Question about HP Officejet 5610 All-In-One InkJet Printer
Popping noises popping noise when scanning using ADF
  • 33 Answers
R u capable to remove ADF from Printer ? if yes ? Make sure printer's power is off.
remove ADF from printer , clean 2 paper pickup roller,Pad, gears and sensor. reinstall ADF properly to printer. now turn it on. may be prob will solve.
Posted on Nov 24, 2013
Beeping noise when copying
CLEAN THE FEED RUBBER OF YOUR ADF, OR THE SENSOR. OR REPROGRAM ADF
Mar 26, 2014 | Canon imageCLASS D880 All-In-One Laser...
Popping noise when scanning
r u capable to remove ADF from Printer ? if yes ? Make sure printer's power is off.
Nov 18, 2013 | HP Officejet 5610 All-In-One InkJet...
The scanner is making a noise while scanning
Hello Rita,
The noise produced when the gears in the ADF upper unit is worn off. You are recommended to contact a Fujitsu expert for replacement of the faulty gears. You may also contact scancare.bbs@gmail.com for more details.
Thanks,
ScanCare
May 22, 2013 | Fujitsu ScanSnap S1500M
Fujitsu fi-6140 scanner making ticking noises during scanning
The tick tick noise is produced when the gears in the ADF upper unit is worn off. You are recommended to contact a Fujitsu expert for replacement of the faulty gears.
Thanks,
ScanCare
Jan 25, 2012 | Fujitsu FI-6140 Flatbed Scanner
Good Evening, I have a i420 Kodak Scanner when scanning in images it makes this high pitch screaming noise.
I highly doubt the main board is going bad. There is a huge difference between an electronic high pitched noise vs a scanner noise. Does the noise only occur while scanning or when parts are moving? If yes, then a scanner noise. If the noise is on all the time even when idle, then you have an electronic noise like an open or leaking capacitor.
On this particular model the seperation idle roller builds up with paper dust and will cause a high pitched noise. Like nails on a chalk board. Very simple fix. Open cover. Grab seperation assembly and pull toward the tray at the front of the scanner, it will pop loose then lift up. Make sure to pop it back into place good. Be forcefull. With the assembly in hand, clean, and lube idle roll. It is the first metal/plastic roll the paper touches at the tray entrance. Also clean the shafts and bushings for the rubber rolls. Reassemble and you are all set. Happens on EVERY I420 scanner I have seen.
May 10, 2011 | Kodak i1440 Pass-Through Scanner
Brother MFC 9440CN - I am getting "Document Jam"
Take the cover off of the ADF, rub clean the rollers with a damp cloth. Make sure there is no paper stuck in the area Also, check that the sensor flags are activating. just move them back and they should bounce back to normal position. Cleaning should do the trick.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
Jan 21, 2011 | Brother MFC-9440CN Laser Printer
Just tell me how to scan, it's just making a noise. I forgot how to use it. I attached it to my laptop, the light on and it is making a scanning noise, but nothing is popping up on my screen. Please help.
there a stucked scan mecanism, you nedd to open-it and clean-it, but is very fragile mec. need a sensitive hands, not damage the lents, plastics or cables. good luck
Dec 25, 2009 | Office Equipment & Supplies
Documents will not feed from the ADF
Is there a more permanent fix in the meantime? I'm just tired of fiddling each time that I use the ADF
Jul 03, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Xerox 510 will not scan from ADF
If it is new, and not assuming there is a hardware problem with the scanner (some fault), might be a software problem. If the scanned image from the flabed is OK the drivers would be installed properly. You do not say which software you are using but when you have a "Professional" documentscanner and intend to use it for "production" scanning you need proper software also, To scan, to mix documents, rearrange pages, auto remove blank pages, deskew, produce small PDFs even when scanning color and so on. Look at PixEdit - it will do the job for you.
Jul 16, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Hello, I have an HP OfficeJet 7310 all-in-one print/scanner/fax etc. I purchased about two years ago but don't use very often. Yesterday while I was trying to send a fax I received a loud winding-up...
I have same problem! The copy/scan function would feed the orginal from the ADF halfway and instead of making a normal loud feeding noise it made a horriable alarming sound and displayed an error message. To fix it: I waited a day or two and bang the top of the feeder cover with normal force while the original is feeding. It appeared the problem is resolved. I have no idea what the problem is, however I think if this work for few months at a time is fine by me.
Apr 12, 2008 | Office Equipment & Supplies
HP Officejet 5610 All-In-One InkJet Printer Logo
43 people viewed this question
Seeker5211
Seeker5211
