Question about Honeywell Rth2310b 5-2 Day Programmable Thermostat
The temperature falls 3 or 4 degrees below the set temperature before furnace kicks on
    New Friend:
  • 138 Answers
There is a Span setting on the thermostat causing that, most newer thermostats have a adjustable span from 1 to 5 degrees, if your thermostat has a option menu, scroll through the options and see if you find a option called Span if its at 3 or 4, change it to 1 or 2, then your furnace will cycle on sooner. If you have your owner manual still for it that should show you how to do it.
Posted on Nov 18, 2013
Ice machine , fan kicks on and off constantly
Hello Harold;
My name is Peter. I am a retired field service refrigeration technician.
Your fan is not designed to run constantly. Your fan will turn on when the set temperature falls 10-20 degrees below set temperature, and will run until the unit is 10-20 degrees above set temperature.
1.) Clean your condenser coil. This coil removes the unit heat.
2.) Check your condenser fan to make sure it is running.
3.) Check the door gaskets. They may be crushed or worn, allowing warm air to enter your unit.
Dec 23, 2014 | Refrigerators
Hi,My remote do not get the good temp in my house. Ex: I set to 80F in heat mode but the thermopump operate slowly and dosn't get hire than 70-72F. The remote see the unit and all. Is the sensor in th
You have a heat pump.
Once the outdoor temperature falls below 36 degrees, heat pumps will sharply lose their ability to heat.
If you are getting a 72 degree indoor temperature when the outdoor temperature is 28-30 degrees, the heat pump is performing up to spec.
On heat pumps, the air coming out of the nearest air vent to the unit should be heated approximately 40 degrees warmer than the air entering the unit.
If you have a 70 degree indoor air temperature, the heat pump should be supplying 110 degree air at the closest air vent to the indoor unit.
Gas heat is a much better heating source where outside temperatures are commonly below 36 degrees.
Even electric furnaces perform better than heat pumps under these conditions.
Nov 30, 2014 | Heating & Cooling
I have a Braeburn 3200 and when the the temperature reaches the desired heat setting. The furnaces heat will shut off, but the fan will continue to run indefinetly. eventually blowing very cold air up
The fan relay is stuck in the on position. When the temperature drops the heater does not ignite because the fan is already running and ignition is locked out after the heat cycle starts an the fan turns on
Nov 16, 2014 | Heating & Cooling
Furnace will not kick on
going out on high limit which requires manual reset
Dec 15, 2013 | Intertherm P3RA-048K Air Conditioner
Fasdfas
Does the furnace stays off?.
Furnace are ment to cycle on and off because of limits .If you set to 70 furnace would cycle several times before reaching that temperature.
Just make sure your filters are clean and you got proper return air flow because lack of air flow will cause furnace to shut off sooner than normal
Jun 08, 2017 | Heating & Cooling
I just installed a honeywell 5-2 progammable thermostate.. Everything is hooked up fine and I have my days, hours wake, sleep, leave...etc all set, but when it goes on.. for example, I have it set for...
You didn't include a model number, so it's hard to know for sure - but I'll take a stab at this one. Many of these t-stats have a programmable offset to reduce "hunting". This can be as little as 1 degree or more than 2 degrees.
This means if you set the offset to 1 degree and the room temperature to about 65 degrees, the furnace will heat the room until the t-stat registers a rising temperature of 66 degrees. The furnace shuts off and will not turn on again until the t-stat registers a falling temperature of 64 degrees. The average is 65 degrees, and prevents the furnace from starting and stopping numerous times instead of just once with the 1 degree offset.
You can further reduce the number of furnace start and stops by increasing the offset to 2 degrees. This would work like this when the t-stat is set to 65 degrees and the room is cool:
Room Temp Furnace
63 On
64 On
65 On
66 On
67 On
68 Off
The room is now warm and heat or furnace is off. The room begins to cool like below:
67 Off
66 Off
65 Off
64 Off
63 Off
62 On
With a 1 degree offset, the room temperature varies +/-1 degree (about 2 degrees total). With a 2 degree offset, the temperature about varies +/ -2 degrees (about 4 degrees total).
Also, when the thermostat shut the heat off, the heat that was made is delivered to the space instead of wasted by sending outdoors - so the room will get a little warmer even though no fuel is being burned. The same holds true at the other end. When the t-stat turn heat on, fuel is burned, but there's little heat until the source has reached the optimum temperature and then the heat is delivered to the space.
I hope this helps & good luck! Pleas rate my reply - thanks!
Jan 24, 2011 | Honeywell Programmable Thermostat Heater
Does the T8602C1095 have an anticipator that may need adjustment when the temperature set is exceeded, eg we set at 70 and it goes to 71-72 and then need to manually shut down system.
that is how they work. ther is a 1 to 3 degree variance up or down.it probaly does not kick back until 67 or68 degrees. a two stage furnace will keep a more steady temp.
Oct 01, 2009 | Honeywell Electronic Programmable...
Honeywell Rth2310b 5-2 Day Programmable Thermostat Logo
118 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
