Question about Nikon Coolpix L1 Digital Camera
Fix shutter speed - Nikon Coolpix L1 Digital Camera
How to fix slow shutter speed?
When in Any auto mode or P or A your camera automatically will adjust your shutter speed for ambient light conditions. So if your having issues where your camera is choosing to slow a shutter speed and you photos are coming out blurry then there isn't enough light either because other settings in the camera are limiting light or where ever you are taking photos is poorly lit. Setting your ISO Higher should allow the camera to increase the shutter speed, but will often introduce noise to your photos. The more you play with your camera and learn digital photography the more you'll understand how to make your photos the best they possibly can be. For the time being if getting a no blurr shot is key put your camera in S mode which means shutter priority this will allow you to control and lock your shutter speed and set your ISO to auto this will force the ISO and Aperture to change instead of your shutter speed to get a good photo.
Jul 21, 2014 | Panasonic Lumix DMC-FZ30 Digital Camera
Slow shutter speed on D7000
The camera requires service by camera tech, not a user fix problem.
Jan 21, 2013 | Nikon D7000 Digital Camera
Cant set shutter speed past 200
Is the flash turned on? The camera won't let you set a shutter speed faster than 1/200 when the flash is on.
Dec 08, 2012 | Nikon D3000 Digital Camera
All run well (shutter-exposure-drive) except for mirror
it sounds like its set up for a very slow shutter speed
ie:30sec's? and your getting triger happy trying to rush it to take the photo and get it over with, check when film speed its set on and what shutter speed its set to,and stop poking the mirror about or its going to cost you big time bucks getting it fixed,
Mar 05, 2010 | Contax 167 MT 35mm SLR Camera
How do I change the shutter speed?
This is "shutter lag," the delay between pressing the shutter release button and the camera actually taking a picture. This is a common situation with many compact cameras. The camera has to focus on the subject, meter the exposure, and switch the circuitry from displaying on the screen to recording the image and saving it in memory. More sophisticated (and expensive) DSLRs eliminate this shutter lag by having more dedicated hardware for this.
With a compact camera, you can reduce the shutter lag by anticipating the shot. Press the shutter release button halfway to focus and meter the exposure. Continue to hold the shutter release button halfway until the right time, then press it the rest of the way.
Jan 17, 2010 | Canon PowerShot SX100 IS Digital Camera
Shutter speed on my nikon d80 is to slow
Try CUSTOM SETTINGS MENU 31. (turn off EXP. delay mode).
Dec 28, 2008 | Nikon D80 Digital Camera with 18-135mm...
Shutter speed
shutter speed has nothing to do with battery power. If you have a SLR camera you use the shutter speed option when you want to have control of the shutter speed, slow shutter speed means if your taking a picture of a waterfall and you want to see the actual droplets you set a slow shutter speed, if you want it to look more smooth/flowing you set a faster shutter speed, if you do not have a SLR camera you probably dont have much say so in shutter speed...
May 28, 2008 | Nikon FE 35mm SLR Camera
Flash and high shutter speed problem
Actually you cannot take 'High Speed' photos and flash they way you are thinking- Even even with high spec pro cameras - it does not work that way. The Flash speed is in the order of 10,000th sec. So all the shutter has to do is open for a long exposure - because synching the the flash is hit or miss And it is the Flash that does the exposure.
Aug 29, 2007 | Nikon D40x Digital Camera
Slow shutter speed
from the manual: Using Shutter-Priority Mode 1. Set the mode dial to S (shutter-priority) and a yellow arrowhead on the screen points to the current shutter speed. Press the jog dial and the current shutter speed turns yellow. 2. With the current shutter speed displayed in yellow, rotate the jog dial to select the speed you want to use. 3. Take the picture. If a workable aperture isn?t available for the shutter speed you?ve selected, the shutter speed indicator on the screen flashes when you press the shutter button halfway down. You can use the setting as is, or press the jog dial down to select the shutter speed again and rotate it to select a new shutter speed.
Jun 03, 2007 | Sony Cyber-Shot DSC-F717 Digital Camera
Bronica SQ-Ai shutter problem
There could be a number of issues with this problem. Make sure the contacts at the rear of the lens and those on the body that connect with those on the lens are clean and straight. If so, the problem may be in the shutter within the lens. There is a magnet inside the shutter that sometimes becomes contaminated and fails to hold the shutter blades open for the selected shutter speed. The face of the magnet may need to be cleaned. There are also timing switches that sometimes go bad or need adjusting. These internal problems need to be taken care of by a competent technician since the lens needs to be completely disassembled. I have also seen these shutters go bad and need to be replaced. Let's hope that's not the problem because it will be difficult to get a new shutter for the lens--but not imposible. God luck.
Apr 30, 2007 | Bronica SQ-Ai Medium Format Camera
Nikon Coolpix L1 Digital Camera Logo
16 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
