Question about Gemmy Life-Sized Animated Santa
Santa moves and mouth moves but no sound.
No sound
Hi there my Santa sound is coming on real low then goes off
Posted on Nov 22, 2013
My Santa quit dancing what can it be?
this is what i found on the internet...
hey i got one of those santa's too that stopped moving. found a rubber belt to be the issue. takes a bit to get him apart to repair (removing arms, clothing, and mid body & head to leave a stand with a rectangle box that moves the santa body i havent fixed mine yet last time i tried i added lots of vasaline to areas that move / rub but didnt help. am going to try new belt when i can get one. Did your santa sound distorted when he stopped moving?
or try this link.
Repairing Singing Dancing Santa
or this one. My Santa quit dancing what can it be Google Search
Dec 14, 2016 | Toys
How do I get Kris Jingle to sing the song. It worked when I bought it a month ago; but, it has quit. I changed batteries that are in the bottom unit.
The foot contains the "on" button, but where does the sound usually come from? If the Santa suit opens in the back, you can check to see if the music box is functional by turning it by hand, if it is the old fashioned type. Maybe something is jamming it? Or it got wet? More information as to what happened prior to it not working would be helpful.
Thank you for contacting Fixya.
Does this help? Let us know.
Mary Oliveau Xx's
Nov 26, 2014 | Sewing Machines
Gas Smell in 2007 Hyundai Santa Fe
to much gas fumes can make you ill thats why you fill or transfer gas in a well vented area --will need to look for what vent ,line or component is causing the fumes
Jul 12, 2017 | 2007 Hyundai Santa Fe Limited
Mouth does not move
Motor operating mouth assembly is bad. The process to remove it is tedious and the motor is specific to the design. This was a common problem with all of the motors in this series. Especially the one operating the mouth. The input pulsing necessary for the mouth to move, was to abusive to the motor, and subsequently shortened its life.
Dec 18, 2011 | Gemmy Bing Crosby Big Head Doll
We've got a santa fe and the sound button is working but the train doesnt move
sounds is run by 3 aaa batteries under the smoke stack and train is run by 6v battery under the seat, 6v battery probably need to be connected or recharged
Jun 06, 2011 | Peg Perego Santa Fe Express Ride On Train
Our Singing Bing Crosby Santa doesn't move his mouth any longer, but his head and microphone still move while he's singing. Can we get his mouth repaired somewhere????
I have had the same trouble. I had to take his head apart and there is a string that is attached to the motor that works his mouth. The string has come unattached and needs fixed. The head is put on with a type of staple around the neck.Take them out and you will see what I mean.
Dec 14, 2009 | Gemmy Bing Crosby Big Head Doll
Gemmy Santa Bear mouth does not move
I would like to first tell you what the problem is with either your Bing or Bear head. Inside the head is a motor that works the mouth. On this rotating motor is a pulley type system, which has a twine or you could call a heavy string piece. It is attached to the motor, and when the is activated it rotates the thread round the spindle on the motor and the mouth operates.. It is quite a difficult to take this head apart. I worked on my Bing for some time to find out this problem.. The string comes away with use and of course time, that is is why the mouth no longer moves. If you wish to try and repair, you first have to remove the head from the base. If you look there are 4 heavy duty staples just round the collar neck area. They will come out with a small head screwdriver or something pointed. Just work it slowly under till staple raises up, then just pull it out. Once they are all removed the head should be loose. This is only to give you access to seeing the internals firstly. Now comes the hardest part. The soft moving part of the mouth needs to be removed. You need to work it of slowly as there is a glue base on it, so care is needed here and can take time. If you managed this all is left is the metal pin it was on. Now inside is the plastic unit that moves the mouth this is glued in which is the main problem. And this is the issue, it is pushed on and the only way is to remove is to have a precision head screwdriver and work it off... Best done by someone who is quite good with their hands and very patienced. Because it may break. Took me severals hours to remove. When you get it off the internal workings will come out of the head. There is no other way of doing this. Having the head loose allows you to look at the piece and the workings. A small torchlight held by someone is best as you work out the mouth fitting.....As i said it is no easy job and took me long periods of time to get to this point. I wish you all the luck in achieving this.......
Dec 15, 2008 | Gemmy Rocky Balboa Big Head Animated...
Gemmy Life-Sized Animated Santa Logo
203 people viewed this question
Top Gemmy Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Gemmy Toy Expert? Answer questions, earn points and help others
