Question about Panasonic VIERA Televison & Video
Panasonic tv heats up and turns off - VIERA Panasonic Televison & Video
My name is Callie and my panasonic PT-60LCX64 projector tv wont turn on. I can hear it running and hear the fan, and read about a switch that needs to be pressed in but i cant find the switch.
PT-60LCX64 - Panasonic
shop.panasonic.com > Get Support
Panasonic60" Diagonal LCD Projection HDTV. ... Details http://shop.panasonic.com/support-only/PT-60LCX64.html ... Will the Touch Pen (TY-TP10U) work with my TV?
Panasonic TV Not Turning On? (PT-60LCX64)? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 13, 2010 - When I power the TV on, the green light flashes for about a minute, and ... Source(s): panasonic tv turning pt 60lcx64: https://tr.im/EBjDN ... I have apanasonic tv PT-56lCX66 and it wont turn on? Why won't my Panasonic PT-52lcx16TV turn on? Panasonic lcd rear projection 60 inch tv..model #PT-60LCX64.
Panasonic PT60LCX64 Lamp with Housing TY-LA1000
www.amazon.com > ... > Projector Accessories > Lamps
Amazon.com, Inc.
Rating: 3.8 - ‎30 reviews
PANASONIC PT-60LCX64 TV Replacement Lamp with Housing ... Howere, EVER TIME we turn the TV On a Pop Up Message comes up to Set a Lamp Timer!
Panasonic LCD Projection 1 Orange Amber Blink PT 43 50 ...
? 5:48
https://www.youtube.com/watch?v=Z9tLqxpD1qU
Apr 18, 2013 - Uploaded by norcal715
Dec 26, 2015 | Panasonic Televison & Video
My Panasonic LED TV picture goes away after a few minutes
Could be a bad connection that disconnects when heat in the system causes it to expand. Take to a pro or call manufacturer, they might have a recall or free repair available.
Apr 03, 2015 | Panasonic TC55LE54 55" 1080p 120Hz SMART...
My Panasonic led tv just shuts off , wait 10 mins
It could be the room temperature or the TV is placed in a box type cabinet, thus restricting the air circulation at the back of the TV. Flat screen TV's generate a lot of heat and without proper air circulation, they usually shut down to prevent damage to its components. Are you in the middle of a cold spell? Usually when it's cold, you have the heaters on hi heat, yes? Try and reduce the heat or place the TV on a cabinet with ample air circulation and then see the difference.
Oct 17, 2014 | Televison & Video
I have a panasonic tv model 21fx20- shut off after few minutes
Request the schematic diagram directly from Panasonic.
Jun 19, 2017 | Panasonic Televison & Video
1998 32" PANASONIC TV. When
You have dry joints!
Look for poor soldering on any heavy object including heat sinks/transformers etc.
Dec 31, 2010 | Panasonic Televison & Video
How do i reset the lamp timer switch on my panasonic tv
Unplug, wait 5 minutes and plug in...this may or may not reset... There are several problems with this TV that can occur due to the heat within the balister and lamp area.
Aug 15, 2009 | Panasonic PT-50LC13 50" Rear Projection...
1 yr old panasonic th-50pz700u shut off spontaneously and won't turn back on . red light blinks 8 yimes and repeats
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit).
This has to be replaced, call Panasonic and if you still have warranty you can get it replaced for free.
Jun 03, 2009 | Panasonic (TH-50PZ700U) Television
My panasonic TV Model: pt 53tw53g turns off by it self
My Panasonic has exactly the same problem. The repair man just came in and said that the convergence and resistor burned under heat and have to be replaced. Will cost $400.
May 13, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic plasma
If you open the back,look at the can shaped items.If any of them have the tops bulged out,they need to be replaced.This should solve your picture problem,unless there is something else wrong.What is happening,is they are heating up,and the picture goes out.I bet the longer you have the TV off,the longer it stays on?Hope this helps.Thank You very much! Tyler
Apr 06, 2008 | Panasonic TH-42PX75U 42 in. Plasma...
Televison & Video Logo
23 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
