Question about Danze D403412 Melrose Single Handle Kitchen Faucet with Spray - Chrome...
Low pressure on hot water side of single handed Danze kitchen faucet
The hot water side of my kitchen faucet suddenly lost pressure. The cold water side is normal. I have taken out the cartridge and tested the pressure. Hot water flow is low, cold flow is normal. Any ideas? Gary
landsend
  • 1066 Answers
SOURCE: i have a single handle kitchen faucet that now has no cold water
You need to install a new cartridge in the faucet.  The cartridge controls everything.
Posted on Mar 09, 2009
  • 92 Answers
SOURCE: Moen Kingsley roman tub- no/slow hot water flow
sounds like you may have a little debri on hot side stem or kinked hose between valve and spout turn off water to house remove handle pull bonnet and remove stem turn water back on with stem removed see how water flow is be careful turning water on you could make a mess i am assuming the low pressure is in shower only
Posted on Apr 16, 2009
frcs68
  • 1605 Answers
SOURCE: Water flow is too powerful..
I got you, you want a screen to be put on the spout!
check the inside of the spout. there may be a internal thread, if it is, then you can get a external thread screen from home depot.
Posted on Apr 22, 2009
manhandy
  • 146 Answers
SOURCE: Danze pressure balance single handle shower faucet
it the valve is full of dirt or needs to replaced not all the time but i have fix many buy just cleaning it out or pipes are fasten down. try just cleaning.
Posted on Jun 26, 2009
  • 127 Answers
SOURCE: danze kitchen faucet spout difficult to move from
o-rings in the spout need to be greased or replaced...use silicon grease if you are greasing them....not petroleum based product.
Posted on Oct 18, 2009
Poor hot water pressure form Delta single lever faucet
it can be adjust take handle off and remove locking collar first turn water off,
it has a metal or plastic ball with a shaft for the handle it may have spun or a washer may be bad under it,
you can get a replacement at lowes or Home depot to replace it if this is the problem .
Apr 25, 2010 | Delta Model 172: Waterfall Single Handle...
Pressure surging thru Delta single handle faucet. The water flow starts and stops suddenly when the faucet is more than half way on. Same for hot and cold.
I don't know if this is your problem or not, But I had a new faucet and it did the same thing. I found little tiny pieces of polishing media stuck in side the faucet. Every time you turn on the water it comes out fast , then trickles, drove me nuts, I took it back and got another, no problem, hope this helps.
Apr 21, 2010 | Delta 2402 Classic Single Handle Kitchen...
Faucet is leaking from the cold water line inside the faucet. it is a danze lazio pull out kitchen faucet
Hello
First shut off water to faucet.There should be a allen screw that holds the faucet together near the top back of the handle,lossen this and pull top off.
Next take some pliers and tighten down the lock nuts to compress the washers,do this gently.
Reassemble,water should stop leaking.
Mar 30, 2010 | Danze D403412 Melrose Single Handle...
Moen single handle kitchen faucet, Hot water and
Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
Dec 29, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Low hot water pressure in kitchen faucet
I have moen kitchen faucet # 7560 and water pressure very low. What should I do? We check water flow in pipe it is ok. I changed cartridge as well as pipe nothing help. Please let me know. thanks
Oct 14, 2009 | Moen & Replacement Cartridge
The hot water side has low water pressure. The
start by making sure the valve that supplies hot water to the sink and dish washer is fully open. If there is low hot water pressure in any of the other kitchen/bathrooms, then trace the line to see where the pressure drops. If it is only in the kitchen, it should be an old valve, (causes restriction)Good Luck.
Oct 10, 2009 | Whitehaus Kitchen Single Handle Faucet...
I have a single handle kitchen faucet that now has no cold water
Mar 09, 2009 | Danze D403412 Melrose Single Handle...
Leaking single lever kitchen tap
on most of the single handle faucets there is an erasure like button ( may have a hot and cold blue and red indicator or be silver ) usually located right under the faucet arm on the manifold chrome sleeve or back behind the arm or it could have a large ring nut over the doam of the lever take your hand and feel the area that covers the area where the spout arm swivels and feel for the button or take your fingers and fel the to of the lever doam
if you find the button just take a sharp screw driver( be sure to plug the drain holes and turn hot and cold water off under sink) pry the button off and use a hex wrench and loosten
if no button then there has to be a large nut on top you may seee two grooves oppsoite each other wheich would mean a special tool
use an adjustable wrench (put cloth ofer chrome to protect and turn counter clock wise( the ring nut will not be very thick
after removing you should be able to replace the cartridge
good luck
Dec 30, 2008 | Danze D403412 Melrose Single Handle...
Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Dec 04, 2008 | Price Pfister Marielle Kitchen Faucet with...
Low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
Nov 14, 2008 | Delta Faucet Plumbing
Danze D403412 Melrose Single Handle Kitchen Faucet with Spray - Chrome... Logo
35 people viewed this question
Top Danze Plumbing Experts
john h
Andrew Bugbee
Are you a Danze Plumbing Expert? Answer questions, earn points and help others
