Question about Refrigerators
My f&p E240b is chilling the fridge too much n the freezer is freezing. The fan is going intermittently from the fridge to the freezer. I've defrosted the freezer but is refreezing again and the temp control in the fridge keeps flashing. Can anyone help diagnose? Thanks
  • Jasmine
    Jasmine Nov 18, 2013
    Sorry the freezer isn't freezing properly
SOURCE: Over Chilling Refridgeration set on 7C still goes to 0C Digital thermostat
behind or inside the digital display casing-mike
Posted on Sep 30, 2008
huuum
  • 750 Answers
SOURCE: Candy CPCA250 GB Freezer feezing but fridge not cold
Hello jonnyclewlow
Welcome,
You said, you recently had a problem with my Candy fridge freezer (it defrosted overnight and wasnt cooling at all) and a repair shop diagnosed a thermostat problem. I have replaced the thermostat, Now the freezer freezes without any problems but the fridge does not go cold at all.
Also the compressor is running constantly
This is my first thought
Fresh Food temperature is
too warm. Freezer
temperature is satisfactory.
1. Fresh Food control is set too
warm.
2. Set fresh food control to a colder setting. Allow 24
hours for temperature to stabilize.
3.Then see if you do not have your freezer articles packed full up to the top, or covering the cold air vents usually found in the rear of the freezer compartment.
The fridge and the freezer share the cold air so the air must not be restricted from travel form the freezer to the fridge and back!
This would also cause the compressor to run none stop trying to cool the fridge!
So check your air vents in the freezer.
I'll bet you did not know they were there !
Most of us never notice!
Hope this works for you.
Please let me know that one of these solutions worked for you!
or if you have any questions.
Thank You, huuum
Please remember to leave a rating!
Posted on Oct 14, 2008
SOURCE: Fridge freezes contents
Check the door seal is not split,it may be letting air into the compartment
Posted on Nov 14, 2008
josecolono
  • 6 Answers
SOURCE: everything in freezer defrosted
the defrost has a timmer you mite have to chang it ok
Posted on May 14, 2009
  • 117 Answers
SOURCE: Hi my Samsung fridge freezer
some good stuff on youtube re
samsung fridge freezer help
also samsung diy video help
Posted on Oct 19, 2010
My f&p fridge freezer E240B is not chilling in the fridge part. I can't find any manuals or help on line for the product. Help please
Andy,
I am not familiar with the frig your referring to. However, MOST refrigerators get there cold from the freezer side and circulate it via a fan that's also normally inside the freezer. If you open the doors (and sometimes you may have to hold in the door switches) do you hear a fan running? If not you could have a couple things going on: 1. The fan(s) has failed. 2. The freezer Evap coil may of iced over and the fan too is frozen stopped.
Oct 11, 2013 | Refrigerators
My fridge freeze is excessively freezing in the freezer compartment and not chilling in the fridge compartment Any help would be greatly apprieciated Brian
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2011 | Microwave Ovens
Freezer is working, refrigerator is not chilled, fan runs intermittently. Frost is starting to form on the back wall of the freezer. I vacuumed the coils.
heatman101
May 18, 2011 | Refrigerators
THE FRIDGE SECTION IS FREEZING , AFTER WE HAD THE FREEZER REPAIRED
more than likey a provisions compartment fan ,(fridge compartment) symptoms include temprature stratifcation( where product freezes in lower part of refrigerator eg: crisper draws and top shelf warmer....
fan may appear to be functioning but broken wire may cause intermittent operation ..you can test these fans remove fan ...and test with square 9 volt battery or 12volt d.c supply....i hope this could be of use
ozzie fridge tech...;)
May 21, 2010 | Fisher and Paykel Active Smart E522B...
My refrigerator is not freezing properly only to the bottom of the freezer is cold the fridge part is not cold is warm
Check the circulating fan as your first target. This problem is very hard to diagnose because the fan will spin but not fast enough to circulate the chilled air through the freezer and refrigerator.
Aug 22, 2009 | Refrigerators
Hotpiont ffm90 fridge not chilling
hi if the freezer appears to work and the fridge if warm,the problem is that the freezer is over frozen and blocking the vents which send cold air into the fridge when required,and the noise is the fan hitting the the ice build up,defrost (switch off)your applinace for at least 36 hours then switch back on,you will then find after the freezer reaches -12 the fridge will then start to go cold.
Mar 09, 2009 | Hotpoint FFM90 Bottom Freezer Refrigerator
Fisher and paykel E240B refrigerator freezer has just started beeping 11 times when i open the door and is not freezing in the freezer cold enough
I called F&P customer care when my fridge did this, and apparently 11 beeps means the compressor has failed. I hope you got someone to fix your fridge! I decided to post a solution as I couldn't find one online anywhere!
Aug 18, 2008 | Refrigerators
Sub-Zero 550 - freezer unit is chilling, but not freezing
Ice maker was intermittent at best - ice was often just a shell. After two failures to correct we had the ice maker (a Whirlpool - on a Sub Zero - Go figure) replaced. Then the paddle that detects the ice level broke. Next step a new GE.
Jun 13, 2008 | Sub-Zero Bottom Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
