Question about Toshiba 37AV502U 37 in. LCD HDTV
Volume turns up by itself
Volume turning up while I am watching it. No one is touching the t.v. or remote.
Volume, device inpute issues
Try new battery's in the remote, and check all volume buttons, one may be stuck down.
Mar 23, 2014 | Mitsubishi WS-65511 65" Rear Projection...
Volume turns down by itself until it says VOLMIN
I have a Samsung home theater system model HT-D6730W. I have had some issues with the volume turning itself down till it says volmin. I've seen that I'm not the only one with this issue!!!! I have tried all the suggestions that were posted. Doing a hard reset, changing settings, I bought a cooling pad for laptops Hopi g those would fix it. I called Samsung support Which was a joke!!! I took the putter cover off and cleaned all the dust from the unit, removed batteries from remote, removed all cable connection on the back of the unit other than the HDMI cable going to the tv. Having done all that the unit was still turning its self down. I'm a bit of a tinker and so while the cover was off of the unit, displaying all the delicate stuff inside, I turned on the home theater system and played a movie set the volume to a good listening sound. When it started to turn it self down I remove the wide wire ribbon from the main circuit board going to the touch panel on the front of the unit. Voila!!! Sound quit going down!!!! I unplugged unit and removed front touch panel and cleaned all dust from the inside of it. Put it all back together. Tested. Still doing it. Removed the touch panel again and this time I disconnected the small wire ribbon for the volume touch buttons. Reassembled and tested. NO MORE ISSUES!!! Everything on the front still works other than the volume buttons. You can still change the volume using the remote!!!! I hope this finds everybody that is having this issue with there unit.
Feb 14, 2014 | Samsung Audio Players & Recorders
I have a Mitsubishi 73"
i would suspect your control buttons on your front panel on the set have become shorted. specifically the volume buttom down. This is freezing you control functions. like someone is holding the volume down button all the time. or intermitantly. this cuircit board is on front of the set. I have seen this problem a few times at the shop. The common repair is to replace that button assembly cuircit board. I believe the last time it cost the customer around 85 dollars, but like all things depends on the part and the technician that puts it in.
Apr 21, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
We are watching tv and the volume just turns itself all the way up. If we turn it down, it goes right back up. It stays like that for about 15 min at a time and then it will allow me to turn it down until...
check the remote control, take the batteries out and try to adjust the volume on the tv set itself.
If this resolves the problem the button on the remote may be sticking, either clear it or get a universal remote.
If you still have the problem without the remote then its time to take the tv to a repair shop or claim on a warranty.
Mar 15, 2011 | Televison & Video
Volume goes all the way up by itself
1. The volume up button on the remote may be stuck down- try wiggling the button to get it out. If it isn't the remote if the local volume control is in fact two buttons perhaps that one is stuck in or damaged.
2. The dvd sounds like it needs a new laser unit- a worn laser unit may play up like this.
It might be time for a new one as replacement can be sometimes more than the cost of a new one nowdays!
Jan 17, 2010 | LG LFD7150 Shelf System
The volume is turning itself down all by itself. The volume on the remote won't work, but the remote is fine with the other TV controls.
It sounds like the button is stuck. Take the remote apart if you can and see if the key is stuck somewhere. This happened to me once with a rubber key type of remote. It drove me crazy.
May 10, 2009 | Sansui HDLCD3210 32 in. LCD TV
Amplifier goes from low volume to high volume without touching any controls. I turn it down only to have it mysteriously go up again 5 minutes later. Warranty ran out one week ago...
Let's eliminate ghosts and goblins. I can't identify your unit. Give me a make and model number.
As a test, locate the remote control window on the front of the unit, if it has one. Set it up to watch or listen to something then cover the remote window on the unit with a small piecr of cardboard. If you can't locate its infrared receiver for the remote just cover the entire front of the unit with something sufficiently opaque to block your remote. Try to operate it with th remote to be sure the unit can't see it.
If the expected problem never comes back you have a stray signal from something else in the environment getting interpreted as a 'volume up' command. Then look around for other remotes being used, wireless devices, use your imagination. I used to have a remote-controlled space heater and my TV would sometimes shut off if I used the remote. Does the unit have line-of-sight to a nearby house? Maybe something next door (garage opener?) is interfering.
If it still happens and there are no other infra-red devices nearby you have a ghost.
Apr 27, 2009 | Audio Players & Recorders
Volume increases on its own intermittently
When the volume increased did the display show it doing so as if someone was turning the knob?  I mean did the volume go from like level 15 to 30 or did the unit's level stay constant while the audio volume increased?
Were you alone or sharing the room with a jokester who has a universal remote?
Does this problem occur when the batteries are removed from your remote?
Are you sure the 'volume up' button on the unit itself is disengaging properly after being pressed?
Dec 18, 2008 | RCA RT2760 System
Volume decreases by itself
maybe defective speaker or audio output ic or shorted capacitor within audio circuit
Nov 09, 2008 | RCA F32648 32" TV
RCA tv doing various things by itself
haunted house. contact an exorcist
Jul 13, 2008 | Televison & Video
Toshiba 37AV502U 37 in. LCD HDTV Logo
21 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
