Question about Intimus Simplex se Shredder
Gears worn out and jumping the teeth - Intimus Simplex se Shredder
  • 189 Answers
Intimus is a German company but you can reach them in the US at:
http://www.intimus.us/
Posted on Dec 10, 2013
Can any one help me with advice on how to repair the 5th gear on my Chana 1300 Club Star? Greetings, Johan.
Replace the selector and check adjustment. Only replace the gearing if teeth are badly worn as that alone will not cause it to jump out of gear.
Aug 08, 2017 | Cars & Trucks
Hi my proton savvy 2007 model keeps jumping out of first gear only when I go to take off. What would be causing the problem.
the synchro dog is not staying engaged for several reasons
worn teeth on the dog, , worn inlet shaft bearings , gear not going fully into gear from incorrect selector adjustment
Apr 24, 2017 | Proton Cars & Trucks
First gear engages but slips out when try to take off
the gear teeth are prob worn. see if it will try to moves off in 3rd without jumping out of gear if so then its not the lever/linkage it is the gear teeth inside the gearbox and needs to be repaired or replaced
Feb 04, 2017 | Cars & Trucks
On a slight ascent the gear lever jumps out of the 5th gear.
There is quite a long list of possible reasons and most of them require gearbox removal to fix.
Weak or broken selector detents, weak or broken synchrohub detents, loose, worn or maladjusted selector fork or mechanism. excessive endfloat in a shaft, gear or hub.
Worn synchrohub teeth is a very common cause.
It would be worth checking the external linkage for possible fouling or maladjustment first.
Apr 28, 2016 | Cars & Trucks
What causes Toyota Land cruiser gears to jump out of gear when driving
Usually worn parts in the gearbox, called 'detents'. These normally hold the gear engaged. Try holding it in gear with the lever. If that does not work then the wear may be further in, on the shaft spacers and gear teeth themselves. You may be able to get a reconditioned gearbox, depending on where you are.
Another cause mentioned by owners is worn engine mounts, so check those too.
Mar 22, 2016 | Toyota Cars & Trucks
My van keeps jumping out of gear what is the problem
most likely a manual gear box is it
jumping out of gear indicates the the gear is
not properly engaged --adjust linkages
check gear lever for obstructions in mounted on the tunnel
loose /incorrectly tensionedd bell housing bolts
failed rear engine mounts
drive line vibrations
or possible badly worn gear teeth
jumping out of gear is when the mating gears are not exactly in line and the slight angle makes one gear walk out of mesh with the other.
Sep 06, 2015 | 1994 Dodge Caravan
Knocking noise of chain in honda dream yuga bike when accelerating after shifting the gears. i have tightened the chain but still it happens.
That knocking noise could be that the teeth on your main drive are worn out and chain is jumping them on acceleration.Pull th primary cover and check the drive gear for chain on motor sprocket.Replace it if worn to that point.
Oct 02, 2013 | Honda Motorcycles
The chain jumped the gears. I opened the case and it looked pretty clean. the chain appeared stretched. I bought another chain and installed. It lasted about 3 weeks and it stretched agian and jumped the...
u may need 2 replace the timing gears as well old gears may have worn teeth.i had same prblem with a chev mtr fitted a chain&gear set fixed it right up. ps make sure u use a new chain
Sep 10, 2011 | GMC Denali Cars & Trucks
My mercedes atego jumped out of gear at about 50mph i was unable to select any gears but when i let the clutch back up and gear stick in neutral position it appears to still be in fourth gear when...
SHIFT LINKAGE WORN OR DAMAGED.BROKEN OR LOOSE INPUT GEAR BEARING RETAINER, COULD HAVE DAMAGED OR WORN CHECK BALLS FORK ROD BALL GROOVES OR CHECK SPRINGS, WORN MAINSHAFT OR COUNTERSHAFT BEARINGS,WORN SYNCHRONIZERS OR CHIPPED OR WORN GEAR TEETH. MANY THINGS WILL CAUSE MANUAL TRANSMISSION TO JUMP OUT OF GEAR.
Jul 21, 2011 | Mercedes-Benz Sprinter Cars & Trucks
Gearbox continually jumping out of gear.
If this is a Manual transmission and if you push hard and a shifter it still pops out your shifter may be out of adjustment. The other possibility is the synchro teeth on the gear are in a slider rings are worn in the transmission needs to be rebuilt. Good luck.
Jun 04, 2010 | 2000 Toyota Land Cruiser
Intimus Simplex se Shredder Logo
Top Intimus Office Equipment & Supplies Experts
ray gallant
Lonnie Arks
Tom Chichester
Are you an Intimus Office Equipment and Supply Expert? Answer questions, earn points and help others
