Question about Ricoh Aficio GX3050N Printer
Error code 999 GX5050N - Ricoh Aficio GX3050N Printer
I have a Ricoh Aficio GX5050N and I have cleaned out the waste ink tank but cannot reset the counter. the INK CU replace command does not appear to work.
cleaned tank ,reinstalled, same? read for hours?? , powered on printer with ink cu out slightly,ink cart door open, the prompts came up to replace the cu, then do you want to reset counter, hit enter, closed ink cart door, done ! ,, whewww !
hrdchgr69@aol.com
Sep 15, 2011 | Ricoh Aficio GX5050N Printer
Error 990 keeps blinking on machine
This is an error that has to do with the ink drying up on the maintenance unit. This cannot be fixed by the end user and must be fixed by Ricoh. Error 990 is a Ricoh defect in which the printer should qualify for replacement.
Feb 12, 2010 | Ricoh Aficio GX5050N Printer
Ricoh Aficio GX3050 Gel sprinter - error999
BULLETIN NUMBER: J001/J003/J006/J007/J010/J011 – 021 07/02/2008
APPLICABLE MODEL:
GESTETNER – GX3000/GX3050n/GX5050n
LANIER – GX3000/GX3050n/GX5050n
RICOH – GX3000/GX3050n/GX5050n
SAVIN – GX3000/GX3050n/GX5050n
SUBJECT: SC999 OCCURS
SYMPTOM:
An SC999 (Maintenance Stepper Motor Home Position Error) occurs.
CAUSE:
Some of the ink in the machine has dried, and as a result the maintenance stopper motor cannot rotate or
the levers come loose.
NOTE: The following conditions make it easy for the ink to dry up (See Appendix 3 for more details):
- Low humidity
- Long intervals between machine usage
- Total period of usage is long
- Low Print Volume
 COPY QUALITY
Fixed ink Stepper Motor
Right Flushing Gate
Levers
Tech Service Bulletin No. J001/J003/J006/J007/J010/J011 – 021
Page 2 of 5
SOLUTION:
Production Countermeasure:
The shapes of some parts in the Maintenance Unit have been changed in two steps ("Step 1" and "Step 2"
below).
NOTE:
See Appendix 1 for the details of the Step 1 and Step 2 modifications.
See Appendix 2 for the visual differences among the unmodified unit, the Step 1-modified unit, and
Step 2-modified unit.
See UNITS AFFECTED for the Serial Number cut-in of Steps 1 and 2.
Field Countermeasure:
1. Cycle power OFF/ON.
2. Install one of the modified Maintenance Units ("Step 1" or "Step 2").
NOTE: For customers experiencing a SC999, have them contact 1-800 Ricoh38 for replacement.
Feb 02, 2010 | Ricoh Aficio GX3050 GelSprinter
Cs 999 code im ny ricoh aficio ap3800c how i fix that? thanks ,some one play with it know wen i turn the switch on this is what i get cs 999
This is a firmware error code. You are going to need a service tech to reload the firmware. Make sure they use the latest version with any and all updates included.
Dec 19, 2009 | Office Equipment & Supplies
Ricoh GX5050N banding
it can be due to the fusing temperature not being right.try to change the paper type to a heavier paper type to increase the fusing temp.
May 22, 2009 | Ricoh Office Equipment & Supplies
Unable to process request at this time -- error 999.
Error 999 on Yahoo! products is an error to say that, well, there is an error! This error code, Error 999, does not stand for any specific error and is more or less a code for any Yahoo! error.
However, this message is generally shown for when Yahoo! limits the bandwidth usage of a person on Yahoo! software for some reason.
This message can be shown when many things are pressed or done through Yahoo! software, as a way to prevent misuse and abuse.
The easiest way to solve this issue is to wait some time and try again later. This should be only a temporary error message, and things should be back to normal after some time.
Jan 23, 2009 | Yahoo Messenger
Hello, we're getting an error code of 990 on a GX5050n inkjet printer. The printer is fairly new with only a dozen or so printouts. Thanks.
make sure printer is off. Then old down escape and online button at the same time. Continue to hold these two buttons down then turn on printer. Continue to hold those two buttons down (will take about 2 - 3 minutes). This should clear that message - worked for me!!!
Aug 07, 2008 | Ricoh Aficio GX3050N Printer
Ricoh Aficio GX3050N Printer Logo
32 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
