Question about General Electric GHDA485NCS Built-in Dishwasher
Timer Control Assy
Purchased model 5 yrs. ago It's now out of production! Is there an alternative controller that will fit my m/c
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 24 Answers
Call apd it's in California it appliance parts distributor
Posted on Mar 28, 2014
My Crosley oven has a new element and timer and still will not heat up
It sounds like you need to replace the burner receptacle, in either the broiler or the bottom oven burner( heating element) or both. When it exploded it burned the contacts in the heating element.
Apr 11, 2014 | Ovens
Maytag washer MAH4000AWW timer will not advance. Washer will operate if I manually advance timer. Have changed timer, followed Drive System diagnostic test, the wax motor and control board were replaced a...
there is a motor inside the timer that turns the knob. the problem must be the replacement timer. was it a brand new timer from maytag or a 2nd hand? also double check your timer is connected correctly.
Nov 08, 2013 | Maytag Washing Machines
Have a intermatic t10004r pool controller box. pool light not working. box is only 1.5 yrs. old only used light 4 times all brand new 1.5 yrs ago
T10004R comes supplied with one 240Volt T104M timer mechanism.
T104 mechanism can be tested to see where problem is located.
Open following link for troubleshoot checklist to see where problem is located.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Recommend standing on dry surface and using same precautions when working inside circuit breaker box.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 03, 2011 | Intermatic T10004R - Pool-Spa Mechanical...
I have a renault espace I fitted a new alternator appx 5 yrs ago it has now stopped charging could it be an alternator relay problem or do I need a new alternator?
5 years is alot of miles ago... it's possibly bad. If you have a voltmeter you can verify. With car running, connect voltmeter to battery and it should read between 13.1 volts - 15.8 volts. Anything lower, alternator is bad. Also have your battery "load tested", it can give similar symptoms.
Mar 08, 2011 | 1990 Geo Prizm
This is the third Temp Control Assy replaced in 8 yrs
check gas pressure if too low it will run hot and soot up clean out exchange of soot should be ok
May 12, 2010 | Jandy Laars Lite 2 Pool Heater 250,000 BTU...
Dryer timer knob
This control could be the problem IF the blower wheel ain't stripped, the dryer is clean, and the duct work is free of air restrictions.It is located on the blower housing next to the fuse.ec8cbee.jpg
Mar 18, 2010 | Maytag PYE2300AY Electric Dryer
Sears Kenmore Elite Oven 790.99123405 Caught Fire!!!
The PF indicates a power failure.
The range experienced a loss of electrical power.
This code is usually cleared by pressing the CLEAR/OFF button.
If you continue to get this code, you may need to unplug the range and check the wiring connections of the power cord on the back of the range.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 12, 2009 | Kenmore 99123 Electric Kitchen Range
Control Panel has given out (ACS3350AS)
See the solution I posted here:
http://www.fixya.com/support/t519198-amana_acs3350as_never_buy_amana
Jan 02, 2009 | Amana ACS3350AS Gas Kitchen Range
Washer problems
Mardokenly, start with the door lock assy. It looks like power has to go through the wax motor assy (door lock)then the light before getting to the main control board. With the power off and harness removed from the door lock mechanism it should ohm out at 950 to 1100 ohms at room temp. If this passes the test another area to look would be the timer and control board. If the control board does not see a change in timer inputs after 5 minutes of power to it, it will shut the washer off. Things to check would be loose connections at the timer and control board. They have had a lot of service bullitins and service flashes out on this model. One of which has to do with the loss of the nuetral line from the power cord to the control board. When this happens, of course the washer will shut off. You may want to call Maytag and see if you are covered under these service bullitins. Catriver..post back.
Feb 19, 2007 | Maytag Neptune MLE2000A Front Load Stacked...
General Electric GHDA485NCS Built-in Dishwasher Logo
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
