Question about Polycom Lands Phones
Add an inline volume controller
Our Polycom VoiceStation 300 is too loud even when the volume is turned all the way down on the unit. I think I should be able to install an in-line volume control on the cord that leads to the unit, but I don't know which wire(s) control volume. Does anyone have experience here who could talk me through it?
  • 2,072 Answers
Unless you are good a solder then you probably won't be able to do it. You wolud need to solder a potentiometer inline of the + voltage to the speaker. Or solder one inline with the existing one. Potentiometer = voltage control aka volume control.
Posted on Nov 19, 2013
  • 1 more comment
  • mikadot
    mikadot Nov 19, 2013
    i would just follow the speaker wires back to the board.
  • Aimee Cardwell
    Aimee Cardwell Nov 19, 2013
    I'm pretty good at soldering, but I don't know which of the wires are which. They connect to the phone via an ethernet jack. I guess I could take the cover off and try to figure out which ones lead to the mic and which to the speakers, but I was hoping someone already knew. :-)
  • Justin
    Justin Nov 19, 2013
    Yeah no clue, I'd just you a voltage meter on the wires. It will probably 5v
  • 12 Answers
SOURCE: how do i conferance call on a polycom voicestation
The conference call feature is not part of the phone, but part of your telephone network. In some systems you press a sequence of keys to conference in another member such as flash #02 but it depends on what telephone network you use. Contact your IT admin and ask how to trigger the feature on that analog line.
Posted on Aug 12, 2010
  • 61 Answers
SOURCE: how do you make a
Press the speaker or ON button, then dial and wait for an answer.
Posted on Aug 16, 2010
  • 146 Answers
SOURCE: How do I receive 3
you cant
you can only call out to multiple people not receive multiples
try using a conferencing bridge so all people can call into one number and be connected that way
Posted on Mar 21, 2011
SOURCE: I have the Polycom VoiceStation
Hi, I have never really though of those brand devices as all that good. I recommend Konftel, they are simply the best. With Aethra, a close second...last is .......
Just get the top of the line one, and you will NOT be disappointed.
http://www.telecom.co.nz/content/0,8748,101437-201060,00.html
BTY, I expect that your unit is faulty, the electret mic's aren't very good, and fail quite a bit, as with all cheap electret's, and also check positioning too, this can make a difference too, make sure nothing is around to reflect the sounds as this is what makes it echo and sound bad, regardless.
Posted on Jul 27, 2011
  • 125 Answers
SOURCE: What are possible reasons that the conference phone is not getting power?
If you know anyone that can test the power supply with a digital meter, you can check if the power supply works or not. the power control board on the voicestation might have blown. and If that is the case I wouldnt recommending fixing it. Getting a refurbished or used with maybe 3 months to 1 year warranty isnt that expensive on these systems. getting it fix might cost you about the same. But checking if the power supply is working or not would be the first thing you want to do. If that works. looking for a power supply is pretty easy.
Posted on Mar 23, 2012
Polycom voicestation 300
are you sure this feature is not blocked on your line? check with another phone connected to the same socket if you can dial the same numbers
Jul 30, 2014 | Polycom Lands Phones
Doesnt ring when call transfered
When the Polycom is on-hook (not in a call), use the volume rocker to change the volume of the ringer.
Dec 10, 2013 | Polycom VoiceStation 300 (220017910001)...
Polycom voicestation 300 isn't turning on. Any ideas?
Why not go through the user's manual for an answer?:
http://search.aol.com/aol/search?&s_qt=sb&q=polycom+voiceststion+300+problems&tb_oid=07-01-2013&s_it=amonetizetest1-ie&tb_mrud=07-01-2013&tb_uuid=20130107163427450
or the repair service:
http://www.thevoiceanddatawarehouse.com/cart/itemid/419/itemname/cart.php
Jan 16, 2013 | Lands Phones
Feb 27, 2012 | Polycom VoiceStation 300 Conference Phone
My polycom is flashing and beeping even after being turned off and back on. wha't up?
it might be power supply they are common to go bad
try different one and see if that helps
Mar 30, 2011 | Polycom VoiceStation 300 (2200-17910-001)...
How do I receive 3 calls at the same time on a Polycom Voicestation 300 ? (conference style)
you cant
Feb 25, 2011 | Polycom VoiceStation 300 Voice...
How do you make a conference call on the Voicestation 100 polycom phone?
Aug 12, 2010 | Polycom VoiceStation 100
I set up the polycom as instructed... I even confirmed with my helpdesk that the line is analog. When i turn the unit on I get a high pitched buzzing sort of sound... no dial tone? I also cannot dial in...
Try to plug a cheap analog phone into the same line instead of the voicestation to verify that it is indeed analog. It sounds as if you connected the phone to a specialty PBX line or similar. There are analog PBX that only work with their own phones. You can also try to connect the phone at home and see if it works on your analog line at home.
Aug 05, 2010 | Polycom VoiceStation 300 (220017910001)...
How do i conferance call on a polycom voicestation 300
May 14, 2010 | Polycom VoiceStation 300 (220017910001)...
How do I conference call on a Polycom Voicestation 400?
Conference call is not a feature of the phone, but a feature of the telephone system in the company. Usually you press a sequence of keys like flash #02 to trigger this function in the phone system. If your company phone system does not offer the feature then you have to use an external conference call provider.
Jun 17, 2009 | Polycom VoiceStation 300 (220017910001)...
Lands Phones Logo
174 people viewed this question
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
Sandeep Kamat
Sandeep Kamat
TEKUSER
TEKUSER
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
