Gorenje induction hob fault code - Washing Machines
4 Suggested Answers
  • 134 Answers
SOURCE: I need a handbook for a gorenje gas hob and fan oven
Hi
You need o call Gorenge and they will send it if they have it.
0845 050 8555 UK
please leave feedback
Posted on Feb 12, 2009
SOURCE: gorenje WA72145BK fault 6 displayed on my LED
I have the same problem. Any solution? Thanks!!
Posted on Jan 09, 2010
  • 45340 Answers
SOURCE: I have a error code E4 on one of the hot plate on my gorenje induction hob IT604ASC
contact the manufacturer . or a repair service
Posted on Sep 28, 2016
Error code e9 on hob aeg hk85440075
From another Post from Daniel T:
E9 on this hob means a user interface control board fault. This is the touch control board which you press to turn on.
What the service manual says is disconnect the hob from the mains connection and leave for 60 seconds. Then wire it back up and turn back on and see what happens.
If still the same then the user control board needs to be replaced.
To access this you need to remove the hob from the work top and remove the screws holding the glass on all 4 sides of the hob.
Then you can lift the glass top off.
From there you will see the user board in the front its the smaller board.
Replace this and that should cure the fault here.
If you need anymore info just get back to me.
My Zanussi induction hob flashes an error code E9 when try
Oct 30, 2015 | AEG Washing Machines
Rangemaster 110 induction hob not working
sounds like you will have to strip it to get to where the water is causing the fault
Jan 10, 2014 | Rangemaster Kitchen Ranges
Induction hob not heating up. What does 5h or SH error code indicate?
if they are not steel bottomed pans they will not work with induction hob test them with a magnet
Apr 07, 2013 | Smeg Cooktops
Induction hob neff T4243 has cracked will I need to replace it
Did you crack your hob by means of impact or did it happen on its own accord?
I have a neff induction hob and has just cracked in 3 directions while cooking this evening. I am just trying to determine if there is a common fault with this neff product or I am just unfortunate. Mine is under warranty and have a engineer coming on Monday, so have the whole weekend with no hob as I have been advised not to use it.
Many thanks
Feb 28, 2012 | Cooktops
De dietrich induction hob fault code d5 6f 20 a3
I have a De Dietrich DTI749X induction cooktop and i have the FO error code flashing on two of the hobs.
How do I fix this?
Sep 01, 2011 | De Dietrich Ovens
My De Deitrich induction hob wont heat up.
It is OK. The voltage was the problem. As soon as we went on to proper power again the hob worked normally.
Jan 10, 2010 | Kitchen Ranges
Hi
0845 050 8555 UK
Feb 11, 2009 | Ovens
Induction hob switching off
check that the hob is wired correctly underneath 1,2,3 should be linked together as live 4,5 as neutral and earth takes its place as earth,
if it is wired correctly then i m afraid the hob needs a new induction element it is all one complete unit on these hobs not seperate so your looking at £1000 + to fix it plus engineer call out charges
Dec 06, 2008 | Kuppersbusch K 23 in.EKE604.2 Electric...
Washing Machines Logo
Top Washing Machines Experts
