Question about Exercise & Fitness
Pacemaster Pro II goes up but not down
Everything else works fine, but the elevation only goes up and does not work to go down
    Top Expert:
  • 12,223 Answers
Please RUN the software calibration for easy diagnostic, Read you owner manual and follow the steps and fix it. Or download from www.fitness.manualsonline.com
God bless you
Posted on Nov 19, 2013
4 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: Getting a dead sensor reading on pacemaster pro plus treadmill
OPEN MOTOR SHROUD INSPECT THE COMPARTMENT ON THIS INSTANT I BELIEVE THAT THE SENSOR IS AT THE OPPOSITE END OF THE MOTOR THE LEADS GO INTO MOTOR CONTROL BOARD I WOULD FIRST UNPLUG AND PLUG THE CONNECTOR THIS WOULD CLEAN ANY OXIDATION OFF. IF NOT YOU SHOULD BE ABLE TO DO THE REPAIR
Posted on Mar 02, 2010
  • 9 Answers
SOURCE: I have a vision fitness T9450 treadmill. My wife
first thing to do is to enter the calibration mode. First remove and replace the safety key. Press and hold the elevation up and the speed down buttons until the machines beeps at you 3 times consecutively. You should also see either the model "9450" or the software code which varies from machine to machine. You should now see one of two things - "eng1" may be displayed in which case just use the elevation keys to get to "eng4" and hold enter for 3 seconds - then press start - this will calibrate your machine and confirm if there is any speed reading issues.
If your machine displays more numbers as it would on the deluxe and premier consoles of this brand then you should see the model of your treadmill at the top left. hold enter from here until "eng1" appears and the perform the steps as above. If the speed is not calculating properly during the calibration the magnet or the speed sensor may have been moved or the magnet could have gone bad - usually slowing to one speed and not changing is the sign of a bad speed sensor. If the control board had any irregular voltage it would shut down as a safety precaution.
Posted on Aug 05, 2010
  • 1796 Answers
SOURCE: Where is the elevation fuse on a Pacemaster Gold
Hi!!
On page 6 of your owner's manual, step 3 shows a diagram to remove the shipping bolts. On that diagram, you can see the motor and the power cord wrapped around it.
Click on the following link to get a copy of your owner's manual on .pdf format, scroll to page six and magnify it to 400%, you should be able to see the blue circuit board and two white fuses. Make sure your Pacemaster is disconnected before working on the fuses.
http://www.pacemaster.com/manualPDF/PremiereGoldEliteFoldup.pdf
A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Posted on Nov 06, 2010
Pacemaster pro elite INCLINE MOTOR DOES NOT WORK
If you wish to get some details about treadmill repair and service ; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jan 02, 2017 | Exercise & Fitness
New Magnetic Key
Go to walmart and look in kitchen goods. Look for refrigerator magnets and find small one... It will work... Looks cute too.
Jun 22, 2014 | PaceMaster ProPlus II Treadmill Incline...
Pacemaster Pro Plus treadmill popping fuse
You need to replace the walking belt. Don't use the machine until you've replaced that.
May 22, 2017 | Exercise & Fitness
I have a Pacemaster Gold treadmill that will not hold elevation. I have no error codes. It will go to the proper elevation and then immediately start descending. If I change the elevation setting it will...
Run the utility software calibration for easy diagnostic, and fix it.
Go to HOOD open the cover motor and follow the steps indicated. or your owner manual.
God bless you
Sep 30, 2013 | PaceMaster Gold Elite Treadmill Upper...
Pacemaster treadmill will not start, no lights, nothing.
Is there a spot on the control board you can check for out going power? You might have a bad board. You can visually inspect your board for anything that looks burnt or one component that looks swolen or loose. Poor solder joints are a common problem with treadmills because of the constsant movement.
Feb 18, 2013 | PaceMaster Aerobics Pro Plus Walking Belt
Can't load spectra II on my new mac pro
The SpectraView II software included with my NEC LCD3090WQXi display was version 1.1.02. Snow Leopard requires version 1.1.03. I downloaded the new software from the NEC website, installed it and now everything is working fine.
Oct 27, 2009 | NEC MultiSync LCD3090WQXi - Flat panel...
Exercise & Fitness Logo
56 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
