Question about Hotpoint Dishwashers
Hotpoint dishwasher dwm 75
What does error code al-02 mean
SOURCE: hotpoint fdw20p dishwasher
You need the control panel to reset before anything else can happen. To do this TURN OFF THE PLUG SOCKET FIRST AND UNPLUG. Then you need to drain ALL the water from the machine. Turn off the water supply feed and place the wastage pipe as low to the floor as poss ( 1-2" off floor). Water will gush out so use a large shallow tray and keep emptying the tray. Tilt the dishwasher over slightly to make sure all the water is out.
This will allow the control panel to reset itself which wouldn't normally happen if the base of the dishwasher was holding even a small amount of water.
Re connect the water, plug back in , select the RESET setting on the dial and close the door and switch on.
Leave for about 20 seconds and then turn off.
Rotate the selector switch to "A" Intensive wash and switch
I found this on another site and it really did work for me
Posted on Feb 23, 2008
IFIXALL
  • 868 Answers
SOURCE: hotpoint fdw 85
This is going to keep breaking down,Call the manufacturer and demand a refund.
Posted on May 23, 2008
SOURCE: Hotpoint FDW 85 Dishwasher
You just need to switch the machine off for approx 30 seconds from the mains and switch it back on again!!
AL99 means that there is a communication error within the machines software.
Posted on Jun 16, 2008
SOURCE: hotpoint dishwasher error code AL
heater circuit fault - will be element or timer card (module)
Posted on Oct 09, 2008
  • 157 Answers
SOURCE: error code A10 for hotpoint FDW70G
heater
Posted on Dec 19, 2008
I have an hotpoint sdw60 dish washer that is flashing 2 yellow lights, these are numbers 5 and 7 (fast and dry 40c) and (delicate 50c) can anybody tell me what this means.thankyou
Hotpoint Indesit dishwasher flashing lights fault error codes ...
? 15:08
www.youtube.com/watch?v=FRLbrBPHcnE
May 3, 2015 - Uploaded by how-2-repair.com
http://www.how-to-repair.com/help/hotpoint-aquarius-fdm-dishwasher-flashing-lights-and-there-fault-codes ...
Oct 02, 2015 | Hotpoint Dishwashers
Error code 02 ewd6505gso
Sandra Lawson,
Getting an Error Code 2 on your dishwasher, means there is something going on with the turbidity sensor. This is the sensor that determines how dirty the water is which in essence determines how long the cycle will run.
What you can try to do is to reset the appliance for 30 minutes. You will do this by cutting the power at the circuit breaker and leaving it off for no less than 30 minutes. Try running the cycle again and if you are still receiving the Error Code 2, I would recommend contacting the manufacturer for further assistance.
-Best Regards-
Jan 06, 2014 | Electrolux 24 in. EDW5500DSS Stainless...
My hotpoint dishwasher is leaking water and says error 99 on the screen what can i do?
If it's an AL error, is a communications error. PCB(s) cabling, connectors etc. If it's A99, This is a communications error meaning that there is a problem between the control PCB and the main PCB in the base.
It could just be bad connections or broken wiring but as this is an Indesit machine then PCB failure is also quite likely.
May 26, 2012 | Hotpoint Dishwashers
Model FDW80 error code AL-10 what does this mean?.
error code AL-10 == Failed heating element
You will need to have the element replaced, call a professional, or obtain a service manual and do a DIY?
May 12, 2011 | Hotpoint Dishwashers
Hi i have a hotpoint fdd912 dishwasher a3 error keeps coming up
A3 error code in Hotpoint dishwasher could mean either the heat fuse has tripped or there is a blocakge in the drain and the drain pump has timed out.
Clean the drain and filter and then check. If this does not help then you will have to check the thermistor/ heater fuse.
Mar 13, 2011 | Hotpoint Dishwashers
Hotpoint dishwasher error code AL 10
Oct 08, 2008 | Dishwashers
Jun 15, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint fdw80 dishwasher
Faulty heating element. Had the same error and got Hotpoint to replace the element. Error was also confirmed by their engineer.
Apr 13, 2008 | Hotpoint 24 in. DWF32P Free-standing...
Hotpoint fdw 85
Oct 03, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint Aquarius+ FDW70 Error Codes
i have the same on my dishwasher and have just been looking on the net. Found out that the error code A10 means open/short circuit fill value traic. Whatever that means!!! and to book a service engineer. Hope that helps
May 04, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
27 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
