Question about Black and Decker USA Black & Decker FP2500B PowerPro Food Processor Refurbished BLACK
Loud noise from the back of the the unit
Noise coming from the back
Noise like an airplane coming from underneath towards back. Starts from first moving and gets louder with more speedlouder
Could you nr a bit more specific about where the noise is coming from? If the noise is coming from your engine compartment I would guess you have a large vacume leak. If it is coming from say the very back of your car it may be that your exhaust has been damaged or blown a hole in it which could create that noise. Or it could be something as simple as a wind whistle noise I have seen many times where a plastic cover underneath the car has come loose or had clips broken not to where it will fall of or drag but it will catch the wind just right to make a hell of a lot of noise. Just a few things to check that come to mind. hope this helps
Apr 24, 2015 | Cars & Trucks
My iphone 5c will not ring how do I turn the ring ton me back on?
on the left side on the phone, theres a switch, turn it on
Oct 11, 2014 | Cell Phones
Lg tv humming noise when tv is on
The humming noise is most likely coming from the power supply.
If the unit is worth the repair cost ( Over $100.00 ) you should have it repaired.
If not, deal with the noise until it goes out.
May 12, 2014 | Televison & Video
Grinding noises coming from the back the gears
I had a similar problem on my hp printer.
If you you still have the warranty, please use it.
otherwise, take a look:
http://www.fixya.com/support/t2199521-hp_laserjet_1200_making_terrible_noise
Sep 13, 2013 | Kyocera FS4000DN Information Technology
New A/C Unit makes loud noise when it starts up
It shouldn't be too loud. You don't explain where the noise is coming from? The air handler/furnace or the outdoor unit.
Jun 13, 2013 | Heating & Cooling
New AC makes loud noise
I would call contractor back
Lound vibration when running
Check gas control valve.
Good luck,
Marty
Feb 18, 2013 | Rinnai Water Heaters
Makes a really loud buzzing noise during operation
Unit uses a Magnetron and likely a power board called an inverter to run it. Someone would have to open the unit in a way where they might pinpoint where the sound is coming from and then take action--does not of course sound normal or good to me.
Dec 10, 2012 | Samsung SMH1622W
When on spin getting a lot of vibration and noise
inspect the shock absorbers if noise is coming from the back during spin cycle
Dec 06, 2012 | Washing Machines
Kitchenaid refrigerator making rattling noise
YOUR ARE GETTING ICE AROUND YOUR FREEZER FAN BLADE THAT IS THE NOISE YOU ARE HEARING IT COMES FOR THE ICE MAKER FILL TUBE THAT COMES IN FROM THE BACK WALL OF FREEZER TO THE ICE MAKE YOU CAN'T DO ANYTHING TO FIX IT JUST MAKE SURE YOU HAVE NO ICE BIULD UP IN THAT TUBE IT MAKES IT LEAK DOWN ON YOUR FAN
Oct 30, 2012 | Refrigerators
Black and Decker USA Black & Decker FP2500B PowerPro Food Processor Refurbished BLACK Logo
264 people viewed this question
Top Black and Decker USA Home Experts
Terry Hair
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you a Black and Decker USA Home Expert? Answer questions, earn points and help others
