "crimp on" connectors, make sure they're tight. Your problem sounds like a bad connection somewhere.
Good Luck
Steve
May 19, 2011 | Harley Davidson FXST Softail Standard...
Jensen VM9410 - Stopped Operating All Of A Sudden
Sound like to me you got a problem with the capcitor inside the unit, if its under warrenty it will need to be serviced. If its not I ould be checking capcitors inside to make sure there not bulging leaking or otherwisen ot wroking correctly.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 24, 2009 | Jensen VM9410 Car DVD Player
46 people viewed this question
Top Memorex Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
