Question about Datamax DMX E4203 Printer
My labels are really faded,have changed ink but is the same
When typing the print is faded
Dymo LetraTAGs are thermal printers, so they don't use ink - just batteries and LetraTAG tapes.
When the print starts to fade it's time to put new batteries in. When the batteries are running out the text fades first even when the motor is still feeding tape.
Jan 31, 2011 | Dymo LetraTAG Thermal Label Printer
I don't know if mine is thermal or not. But, I need ink and don't know where to replace it
Dymo Letratags are thermal printers, so they don't use ink - just batteries and LetraTAG tapes.
When the batteries are running out the text fades first even when the motor is still feeding tape, so change the batteries!
Jan 28, 2011 | Dymo LetraTAG Thermal Label Printer
I RAN OUT OF INK
There is no ink. If the text is fading change the batteries - really! It works every time.
Jan 25, 2011 | Dymo LetraTag QX50 Thermal Label Printer
The ink seems to be fading, but there is no ink, so what the solution?
There is no ink, toner, drum, ribbon or anything else. The labelwriter uses a fixed thermal printhead to print onto heat sensitive labels. This problem on the handheld labellers is almost always an early indication of low batteries.
But this labeller is only powered by the mains, so isn't the problem here. Assuming you using genuine labels then the only likely explanation is that the printhead needs cleaning.
If the 'fading' is happening unevenly across the label then this is probably the likely problem so you need one of these:
Dymo Cleaing Card
If it's not that then it's most likely a hardware fault of some kind, either with the printhead or the power supply. There's not really a lot that can go wrong with these machines...
Mar 29, 2010 | Dymo LabelWriter 400 Turbo Thermal Printer
Tried to label a disc
a light scribe disc? you actually need the ones that are for printing the label. if you want to  use lightscibe get a light scibe disk drive.
Jul 01, 2009 | Epson Stylus C86 InkJet Printer
PIXMA iP90, all the pictures come out really faded..new ink,
I've cleaned it every which way..but still all the pictures print out really realled faded with slight lines horizontally runnung across.
Mar 01, 2009 | Canon PIXMA iP90 Mobile Printer
Ink Problem
They don't use ink, they're thermal printers. If the print is fading change the batteries...
Feb 02, 2009 | Dymo LetraTag QX50 Thermal Label Printer
Ink is fading on my qx50
Dymo Labellers don't use ink, they are thermal printers. When the print fades it usually means the batteries are running out.
Jan 24, 2009 | Dymo LetraTag QX50 Thermal Label Printer
Printing fade at the midle of the page
Build up on the printhead, printhead pressure, or worn platen roller...
Apr 26, 2007 | Zebra Stripe S600 Thermal Label Printer
Datamax DMX E4203 Printer Logo
19 people viewed this question
Top Datamax Office Equipment & Supplies Experts
pkwc
Greg Cann
Greg Cann
Kevin Brown
Level 1 Expert
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
