Question about Panasonic VIERA Televison & Video
Panasonic tv heats up and turns off and cant turn it back on
My name is Callie and my panasonic PT-60LCX64 projector tv wont turn on. I can hear it running and hear the fan, and read about a switch that needs to be pressed in but i cant find the switch.
PT-60LCX64 - Panasonic
shop.panasonic.com > Get Support
Panasonic60" Diagonal LCD Projection HDTV. ... Details http://shop.panasonic.com/support-only/PT-60LCX64.html ... Will the Touch Pen (TY-TP10U) work with my TV?
Panasonic TV Not Turning On? (PT-60LCX64)? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 13, 2010 - When I power the TV on, the green light flashes for about a minute, and ... Source(s): panasonic tv turning pt 60lcx64: https://tr.im/EBjDN ... I have apanasonic tv PT-56lCX66 and it wont turn on? Why won't my Panasonic PT-52lcx16TV turn on? Panasonic lcd rear projection 60 inch tv..model #PT-60LCX64.
Panasonic PT60LCX64 Lamp with Housing TY-LA1000
www.amazon.com > ... > Projector Accessories > Lamps
Amazon.com, Inc.
Rating: 3.8 - ‎30 reviews
PANASONIC PT-60LCX64 TV Replacement Lamp with Housing ... Howere, EVER TIME we turn the TV On a Pop Up Message comes up to Set a Lamp Timer!
Panasonic LCD Projection 1 Orange Amber Blink PT 43 50 ...
? 5:48
https://www.youtube.com/watch?v=Z9tLqxpD1qU
Apr 18, 2013 - Uploaded by norcal715
Dec 26, 2015 | Panasonic Televison & Video
The T.V. suddenly turn off after viewing for about two hours. I turn the manual off/on switch but nothing happens. After about ten minutes when I turn turn on the remote control on, the T.V. turns on. ...
Yes this as been reported lot of time whit plasma ,that is because a over heat problem in the video processor especially in very hot weather period due to the cooling fan circuit where
is unable the cool down the circuit , some as put an external fan to blow air on the back panel slot, but you may need to verify the fan circuit inside the set to make sure its working properly......and i cant go so fare with this because i cant
troubleshoot the problem my self not from here..
hope that will give you an idea
regards Alan..
Oct 26, 2010 | Panasonic TH-42PX75U 42 in. Plasma...
How to get out of the store demo mode
just did it myself. turn the TV off and unplug. wait 3-5 minutes plug back in and turn on. store-home mode will display..chosse home and your good to go
Feb 16, 2010 | Panasonic Viera TH-42PX80U Plasma TV
TV off...cant get out of standby mode
Sounds like the connections on the CRT Socket or CRT circuit board. Remove back and check connections.
You could also have buildup on the cathodes of the electron gun (internally) to redimie you must have set in operation and viewing video. Tap the neck of the tube gently while watching for the colors to change until they Stabileize, this is best seen whith the color turned off.
Good Luck
Feb 12, 2010 | Panasonic CT-27SC14 27" TV
1 yr old panasonic th-50pz700u shut off spontaneously and won't turn back on . red light blinks 8 yimes and repeats
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit).
This has to be replaced, call Panasonic and if you still have warranty you can get it replaced for free.
Jun 03, 2009 | Panasonic (TH-50PZ700U) Television
My panasonic TV Model: pt 53tw53g turns off by it self
My Panasonic has exactly the same problem. The repair man just came in and said that the convergence and resistor burned under heat and have to be replaced. Will cost $400.
May 13, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Cant turn off panasonic PIP
To turn off the "stuck" pip on a Panasonic tv without a remote, turn off the tv. Then hold down the "Action" button on the front of the tv and press the power button. This will activate a reset and self check of the systems and voila! The pesky pip screen will be gone! This is on an approximately 10 year old regular crt "CT-xxxxx" series tv.
Jun 12, 2008 | Panasonic CT-36D32 36" TV
Cant turn on my tv
There's a short in there somewhere. Have a pro look at it.
Mar 25, 2008 | Panasonic PT-43LC14 43" Rear Projection...
Panasonic DVD-S31
have you ot it setting on something warm or hot like a subwoofer to surround sound or on top of a tv even if you had it there before and it worked they get older and cant take heat as well and they get dust built up in them alot of times one freezing or shutting off is getting to hot is it doing it right when you turn it on if so try unplugging it for a few hours then plug it back and try it
Feb 06, 2008 | Panasonic DMR-ES10 DVD Recorder
Televison & Video Logo
23 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
