Question about Jabsco AC Motor Pump, 26 GPM, 115V/230V, 3/4 HP 6050-0003
My customer is looking for an oil service impeller for the jabsco pump 6050-0003
  • 3,382 Answers
Try this link, I am not sure if they have it.
http://www.pumpvendor.com/Jabsco_6050-0003_parts.html
Posted on Jun 17, 2014
How to wire the 115v/230v magnetek pool pump motor (1.5 Hp wth sq flange, 56Y) for 115V ?
if you are not a motor service person do not try this your self get the right help be safe
Sep 23, 2013 | AO Smith 1.5hp 1800RPM 56 Frame Farm Duty...
Changeing 115volt to 230 volt
Most power Flo pumps run above ground pools and run on 115v only.You can look at the wiring diagram on the motor label to see if it is convertible, it will show wiring configurations and amps for both 115v and 230v. If not, it is a 115v motor only.
Sep 11, 2013 | Hayward Power Flo Lx 1 Hp Pool Pump Sp1580
I replaced impeller but cant get any water pressure dont seem to have any air leeks
The leak could be in the pump itself. How is the rest of the pump, is it worn. If everything is OK then you have a leak in the suction side.
Jul 15, 2013 | Jabsco Pump - Water Puppy 7.8 Gpm
1 1 2 hp pool pump wire
look on side of motor there is a schematic for low and high voltage high voltage from factory
Apr 28, 2013 | Hayward 1 12 Hp Super Swimming Pool Pump...
I have a 3/4 hp Flotec 4022 pump. Prior to that I had a goulds 1 hp pump on the same 120 circuit with no issues. The Goulds pump housing started to go so I replaced it. Since replacing it with the Flotec I...
Hi Eglenni,
Here are the specs for your pump:
Thermoplastic Shallow Well Jet Pump 3/4 HP. This new revision of an "old hand" provides good pressure pumping from wells where the depth-to-water is 25' or less.
BODY CONSTRUCTION: Thermoplastic
HORSEPOWER: 3/4
MAXIMUM CAPACITY: 12 GPM
FLOW at 10' LIFT and 40 PSI: 9.7 GPM
MAX LIFT: 25'
MAXIMUM PRESSURE: 78 psi
PRESSURE SWITCH SETTING: 30/50
SUCTION PIPE SIZE: 1-1/4" NPT
DISCHARGE PIPE SIZE: 1" NPT
AMP DRAW (full load): 6.1 amps on 230v / 12.2 amps on 115v
VOLTAGE: 230v / 115v, 60 Hz
RECOMMENDED BREAKER: 15 amp on 230v / 20 amp on 115v
MAXIMUM WATER TEMPERATURE: 140 °F (60 °C)
Note that this pump can be operated at 115 volts or 230 volts (A/C) It may have come wired for 230 volt use from the vendor.
Make sure the pump is piped correctly.
There should be a wiring diagram either on the pump or in the literature so you can check to see how the pump is wired.
MAKE SURE
you have the pump wired for 115 volt use in your case. Also make sure the wire size is #12 awg for the power wiring.
Make sure all connections are tight. If you have an amprobe (an instrument that measures electric current) you can check to see how many amps the pump is pulling when it runs.
You said your old pump was 1 HP. This Flotec pump is 3/4 horse so there could be some pump performance loss depending on the well depth and length of the piping runs.
Here's the link to the website for the pump. There are additional resources available on the website:
Thermoplastic Shallow Well Jet Pump 3 4 HP
Jul 05, 2017 | Northern Tool Electrical Supplies
I just installed Hayward 1.5HP inground and it tells me that if i use the 115v to use a 30 amp breaker - and when i left the 230V button positioning inside the back of the pump and connected with a 14 ...
double the amps, 230 runs cooler (my fav) . 1.5 is 9.6 amps at 230 volt. you will need to set the motor to run on on the lower voltage this is why you are having problems.. also the motor is thermally protected . this why it will run for awhile and shot off .. remember to prime the pump after any pump repair !!!! . jay the pool pump repair guy in longwood florida
Jun 05, 2011 | Hayward 1.5hp Pool Pump Motor Motor A O...
I had a pool install a 230v /115v Pentair pump model # WFE-3 / 3/4 HP in my cascade which needs this pump to send water up to my upper fountain which was replaced recently as well, This was this last...
IF THE MOTOR JUST BUZZES, IT COULD JUST NEED A CAPACITOR.. THE THING ON THE TOP OF THE MOTOR.OR THE IMPELLER COULD BE CLOGGED AND NEEDS A GOOD CLEANING. YOU WILL NEED TO SPLIT THE PUMP TO DO THIS. OR IF IT HAS BEEN RAN DRY IT COOKED THE IMPELLER AND DEFUSER
Jun 03, 2011 | Pool & Spa
Where I can buy the A.O Smith 3/4 HP pool pump impeller?
You'll need information from the pump that the AOSmith electric motor is attached to in order to get an impeller or any other pump parts. If there is no nameplate for the pump are there numbers on the impeller you need?
John
Mar 03, 2011 | AO Smith A O Smith Motors A O Smith 3/4hp...
The pump comes factory set for 230v. Power to the motor is 115v so I switched the jumper as indicated. The jumper is set on 2 posts with an arrow pointing to 230v. I moved it to 1 post and the arrow now...
CHECK YOUR BREAKER IT MIGHT BE THAT YOU ARE 230V .. IF IT IS A WIDE BREAKER ITS 230 OR IF IT IS A SLIM BREAKER ITS 115V , A VOLT METER IS YOUR BEST FRIEND.. REMEMBER TO VOTE FOR YOUR FAVORITE FIXIT GUY ! THANKS JAY
Jun 29, 2010 | Hayward Super Pump 1 1/2 - Hp for In...
My motor is wired for 230v and I need it to be 115v
It should be. Look closely at the motor nameplate and you should see a small diagram telling how to connect the motor for 115v or 230v. Most newer pumps have a small selector of some sorts. Either a plug that pulls off a couple post the include an idicator arrow for where to set the plug for either voltage, or a dial you turn to show it. Either way, you should be able to set the motor for 115 rather easily.
Jun 14, 2009 | Pentair Whisperflo 3/4 Hp 115/230v
Jabsco AC Motor Pump, 26 GPM, 115V/230V, 3/4 HP 6050-0003 Logo
Top Jabsco Plumbing Experts
Gil Shultz
ray gallant
Are you a Jabsco Plumbing Expert? Answer questions, earn points and help others
