Question about Canon imageRUNNER iR C2880 Color Copier
E000003 0002 error
The error come us as soon as the loading screen finishes. I have gone into service mode *28* then funtion then clear then err then ok. When i reset the printer the error still comes up. Also in the service mode it never shows any errors?? ***Weird*** if I open the side while it is loading then close it, it goes to the normal print screen but after a few seconds it shows the erroe
    Problem Solver:
  • 10 Answers
Check fixing thermister or heater then clear first 3 errors through *28*
Posted on Nov 19, 2013
spinal
  • 287 Answers
SOURCE: Error Code E000020-0225
Wedm/Craig. I will glady help you, and I am extremely confident that I am correct. More importantly I wish to to help you avoid The "COPIER DUDE COMPANY" taking a large chunk of your cash. I work for a "COPIER DUDE COMPANY" and we charge $200 just to say "yep, you have a problem". So lets start from square one and please forgive me if I get long winded and redundant. You tagged onto a request for help initiated by a customer called Brassmonkey who had a code of E000020-0181.This code means that when the copier attempted to calibrate each color (cyan,magenta,yellow and black) as it does from time to time to maintain optimum copy quality, the target values for yellow could not be achieved. Not even close. Yellow is the first color the copier checks and is used as a reference for the rest of the color calibration.Therefore it tends to be the primary error code in the event of a problem. Now here is where it gets hairy. Hang with me here. A patch of color is placed on what is called a transfer belt. This belt is where the image/copy is created prior to it being transferred to the paper. In fact, there is a point in time where the color copy you requested exists on this plastic belt, held by a staic charge, and is waiting to be pushed onto the paper as it goes through the machine. So when the copier goes thru periodic calibrations, again it makes a yellow "patch"....looks at it....... reajusts....looks at it... until it hits the optimum target of quality. And it does this for every color. So, now to the NUTS of it all. You have a drum&developer "unit" for each color.One dual unit for each. They are fed toner as they need it. Any one unit can fail due to shear normal use,and this is not a function of toner.{I have seen weird shit that defies logic before but toner is on the wierd shit list} Now, at some point the "plastic transfer belt " fails. So no matter how new the drum/developer units are, the "medium" from which the colors are being judged by cannot provide a valid measurement. Its like an old guy like me trying to read small print with scratched glasses. New text does not mean I can read it better. So now you have an 000020-0225 code. This means that the magenta color calibration failed.This tends to lean toward the transfer belt(scratched glasses) being worn. Two color calobration failures make ya wonder. Canon says that under the best of conditions the tranfer belt is good for 300K. These are all remote troubleshooting suggestions but at least you will have the benefit of these details. And the transfer belt is A: not real expensive and B: not labor intensive. I hope this helps. Good luck and take care. ............SPINAL........
Posted on Feb 26, 2008
  • 11 Answers
SOURCE: mp780 waste ink full
CANON MP 780 WASTE INK COUNTER RESET
Enter Service Mode : Menu – Scan – Copy – Scan
Select #7 PRINTER in the service mode, and
input “0” at # 5 INK ABS CAPA.
Posted on Mar 11, 2008
SOURCE: Service error 5100 on my canon Pixma mp110
just replaced the ink cartridges and reset the counters, evrth ok now :-)
Posted on Nov 09, 2008
SOURCE: Service error 6C00 - at my wits end
I am having the saME TROUBLE. yOU SAY Its either the logig board or the purge unit? What does that mean?
Posted on Nov 20, 2008
pineworks
  • 4041 Answers
SOURCE: printer orange light flashing 2 and 5 times, servive error 5100
Hi You can Try 2 things.
All the luck for you
There is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
How do i reset my canon IR2010f copier to facory defaults
Hi steve363,
Please follow the steps below to reset the unit to factory default.
1. Go into service mode. (*28) "Function" - "Clear". To get into service mode you might need to push "Additional Function" key. *AD>28 simultaneously and *AD again.
2. There should be an option under the clear menu for "pwd-clr".
3. Highlight it and then press OK.
4. On reboot the ID screen should have gone.
5. If not under the clear menu, please try MN-CON, that will clear the main controller.
Hope it helps.
Thank you for using FixYa.
Jul 11, 2011 | Canon Office Equipment & Supplies
Code show on the copier screen:E000004-0010 it's my problem and we can not copy document, so how do we slove this problem Thanks
error is due to fixing unit.clear it in service mode additional function 28 additional function button. go to function then to clear then click err then ok restart the machine wola.
if this not clear the code then u have to call a rep to have look at the unit
Jun 06, 2011 | Canon imageRUNNER 5000 Copier
I am getting e020 error switch main off and on again and again
e020 error is of the main fuser unit u can solve it by press *28* then goto copier then function then clear and clear err dc-con err-hist jam-hist and pull both 1st and 2nd drawer now restart and when the screen is ok again restart then on main screen insert both drawers ur err will be removed -tushar sharma tushar@easy.com -9403343433
Mar 22, 2011 | Canon imageRUNNER 600 Printer
What does error code E000001-0000 on a Canon IR5000 copier mean
The error code is much more likely to be E001, this is a fuser type fault. You should be able reset it in service mode. (copier, Funtion, Clear, error, turn m/c off then back on)
As the issue is a fuser temperature related. First, the error needs to be cleared. Turning off/on won't do that.
You could go into service mode and clear the error (*28* > copier> function > clear > err > ok. Then turn the copier off, then on again and watch it heat up. I always monitor the temperature to make sure it's in the acceptable range (190 C or around that range).
If it happens often I'd have the thermistors changed. If it still happens, check the connectors in back of the fuser. They may need to be shimmed.
Sep 01, 2010 | Office Equipment & Supplies
Error msg E000001-0000 What can we do
that is a thermistor error code. there are several causes for this. the thermistors are dirty, the upper fixing roller is damaged or it might have paper wrapped around it, or the connecter on the back of the fixing frame has a hair line crack in it. now you can clear this code if you you think there isn't anything wrong with the afore mentioned items.
you have to get into service mode. first you will have to shut the copier off at the main power switch and turn it back on once the error code pops up on the screen you will need to get into service mode.
you hit the
additional funtions button
then the 2+8 at the same time
then additional funtions button again
once in service mode you will need to follow the following steps
hit the copier tab
then the funtions tab middle of screen across the top
then hit the clear tab
then the err tab and hit the ok button to clear error
now you only have like 30 seconds give or take to get into service mode and to clear the error code before the machine shuts down if you don't get in fast enough dont worry shut the copier off and turn it back on and keep trying till you get in and clear it. trust me it took me several tries my first time i realized this myself.
Aug 16, 2010 | Canon imageRUNNER 5000 Copier
HOW DO RESET TONER DISPOSAL FULL,AFTER REPLACING ON A CANON IR 28
You have to enter servcice mode and reset the error code. Press the 'head' key with the star inside it - then the '2' and '8' key at the same time - then the HEAD key again. This must be done fairly quickly and then you're in the service mode. Now, from the screen select 'COPIER' then the 'FUNCTION' key then 'CLEAR' ---->'ERR' ---------> 'OK'. Now turn the machine off and on again. Your code should be gone. If not, you may have to clean the waste toner bottle neck where the sensor light shines through it.
Jan 19, 2010 | Canon imageRUNNER 7200 Copier
Error code E000002-0000
Get in the service mode *28* and there under function, clear, err.
If not replace the fixing film unit
Jan 02, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Canon ir6800c error E00000-0030
after power on temp does not reach 50 deg C within 420 sec check main thermistor thermal switch and heater then enter service mode *28* copier function clear err and then retstart copier
Sep 11, 2009 | Canon imageRUNNER C6800 Copier
Error E000001-0000
e001 is a fuser error. it might be able to be reset, but should be looked by a tech.
SERVICE MODE
*28*-press the additional func button, 2&8 at the same time, and the additional func button again.
when you have done it correctly, the screen will change and it will say service mode across the top.
Then select:
copier
func
clear
err
press the done or ok button on the lower right side of the screen.
turn the machine off at the black switch on the right side, wait 10secs, turn back on. should work.
****DONT MESS WITH ANYTHING ELSE IN SERVICE MODE YOU CAN REALLY SCREW UP THE MACHINE.!!!!!!!!!!!!!!!******************
Apr 23, 2009 | Canon imageRUNNER 6000 Copier
Error Code E005
Have to reset the cleaning web counter and error. Press *, 2&8, * to enter service mode. (*28*). Highlight COPIER, select COUNTER, select MISC. select CLEANING_WEB and press C on the keypad to clear the counter. Press reset to get back to main service menu, highlight FUNCTION. Select CLEAR. Highlight ERR and press OK. Switch machine OFF/ON. Hope this helps, let me know?
Sep 04, 2007 | Canon NP 6050 Copier
Canon imageRUNNER iR C2880 Color Copier Logo
173 people viewed this question
old marine
old marine
