Question about Xerox WorkCentre M-24 Color Copier
How do I reload staples into my Xerox WorkCentre 7530?
    Novelist:
  • Xerox Expert
  • 107 Answers
You did not indicate finisher? Xerox MFPs' come with the most finishing options of any manufacturer.... I included instructions for all of them below. Enjoy!
Solution : Load Staples in the Professional Finisher With Booklet Maker The stapler in the booklet maker uses two Staple Cartridges labeled R2 and R3. Booklet stapling requires that both Staple Cartridges be free of jammed staples.
WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the printer has stopped copying or printing.
  2. Open the Finisher Front Door.
    How do I reload staples into my Xerox WorkCentre 7 - wc7556-fin-pro-fnt-door-open.jpg
  3. Squeeze the orange R2 and R3 levers together and pull the Staple Cartridge unit out of the Finisher until it stops.
    NOTE: The Staple Cartridge unit does not detach from the Finisher.
  4. Grasp the orange tabs on both sides of the Staple Cartridge and lift the cartridge out of the Staple Cartridge UnHow do I reload staples into my Xerox WorkCentre 7 - wc7556-fin-pro-book-stpl-cart-remove.jpgnet/uploads/images/wc7556-fin-pro-book-stpl-cart-remove.jpg" alt="wc7556-fin-pro-book-stpl-cart-remove.jpg" class="h_mi" />
  6. If no jammed staples are found, repeat step 4 - 6 for the other Staple CartHow do I reload staples into my Xerox WorkCentre 7 - wc7556-fin-pro-book-stpl-cart-unit-replace.jpgeturn the Staple Cartridge Unit to its original position.
  7. Close the Finisher Front Door.
Solution : Load Staples in the Main Stapler of the Professional Finisher NOTE: Using Staple Cartridges other than the recommended staples may impair quality and performance. Only use only Staple Cartridges recommended for this Finisher.
WARNING: Do not perform this procedure when the prinHow do I reload staples into my Xerox WorkCentre 7 - wc7556-fin-pro-fnt-door-open.jpgbr>
  1. Make sure the machine has stopped copying / printing.
  3. Grasp the orange R1 lever on the StapHow do I reload staples into my Xerox WorkCentre 7 - 7435-finisher-pro-staple-cart-remove.jpgr>
  4. Grasp the orange tabs and pull the cartridge out of the Finisher.
  5. Check inside the Finisher and remove any loose staples.
  6. Pinch both sides of the staple case and remove the staple case from the cartridge.
  7. Insert the front side of the new staple case into the Staple Cartridge, then push the rear side into the cartridge.
  8. Grasp the orange tabs on the cartridge, and then insert the cartridge into the Finisher until it click into position.
  9. Close the Finisher Front Door.
Solution : Load Staples in the Booklet Maker of the Optional Office Finisher LX NOTE: The Booklet Maker usHow do I reload staples into my Xerox WorkCentre 7 - fin-office-lx-side-cover-open.jpg stapling requires that both staple cartridges contain staples.
  2. Open the Finisher Side Cover.
  3. If the Staple Cartridges are not visible, grasp the vertical panels to the left and right of the opening anHow do I reload staples into my Xerox WorkCentre 7 - fin-office-lx-book-stpl-replace-02.jpg class="h_mi">Hold the tabs on both sides of the cartridge and pull the cartridge out of the finisher.
  4. Hold the tabs on both sides of the new cartridge and insert it into the original position in the Finisher.
    NOTE: If you have trouble inserting the cartridge, make sure the staples are positioned correctly in the cartridge.
Solution : Load Staples in the Integrated Office Finisher WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the machine has stopped printing or copying, then open the Front Cover on the Integrated Office Finisher located under the Scanner Assembly.
  2. Remove the Staple Cartridge by grasping the cartHow do I reload staples into my Xerox WorkCentre 7 - wcp3545-stapler-sleeve-install2.jpging it straight out of the Finisher.
  3. Remove any loose staples inside the Finisher.
  4. Pinch both sides of the staple case and remove the staple case from the cartridge.
  5. Remove the new staple case from its packaging and insert the front side of the case into the staple cartridge. Push the rear side into the cartridge. The cartridge will click into place when it is installed correctly.
  6. Grasp the cartridge by the orange handle and insert the cartridge back into the stapler until it clicks into position.
  7. Close the Front Cover.
    NOTE: If the Front Cover is not completely closed a message will be displayed. The machine will not operate if the cover is even slightly open
Posted on Nov 29, 2013
4 Suggested Answers
  • 2072 Answers
SOURCE: Load staples in xerox 430st
I will assume you are talking about the stapler on the finisher. That is a little tricky, but you will see a button on top of the finisher, you have to hold it down for a few seconds and the trays will lower. There is then a small door that opens and the staple cartridge is in there. You can either hold the button down again to raise the bins or turn the machine on and off.
Posted on Jan 22, 2009
SOURCE: Is there a Mac workaround driver for the Xerox WorkCentre PE16
Recently I had to configure a 17" Aluminum PowerBook and a Xerox Workcentre PE 16. That multifunction laser monochrome printer is not supported by MacOS X, but I tried all the same.... and no glue for that, until I went on the Samsung webpage and noticed their SCX-4216F printer. This machine is the same as the PE 16.
So I downloaded the lastest drivers from Samsung's download centre (drivers for Tiger too), installed the drivers on the PowerBook (running 10.3.4), connected the printer and when I selected the printer ... tada! It automatically selected the Samsung driver, so I clicked on OK and started printing. Everything was OK!
But it doesn't end here: even the Lexmark X215 MPF has the same chassis as the Xerox and Samsung. Yet, on Lexmark's website there are no Mac OS X drivers, but Samsung's drivers work just the same. I hope this hint will help others...
Posted on Jan 26, 2009
SOURCE: how to install Xerox WorkCentre PE16 scaner? i ...
How to install Xerox workcentre PE16 scaner?i install twin & driver but not work . Please help...
Posted on Jun 20, 2010
Wide black lines coming on paper while copying
Hello, One of 2 problems can cause this. 1. The toner cartridge is bad. 2. The Fusing unit is bad. Maint. kit if hasn't been replaced will work.
Apr 01, 2014 | Xerox WorkCentre 5632 Staple Cartridge...
Load staples in WORKCENTRE 7530
Open finisher door. Sometimes the staple cartridge does not come to the front you have to manually pull it from the back it is on a track. There will be a yellow tab after you pull it to the front and pull up and out. After you replace the cartridge don't worry about moving back to the back it will move on it own.
Nov 18, 2013 | Xerox Office Equipment & Supplies
Jam inxerox workcentre pro 128 copier finisher stapl area
how do i repair a staple jam in my xerox workcentre 128?
Jan 15, 2013 | Xerox WorkCentre Pro 123/128 Copier...
Error 116-364
Error 116-364 Problem with the Xerox WorkCentre Pro 123/128 Copier Finisher Staple Refills Copier. Dear i am also facing the same problem, It would be very helpful if you share the solution you may had come across. Thank you very much .
May 17, 2010 | Xerox WorkCentre Pro 123/128 Copier...
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox WorkCentre M-24 Color Copier Logo
689 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
