Question about Bosch Cooktops
Bosch Gas Hob PCL785 No Ignition on any burners.
I suspect the Ignition Transformer has failed as there is no clicking although the gas burners can be ignited using naked flame
Gas hob keeps sparking all the time
check the ignition button or its wiring, the button may be broken and 'on' all the time, or the wires underneath broken off and shorted together.
Jan 18, 2011 | Rangemaster Professional 4 Burner Hob 23...
Electric ignition to hob seems to be jammed
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 31, 2010 | Cooktops
Gas hob sparks when off
heatman101
Feb 15, 2010 | Baumatic 20 in. BWK1 Gas Cooktop
Gas hob is permanently igniting
hi gud day,try to clean the area of knobs by using vacium,remove all the knobs firts then clean it,unplug the unit before u clean.
tnx gerbee
May 19, 2009 | De Dietrich DTG775X Gas Hob 22 in. Cooktop
Creda gas hob now keeps ignighting
the ignitors have got wet usually due to cleaning. they are usually located under the rotating switches just let them dry out ( very well .....may take days) and it will work normally again
Dec 23, 2008 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Stuck auto ignition
try easing each knob upwards a bit.
Jul 15, 2008 | Smeg 23 in. SE64 Gas Cooktop
Baumatic B40 Gas Hob : Gas not staying on.
we have the same problem... try removing the knob, ours works fine without the knobs ????
Dec 19, 2007 | Baumatic 24 in. B40 Gas Cooktop
AEG 5 burner gas hob
there is a bypass screw on each gas valve. adjust so flame is reasonable when each burner is turned to low
Jun 15, 2007 | AEG 34942G-M Gas Cooktop
Constant ignition clicking
try easing the knobs up slightly, they are just a push fit
Apr 21, 2007 | Neff 28 in. T2764 Gas Cooktop
Cooktops Logo
27 people viewed this question
Top Bosch Cooktops Experts
paulcarew
Jay Finke
Jay Finke
steve morris
steve morris
Are you a Bosch Cooktop Expert? Answer questions, earn points and help others
