Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
When I turn it on it acts as if it's not connected
When I turn it on power led gives a solid light, all 4 LAN LEDs and WAN LED keep on flashing simultaneously, while status led doesn't give anything and local area connection indicator on my PC says that network cable is unplugged. all LEDs give green light. i tried to solve this by reseting a router, but nothing has changed. by the way all cables I used(3 of them) are working properly. I don't know if that's of any importance but my brother was using it for a few weeks without any trouble, and when I turned it on the first time it was all well except that I couldn't go on the internet, so I had to contact my ISP for assistance and they asked for MAC and I read it to them.
  • 3 more comments
  • ksg0121 Jun 26, 2008
    I have a D-link DCM-202 modem and a dlink Range Booster G WBR-2310 wireless Router. All four LAN lights are on but only have ethernet cable connected. For a temp. fix i have turn both the modem and router off for at least 5 mins. and turn it back on and it work. But this is happening about every other day. Does anyone have any sugguestions???
    Thanks everyone... !!!
  • oxideorange Oct 15, 2008
    WBR 2310 All LED Lights remain in a solid state even if ports are empty. No connection established, reset on modem and router for up to 10 minutes, cables are working fine. What to do now?
  • Anonymous Dec 29, 2008
    Same problem. I called D-Link and the guy got me to shut off the modem and the router, reset the compter, and it still didnt work. when i reset the router it only has one port lit up but there is a flashing lighht and my computer says i have limited or no connection. Im positive i have internet cause it works without the router. What do i do?
  • DrFrank90 Mar 11, 2009
    Same here.
    • LEDs "Power", "LAN", "Ports 1 to 4" : On, solid.
    • Wireless connection : No broadcast.
    • Wired connection : No signal at all (as if cable was unplugged).
    After sticking a pin into the Reset hole for 30 seconds:
    • LED "Power" on, solid; LED "Ready" blinking.
    • Wired connection : No DHCP response ("Limited or no connectivity" on Windows, Just nothing on Linux).
    After connecting a PC to a LAN port with a static IP address:
    • PC - Router communication okay; shows a "Firmware Upgrade" page. No other options available.
    After downloading the proper firmware upgrade (model number + revision match, downloaded latest stable non-beta version 1.05 from; I'm a Canadian customer; filename is, I extracted the archive, giving an image called wbr2310_revA_firmware_105.bin, and fed it to the router through HTTP ("Firmware upgrage page", upgrade.cgi), and let it reboot.
    Result: same as beginning of this post.
    It's the second unit that does this in two years. Called D-Link Canada support line, support representative said she couldn't help me and a "Level 2 representative" would call me two days later at 1pm. They never called back.
  • milost74 Mar 12, 2009
    If I remember correctly, I've solved this by sticking a needle in a reset hole while the router was off, then plugged power with a needle still shucked in the reset hole. Also, the only option was to upgrade the firmware.
    Talking about the firmware, I tried 1.05, but the computer with wireless connection couldn't be online unless the one with wired connection is on, so I rolled back to 1.04
I called D-Link yesterday with the problem. Same as last time: they couldn't help me, and said a better tech would call the next day.
I left the router unplugged from the power for the night.
They called the next day, so I plugged it back in. It worked.
Cheap solution, I know; but you may want to try to unplug the router from the power for about a day. That worked for me. The unit may have overheated or have had a power surge (probably a surge in my case). Another tip: don't stack your router and modem (or any other device) as it causes it to heat up too much. Hope that helps.
Posted on Mar 12, 2009
  • 193 Answers
Contact vendor and ask then to change the firm ware if its not taking it replace the device
Posted on Oct 09, 2007
  • ramji duraiswamy Oct 13, 2007
    have u contact ur vendor
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
Right motor wiring fault
Three red LEDs Three yellow LEDs
Inhibit active
Three red LEDs Four yellow LEDs
Joystick error
Three red LEDs Four yellow LEDs One green LED
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Oct 05, 2017 | Pride Health & Beauty
SMCWGBR14 N only power led
1) Power on the SMC modem / router and wait until all the lights are light up.
2) Press and hold the reset button for 15 seconds and wait until all the lights are light up as the modem / router needs to reboot.
3) Try to access to the admin page again by default login IP -
4) Enter the default login password.
a) smcadmin
b) (blank)
c) barricade
Nov 25, 2013 | Edge Barricade 4 Port Broadband Wireless...
INET light is on not able to connect to internet
Checked the instruction manual online. There's no INET light indicated. There's Power, Status, WAN, WLAN, and LAN LEDs. The WAN LED only indicates that the WAN port is connected to another device, e.g., cable or DSL modem. Check on your cable or DSL modem to see if the Internet light is on. If so, then you'll need to log into your router and go through the configuration/setup per the manual for your type of connection.
Oct 18, 2013 | D-Link 802.11g Wireless Router WBR-1310...
Note that incoming traffic will cause the WAN (or Internet) light to blink even if it is 'probe' traffic trying to break in to your network. Such traffic is to be expected and is the reason you have firewall functionality in your gateway router.
On the inside, there is a bit of traffic on any LAN when the computers are turned on. Messages generated by the router itself are used to find computers and printers for a lot of different legitimate reasons.
Feb 25, 2013 | Linksys Wireless-G WRT54G Router
I have RV082 Router , and Diag Led is constant what to do
Checking the Router's LEDs
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router check the lights on the front panel of the router.
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router, the following should be lit:
  • 1 - 8 (LAN)
  • DMZ/Internet (WAN2)
  • Internet (WAN1)
  • Diag
  • System
Step 1:
Make sure the System LED is lit.
NOTE: If the Diag LED doesn't goes off, you need to upgrade the router's firmware. For instructions, click here .
Step 2:
Make sure the LAN 1-8 ports is lit depending on the computers connected to the designated Ethernet port.
NOTE: If the LAN 1-8 port is not lit, make sure that the computer is powered on. You can also try connecting the PC using another working cable.
Step 3:
Make sure the Internet (WAN1) and DMZ/Internet (WAN2) LED is lit.
NOTE: If the Internet or DMZ/Internet LED is not lit make sure the Broadband modem is powered on and that the modem is properly connected to the Ethernet port
You can access the web-based user interface utility of the RV082 by using one of two methods:
  • Through the RV082 IP address ( by default), or
  • Through its default hostname ("RV082")
1. Open a web browser (Internet Explorer or Netscape Navigator)
· By IP address: Type ( is the default IP address of the RV082)
and click Go or press the [Enter] key.
· By Hostname: Type http://RV082 and click Go or press the [Enter] key.
2. When the username and password prompt appears, type admin in both the username and password fields. (admin is both the default username and default password for the RV082).
Nov 08, 2010 | Linksys RV082 Router (RV082-AU)
My dell dimension 8400 canot boot up at all and the Diagnostic Lights not light wat i can do?
The POWER and DIAG LEDs can give you information. If no DIAG LED look at the POWER LED
Flashing amber, most likely the power supply
Solid Amber, motherboard or item plugged into the motherboard (Expansion card, external connection etc.)
Apr 17, 2010 | Dell Dimension 8400 PC Desktop
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
Screen will not come on hard drive light no light checked power supply is ok
Things to check:
  1. Power led on the front of the tower, it should be solid green when on. Flashing Amber is generally an indication of a bad power supply inside the tower
  2. Power LED Solid AMBER indicates system is not finishing the power on self test (POST) and you remove all connections from the tower except power and try turning on again. If no change, remove all PCI and PCI-E cards from system, try again, no change replace motherboard.
  3. On the back of the tower are 4 diagnostic LEDs near the ps2 ports marked ABCD, after the POST, during a normal boot the will flash in several sequences and with boot is finished all 4 should be green. If they stop an a different pattern, then that indicates a failure Yellow Yellow Green Green indicate bad RAM for example
  4. If the LEDs on front and back are Green then the system appears to be booting but the monitor display is not functional
Feb 05, 2010 | Dell Dimension 4600 PC Desktop
For dummies
Hello, Good question..Phone line to DSL modem, Ethernet cable to WAN port on Router. If connecting a PC wired to Router, connect Ethernet cable from 1 of 4 LAN ports on Back of router to ethernet port on PC. This would be Physical connection...
It's always smart to set a restore point in case something goes wrong during installation of any program. For wireless connection from laptop or PC: install router software on computer. Reboot computer. In browser address bar enter This brings up a window for user name and password. Enter "admin" for both. This allows you to change many settings including Changing SSID(Router Name), User name and password. Enabling WEP or WPA security. Hope this Helps, Good Luck..!!
Mar 26, 2008 | NetGear RangeMax WPN824 Wireless Router...
Problem after firmware update Edimax BR-6114Wg
Hi Fklco,
Why are you connecting the WAN,, (the internet modem cable), to the standard ports? It should have a WAN port, for the cable from the modem, and a LAN for the cables to the computer?
On the other hand, if it is working, I would leave well enough alone, :D
Jan 06, 2008 | Edimax BR-6114Wg Router (BR6114WG)
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
687 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
