Question about Coleman Heating & Cooling
True air heat tries to start then goes to gas.It worked fine in the fall but it is now -5F
  • 138 Answers
Do you have a heat pump and gas furnace setup? Or is it electric and gas setup.
To me it sounds like either configuration issue its electric and gas, but if its heat pump/gas the furnace is defaulting to gas more then likely on the outside air temperature, usually most heat pumps only heat good down to 10 degrees F.
Posted on Nov 20, 2013
Problem heating up and staying heated.
the heater has went out of it or something is keeping it from trying to get it to warm up
Feb 08, 2014 | 1997 Oldsmobile Bravada
Hi: Last week, a contractor installed the above-mentioned new 16 seer heat pump, an air handler and a heat kit. Our house has 3 levels, each about 800 square fit. Initially the house would not heat above...
That is worrysome about putting refrigerant in hap hazzardly... There is a math style process involving pressures and temperatures in two locations that dictate how much ref. goes in. Anything else shows clueless installer. Too much or too little ref. will not work correctly.
Heat pumps do not work below about 33 degrees outside temp. Above that them, aux heat should not be coming on...
You would need to verify that the system you have is rated for the space that you are trying to heat...
Heat pumps heat more slowly than gas or electric, so using set back thermostat is not recommended. True economy comes from maintaining constant temprature. System has to work to hard to raise the temprature, and eats up savings in efficiency by allowing temp set back.
Feb 14, 2011 | Heating & Cooling
We have central heat and air....Heat runs off gas. The air works just fine. However, when we click it to heat nothing happens. The pilot is lit.
First thang you need to do is check to see if you are getting 24 volts to the gas valve, since the air works I am betting you are getting 24 volts to it. So that means you next need to see if the solenoid hat the 24 volts goes to has continuity. If it has no reading you need a new gas valve. I am thinking you need a new gas valve.
Dec 06, 2010 | Heating & Cooling
When I start the car the RPM goes up and down,even if the engine is warm.
Start by checking for vaccume leaks. Most of the time you can hear them under the hood with the moter running. It sounds like a sucking noise. They are rubber hose that can be found at most auto parts stores. They become brittle due to heat and crack open or even just fall of. The reason I point you toward them if your sucking air it will throw the ECM off as it tries to level out the gas air mix>>>
Oct 20, 2010 | 2001 Nissan Sentra
My gas dryer will not heat, but makes a funny buzzing type noise as if it is trying to heat/ignite. On the air dry cycle, there is no noise at all (also no heat, but that's ok). After letting it run for...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 19, 2010 | GE Profile DPSB620GCWW Gas Dryer
I HAVE A CARRIER GAS FURNACE APPROXIMATELY 10 YEARS OLD. IT WAS WORKING FINE LAST FALL. I JUST STARTED USING IT AGAIN AND NOW ITS STARTS UP AND THEN STOPS, STARTS UP AND THEN STOPS? IF I PLACE THE HEATER...
you may need to replace the thermostat or the thermostat batteries if applicable. To replace the thermostat follow the instructions on the new thermostat. Make sure to set the thermostat to the gas setting(see instructions) this should cure your problem. Good Luck on the repairs
Dave
Jan 05, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
RUUD 90 Nat Gas unit, >15 yrs old. T-stat calls for heat, nothing happens. I can place the fan in manual ON, & after a few mins. the warm air starts to circulate. If I leave the fan in auto, the...
sounds like you shorted out the heat anticipator in the tstat. try jumping red to white at the tstat wiring terminal and have a friend stand near the furnace to see if it cranks up immediately. if it does the problem is more than likely in your tstat. be sure to blow out any dust in the workings of your tstat. this is 24 volts and shouldn't hurt you but try not to short it out to the common or other wires.
Nov 24, 2009 | Heating & Cooling
Hi i have a whirpool gas dryer that all works fine but after about five minutes the heat will stop and it will just blow cool air. I can stop it and restart and everything starts and works fine and after...
The gas valve coils are closing the valve or the flame sensor is defective. The coils are the most common problem.
There are 2 on top of the gas valve. Turn off the gas and power. Remove the front panel by opening the top lid and then remove the screws from inside the front panel in the top right and left corners.
Nov 09, 2009 | Whirlpool Dryers
Gas LG dryer works fine, but heat wont stay on more than a minute. then if i try to start it again, the heat wont come on at all. if i wait a few hours, then the same things happens again. heat comes on,...
First, check to see if there is strong air flow out the house at the exterior dryer vent. It is very important to have good air flow for gas dryers. Second, if you do have good air flow and you do get ignition but the burner shuts down quickly and won't relight, the most likely cause is the coils on the gas valve. They heat up when current passes through them and can open up electrically. When they cool down, the process can repeat. The coils for LG gas valves are not available as separate parts. You have to order a complete gas valve, but you can then take the coils off the new valve and swap them out onto the original valve so you don't have to change out the entire valve. If you need instructions on how to get at the gas valve, let me know (with your model number).
Remember, check your air flow first !
Please rate this solution once you have completed your repair. Thanks.
Dec 12, 2008 | LG DLG5932W Gas Dryer
Maytag MDG16CSBWW heating problem
I have a Miele Novotronic T560C. The tumble drier is working fine except the air circulating is cold - it does not heat up at all. What could the possible reason for this and/or solution?
Oct 05, 2008 | Maytag MDG16CS Gas Commercial Dryer
Heating & Cooling Logo
56 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
