Question about Sharp Mx-m260 26ppm Copier
Copy machine is stuck in the copy mode
Machine is stuck in the copy mode. will not go into the fax mode when you push the fax button. all other buttons work and touch screen work ok
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Sharp Expert
  • 106 Answers
Sounds like the machine does not have a fax board on it. Have you been able to fax in the past?
If nothing else, try rebooting the machine, then have your servicing dealer come out to check the fax board module if rebooting doesnt help.
Skelton Business Equipment Houston Copiers
Posted on Jul 28, 2014
Testimonial: "Thank you. I forgot to remove this question. We figured it out. We had to replace the control panel."
Canon_fax_b820_error_342
Do the following procedure 1. Press the buttons in the order of [FUNCTION]- [*] - [5]. 2. [TIME SET HH:MM] is displayed. 3. Current time is displayed following the date [12/12/12 xx.xx]. 4. Press the [START/COPY] button. 5. [DATA SET] is displayed. 6. [CS PRESCAN] is displayed. 7. [INK DETECTOR] is displayed. 8. [PRESS START/COPY] is displayed. 9. Press the [START/COPY] button. 10. [ # TST START:STBY] is displayed. 11. Press the [START/COPY] button. 12. [Please Wait] is displayed. 13. The machine enters the standby mode. 14. Press the [FUNCTION] button and then [#] button to enter the service mode. Execute [All Clear]. 15. [Please Wait] is displayed. 16. The machine enters the standby mode. 17. [LANGUAGE] is displayed. 18. Press the [START/COPY] button. 19. Select the language. 20. Press the [START/COPY] button. 21. [DATA ENTRY OK] is displayed. 22. [COUNTRY SELECT] is displayed. 22. Press the [START/COPY] button. 24. Select the country. (If country of your choice does not appear, turn the machine OFF and then ON. Press the [FUNCTION] button and then [#] button to enter the service mode. Select the country from the [Type Setting].) 25. Press the [START/COPY] button. 26. [DATA ENTRY OK] is displayed. 27. The machine enters the standby mode. 28. Press the [FUNCTION] button to set the date and time. If your problem not solved replace the SCNT PCB
May 01, 2011 | Canon FAX-B820 Plain Paper Bubblejet
Mi da errore ##331 .... dopo aver cambiato le cartucce . prima mi dava errore ##342 ... e non mi prende la carta . ho il fax canon b 140 AIUTATEMI Grazie mille
Do the following procedure 1. Press the buttons in the order of [FUNCTION]- [*] - [5]. 2. [TIME SET HH:MM] is displayed. 3. Current time is displayed following the date [12/12/12 xx.xx]. 4. Press the [START/COPY] button. 5. [DATA SET] is displayed. 6. [CS PRESCAN] is displayed. 7. [INK DETECTOR] is displayed. 8. [PRESS START/COPY] is displayed. 9. Press the [START/COPY] button. 10. [ # TST START:STBY] is displayed. 11. Press the [START/COPY] button. 12. [Please Wait] is displayed. 13. The machine enters the standby mode. 14. Press the [FUNCTION] button and then [#] button to enter the service mode. Execute [All Clear]. 15. [Please Wait] is displayed. 16. The machine enters the standby mode. 17. [LANGUAGE] is displayed. 18. Press the [START/COPY] button. 19. Select the language. 20. Press the [START/COPY] button. 21. [DATA ENTRY OK] is displayed. 22. [COUNTRY SELECT] is displayed. 22. Press the [START/COPY] button. 24. Select the country. (If country of your choice does not appear, turn the machine OFF and then ON. Press the [FUNCTION] button and then [#] button to enter the service mode. Select the country from the [Type Setting].) 25. Press the [START/COPY] button. 26. [DATA ENTRY OK] is displayed. 27. The machine enters the standby mode. 28. Press the [FUNCTION] button to set the date and time. If problem not solved replace SCNT PCB.
May 01, 2011 | Canon FAX-B840 Plain Paper Bubblejet
I just installed my brother 2820, but it won't print, only wants to fax
Copy or print? To copy you must push the copy button on the control pannel first and then the number of copies and then start. By default it may be in fax mode.
Aug 12, 2009 | Brother IntelliFax-2820 Laser Fax
PRINTER STAYS IN FAX MODE WHEN I WANT TO PRINT
if you push the copy button you will be in copy mode.
are you saying you want your default to be in copy?
Apr 19, 2009 | Office Equipment & Supplies
Phantom jams & button undetection
Sounds like a button may be stuck or something. Reset machine by powering off, press and hold start button at same time while powering machine back up. Hold the start button down for a few seconds and release. This should help. Let me know if it does not and I may be able to walk you through another bit harder reset.
Mar 12, 2009 | Brother IntelliFax-2820 Laser Fax
Not sure how to setup the tel/fax mode correctly
The JX200 has four modes of fax receipt - Fax/Tel, Manual, Answering Machine, and Fax Only. The Fax/Tel mode, which you have indicated is your desire, is meant to let the fax machine automatically switch between fax and voice calls. Documents are received automatically, and the machine rings for voice calls.
Set the mode by pressing [Receive Mode/Resolution]. Every time you press [Receive Mode/Resolution], the mode changes cyclically.
If you set Fax/Tel mode, you can control precisely how the fax handles incoming calls by adjusting the following settings:
• Adjust the time the fax takes to check whether a call is from a fax machine or a telephone (<RING START TIME> setting).
• Adjust the length of time the fax rings when the call is a voice call (<TEL RING TIME> setting).
• Set whether the fax switches to receive mode after the ring time set in <TEL RING TIME> has elapsed (<DEFAULT ACTION> setting).
1. Press [Menu].
2. Use arrows to select <DATA REGISTRATION>, then press [Start/Copy]. The LCD displays <USER SETTINGS>.
3. Use arrows to select <RX SETTINGS>, then press [Start/Copy]. The LCD displays <ECM RX>.
4. Use arrows to select <FAX/TEL AUTO SW>, then press [Start/Copy]. The LCD displays <RING START TIME>.
5. Press [Start/Copy]. The LCD displays <8SEC.>
6. Use the numeric buttons, or arrows to enter the time the fax waits before ringing when it receives a call, then press [Start/Copy] twice.
7. Use the numeric buttons, or arrows to enter the time the fax rings while waiting for someone to pick up the Handset, then press [Start/Copy] twice. The LCD displays <RECEIVE>.
8. Use arrows to select <RECEIVE> or <DISCONNECT>, then press [Start/Copy]. This setting tells the fax what to do if the Handset is not picked up within the specified ring time set in step 6.
9. Press [Stop].
Setting ends and the fax returns to standby mode. The machine will now handle calls as indicated in the settings you input.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Jul 31, 2008 | Canon FAX-JX200
Phaser 6110mfp stuck in fax mode, won't copy
NOTE: The Phaser 6110MFP|XN is preset to the Fax mode, but can be switched between the Fax mode and the Copy mode.
  1. Press the [Menu] button on the Control Panel until 'System Setup' is displayed on the bottom line of the Display Screen, and then press the [Enter] button.
  2. Press the [Left] or [Right] arrow button until 'Machine Setup' is displayed, and then press the [Enter] button.
  3. Press the [Left] or [Right] arrow button until 'Default Mode' is displayed, and then press the [Enter] button.
  4. Press the [Left] or [Right] arrow button until the required default mode is displayed, and then press the [Enter] button.
  5. Press the [Stop / Clear] button to return to the Standby mode.
Apr 19, 2008 | Office Equipment & Supplies
Brother Fax 4750 System error 76
try resetting the machine by pushing the features button, and then *2864 in quick succesion, if done correctly you will enter test mode, then enter 91, and then after that clears enter 99 to exit test mode. make a copy to see if it works, and if it doesn't it is time to replace the fixing assy.
Apr 17, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Canon fax jx200 wrong language.
Press the power button and hold it down until the display says "Select Language". When you see this, press the start/copy button and then press the up or down arrows to select the language...then press start/copy again to make it stick. For more details you can download the manual from this web page.
Mar 17, 2008 | Canon FAX-JX200
Imagistics 2500 fax stuck in the "printing" mode. Need to reset.
Yes that worked!! I unplugged it, and kept the red stop button push in while plugging back in and it cleared it out! THANK YOU!
Jan 28, 2008 | Brother MFC-8220 Fax
Sharp Mx-m260 26ppm Copier Logo
83 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
