Question about Apple iPhone Smartphone
I phone been dead for over 12 hours now left on the charger, for 2 hours and still no luck. i have tried pressing the power at the the top right and the button at the centre of the phone, aand still no bloody luck... please please can anybody help
  • Apple Master
  • 2,072 Answers
Try charging from a wall charger versus plugged into a computer if you havent. Also try removing the battery and reseating it, lastly Hold down the power button for about 20 seconds, this should hard reset the phone/tablet.
Posted on Nov 18, 2013
deepbal
  • 91 Answers
SOURCE: Hey whats the button on the top left of the phone
The slider which is next to the volume button is ringing mode or ******** mode.
If the phones dead try charging it completely and try. If that doesnt work, then do a reset on the phone which will work.
Posted on Jan 06, 2010
SOURCE: My iphone's home button hasn't worked for a week
I do not recommend taking the iPhone apart yourself I've personally seen where my clients have done exactly that and broken the charge port or cracked the glass or ripped one of the ribbon connectors. If the home button is not responding you should have a technician look at it.
With that said...
If you absolutely cannot hire a technician...
There are two screws on the bottom of the phone once these are removed the screen assembly can be lifted slowly up from the bottom first - Please do not use a screwdriver to pry it up a suction cup will do the trick (the kind that holds a GPS to the windshield of your car should work). Once you have lifted the screen assembly look underneath toward the top right there are 3 ribbon connectors you can use your fingernail to pry up the connectors freeing the ribbon !-be gentle as these are fragile-! Your home bottom and it connector are located at the bottom of that screen assembly. You will see 2 gold connectors extending from the bottom of the screen. Be gentle with those they break EASY check where they make contact with the board are the contacts clean?
Is the button depressing(does it feel like a click?)?
--It may be that the small round metal piece that helps the button to depress has moved out of place and the button is no longer making contact.
Beyond this you will need a new button assembly which is quite tricky to replace since it is fused inside with the glass.
???!-Maybe time for a pro!???
IF YOU FOUND MY SOLUTION HELPFUL PLEASE VOTE 4 THUMBS UP.
(any less hurts our averages)
Thank you and Good Luck!
Posted on Feb 09, 2010
  • 846 Answers
SOURCE: My 3GS is totally, 100% dead.
Try a different charger and to hard reset the iPhone (menu and on/off together for 5sec). If that fails too there is a hardware issue. Apple should give you a replacement. If you're out warranty, you can try to open it and replace dock connector. If that fails you need a new logic board. You can get the part at iPad Repair and there is a guide that shows you how to open a kindle and install parts at iPad Repair Guide.
Posted on Jun 09, 2010
  • 502 Answers
SOURCE: Hi my iPhone 3GS is dead. I have tried everything
Sounds' like your battery is defective. Bring it to the apple store. If they want to charge you for a replacement phone, try to replace the battery yourself, part is on ebay and there is a guide that shows you how at : iPhone 3GS Repair Guide
Posted on Jun 30, 2010
  • 502 Answers
It probably just a defective battery. Bring it to the apple store to see if you get a replacement through them. If you can't, there are third party iPhone repair services, that will fixed it for cheap. Also, I found an DYI iphone repair guide, so you can do it yourself too, not that difficult.
Posted on Jul 11, 2010
My kindle won t turn on
Her is a possible solution:
1. Plug into the original charger, hold the power down for a full 30 seconds, release. Let charge in this state for 12 hours.
2. Lease the device plugged into the charger, while you have the device plugged into power, press the power button for a full 40 seconds, release. Wait for 5 seconds and then press and release the power button. Did the device wake up? No, continue to step 3.
3. Plug the device into another charger, if you do not have an charger from another phone go to Staples or Radio Shack pick up a new Kindle or Universal charger, make sure you can return the charger.
4. Plug the Kindle into the new or alternate charger. Hold down the power button for 30 seconds release. Let charge for 12 full hours.
5. Unplug the Kindle from the charger.
6. Press the power button for 40 seconds - time it. Release the power button, wait for 5 seconds, then press and release the power button. The Kindle should wake up. If not, proceed to step 7.
7. If you can not wake up the Kindle from a 'hard reset' the Contact Amazon directly for a replacement.
May 25, 2013 | Amazon Kindle Fire HD
Kindle does not charge properly
Let's try to reset the charger system.
Step 1: Unplug from the charger, press and hold the Power button for 30 seconds
Step 2: Plug into the charger. Press and hold the power button for 30 seconds
Step 3: Let charge for 12 hours
Step 4: Unplug form the Charger, run the Kindle until totally dead.
Step 5: When DEAD. Press and hold the power button for 60 seconds.
Step 6: Plug into the charger, let charge normally
If this does not reset the charging system you have either a faulty Kindle or a faulty charger, contact Amazon for replacement.
Apr 01, 2013 | Amazon Kindle Fire HD
Nokia 3110 is dead aftr succesful updation msg..i updated it using ovi suite..aftr succesful updation msg,when i tried to open ovi suite again it displayed software updater is running.i kept mobile...
Updating via PC suit/ Ovi suit is very dangerous ...here phoenix is the best 100% working ,Don't you want to try ?
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 3110c file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment. thanks for visiting fixya. Good luck.
Aug 14, 2011 | Nokia 3110 Cellular Phone
My scooter battery won't charge. Felt mild shock or short when attempted to insert connector. That seemed to disable the charger because the charger powers on, but will not run the charge to the...
Make sure that the charger is fully connected to the scooter; ususally the controller lights will go slowly left to right to indicate it is charging. Make sure the charger is plugged directly into the grounded wall outlet, not into an extension cord or power bar. If the charger is not being recognized by the scooter, you may need to replace the charger, or at least the power cord to the charger.
If your scooter has been sitting unused for a while? If so, the batteries might not charge anymore and will need to be replaced. Contact the manufacturer for a service call or troubleshooting over the phone.
Nov 04, 2010 | Pride Mobility Products Go-Go Elite...
How to adjust the time on a CASIO W-59 watch
Hi Harry,
Your Module number is 2271.
1. To set the time, press and hold button A (left top) until Seconds digits start to flash.
2. Press button D (lower left) to move flashing in the following sequence to change other setting:
Seconds >> Hour >> Minutes >> 12/24 Hour Format >> Year >> Month >> Day >> (Then back to Seconds)
3. While a setting is flashing, use E (+) (bottom right) and B (-) (top right) to change it.
Note: When in the 12/24 Hour Mode, use E and B to toggle between 12-Hour and 24-Hour Mode.
4. Press buton A to exit setting screen.
Your time should now be set.
You may also download a manual for watch/Module number:
http://pathfinder.casio.com/resource/manuals/module_2271.pdf
This should give you all the info you need to operate all the functions of your watch. Thanks.
Regards, Bill
Sep 27, 2010 | Watches
When I plug the 12 volt charger in the lighter the green light goes on. When I plug the Maestro 4040 into the charger the green light goes off and the unit won't power up. I checked the power port and I am...
hey mousehunter, you say you have continuity, did you mean voltage..looking at your 4040 with the back off and screen face down (you probably know this already..sorry if you do) the power port should be on the lower left corner...open it back up and the contact at the top left is a ground as is the lower left corner, the lower right is a ground and the top right is the poss.....this is very common for these ports to fail
Does it look like the port has been replaced, or do you know if it was...normally this happens because of excessive heat from trying to solder a new port on it.
1st i would try a home charger to rule out the charger. (you can check if its working by going in the power options and looking at the power meter and see if its moving, assuming you can still turn it on)
if its totally dead, try this...remove the cover again and disconnect the battery, then press and hold the power button for 1 minute....with the battery unplugged, plug in a known good charger and press and hold the power button for up to ten seconds and see if it starts.
let me know what you find.
bill
Aug 16, 2010 | Magellan Maestro 4040 GPS Receiver
How do I change my Casio twin sensor alti thermo watch from 24 hour to 12 hour format?
Press and hold the top left button for 2 seconds to go into the time adjustment mode.
While you are in this mode press the top right button to switch between 12 hour and 24 hour modes.
Press top left to return to normal.
Oct 09, 2009 | Casio Watches
Setting instruction for Accurist world time wrist watch
Same just happened to me, performthe following:
The analogue hands are not precisely synchronised with
the digital time?
1. Press the lower right button to move the mode indicator
hand to CHR.
2. Pull the lower right button out one click. The hour, minute
and UTC hands will retract towards the straight up 12 O’clock
position. You will see UTC on the top half of the digital display.
3. Press the upper right button to advance the hands to the
straight up 24-hour position. Use the lower left button to go in
reverse.
4. Press the upper left button. You will see HR on the top half
of the digital display. Press the upper right button to advance
the hour and 24-hour hand clockwise until they both point
straight up at the 24-hour position. Use the lower left button to
move the hand anti-clockwise.
5. Press the upper left button. You will see MIN on the top half
the minute hand clockwise or the lower left button to move
anti-clockwise until it is pointing straight up at the 12 O’clock
position.
6. Push the lower right button back in one click.
The watch malfunctions in some way and the above
procedures do not work.
1. Press the lower right button until the mode indicator hand
points to TME.
2. Pull the lower right button out one click. Press the other
three buttons down simultaneously for three seconds and
release. You will see 8’s on the digital display.
3. Press the upper left button. You will see UTC on the top half
the hands of the top dial to the straight up 24-hour position.
Use the lower left button to go in reverse.
position.
Jul 06, 2008 | Watches
Timex Mid Size Sports 1440 WR50M
If your set up is: Top-Left=Indiglo Top-Right=St./Stop Bottom-Left=Mode Bottom-Right=Lap/Reset
Than follow these steps:
1. Press Lap/Reset and hold. You should see the time the alarm was set for.
2. While holding Lap/Reset, press Mode.
3. Let go of all buttons.
4. There you go!
Hope that was a help
Mar 11, 2008 | Timex 1440 Nylon watch
24 hour-12 hour time
Press Set - hold (top Left button) -When the sec start flashing go to the bottom left button press it 3 times -When the hour flashes press the bottom right button 1 time -Press the top left 1 once with
Jul 05, 2007 | Timex Fashion Classics 78587 Wrist Watch
Apple iPhone Smartphone Logo
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
