Question about HP Officejet 5610 All-In-One InkJet Printer
Popping noise when scanning - HP Officejet 5610 All-In-One InkJet Printer
  • 33 Answers
R u capable to remove ADF from Printer ? if yes ? Make sure printer's power is off.
remove ADF from printer , clean 2 paper pickup roller,Pad, gears and sensor. reinstall ADF properly to printer. now turn it on. may be prob will solve.
Posted on Nov 24, 2013
Testimonial: "was a broken gear."
  • Abhay Mar 20, 2014
    may be or dust prob.
I was stopped at a stop sign and when i accelerated my car started moving then made a popping noise and stopped moving. Now it will only move in reverse and first gear. What is wrong with it?
Sounds like a similar problem that I had. I bet the check engine light is on. If so have vehicle scanned for codes. You most likely popped something in transmission.
Jul 29, 2016 | Cars & Trucks
Popping noises
r u capable to remove ADF from Printer ? if yes ? Make sure printer's power is off.
Nov 18, 2013 | HP Officejet 5610 All-In-One InkJet...
Good Evening, I have a i420 Kodak Scanner when scanning in images it makes this high pitch screaming noise.
I highly doubt the main board is going bad. There is a huge difference between an electronic high pitched noise vs a scanner noise. Does the noise only occur while scanning or when parts are moving? If yes, then a scanner noise. If the noise is on all the time even when idle, then you have an electronic noise like an open or leaking capacitor.
On this particular model the seperation idle roller builds up with paper dust and will cause a high pitched noise. Like nails on a chalk board. Very simple fix. Open cover. Grab seperation assembly and pull toward the tray at the front of the scanner, it will pop loose then lift up. Make sure to pop it back into place good. Be forcefull. With the assembly in hand, clean, and lube idle roll. It is the first metal/plastic roll the paper touches at the tray entrance. Also clean the shafts and bushings for the rubber rolls. Reassemble and you are all set. Happens on EVERY I420 scanner I have seen.
May 10, 2011 | Kodak i1440 Pass-Through Scanner
The check engine light came on and we started hearing a popping noise in the gas tank after moma went to an out the way gas station instead of going to our regular gas station that we always go to. The...
The ck engine light is telling you to have it scanned and it will have a trouble code to indicate where to look for the problem. You may have a Vent valve or purge valve problem, it may just be a coincidence that it happened after filling up.
Dec 04, 2010 | 1997 Chevrolet Lumina
Just tell me how to scan, it's just making a noise. I forgot how to use it. I attached it to my laptop, the light on and it is making a scanning noise, but nothing is popping up on my screen. Please help.
there a stucked scan mecanism, you nedd to open-it and clean-it, but is very fragile mec. need a sensitive hands, not damage the lents, plastics or cables. good luck
Dec 25, 2009 | Office Equipment & Supplies
I was driving and heard a pop noise and then my 97
could be the timing chain. Was it a pop or more like a ping . A ping could indicate a timing chain problem. The tensioner might have gone bad.
its not hard to replace for an experienced mechanic
Jul 05, 2009 | 1997 Pontiac Sunfire
Radio Problems
Check your wiring harness from the radio to the speakers, as well as the wiring to the speakers themselves. If the insulation is gone, sometimes that open wire will cause that noise. Or, the plug off the back of the radio to the speakers could be loose.
Oct 17, 2008 | 2004 Dodge Ram 1500
HP Officejet 5610 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
