You need to get an external dvd drive, then either the recovery disk that came with your computer (you may have had to make it), or you need a copy of Windows that is the same version as the one installed on your computer from the factory (look at the Certificate of Authenticity on the bottom of laptop or under the battery). Turn on the computer, then tap the F11 key until you get the "boot menu". Insert your disk into the DVD drive, and select USB DVD drive from the boot menu... follow the installation instructions from there.
Testimonial: "Thanks - I do not have an external dvd drive but can pick one up. The "pins" on the new SATA hard drive do not seem to correspond to the pins in the netbook. Is this a problem?"
