Question about White Sewing 1418 Mechanical Sewing Machine
Manual I need manual for my machine tipe singer samba 4 thank you
Hi the light works on the singer samba 2 but the pedal doesnt, any ideas, I havent thread any cotton through it would that make a difference, thanks
The light will work even if the pedal isn't functioning. The foot pedal in your machine sounds like it needs to be repaired or replaced . To make sure that your machine isn't the problem you can plug a friends pedal in just for a trial run.
Oct 30, 2014 | Sewing Machines
Singer samba 4
You can search the internet for parts http://lmgtfy.com/?q=singer+samba+4+parts Thought that was cool Try the iPhone App or Grab Some Stickers or Craigslist or garage sales.
Aug 01, 2014 | Singer Sewing Machines
How to thread singer samba 4
what's the model number?
would you like to see if there is a manual available for the machine?
sewusa.com has some threading diagrams
Jun 04, 2012 | Singer Sewing Machines
Singer Samba 6 sewing machine
It would be wise to have the machine cleaned & serviced. Do you have a manual for it? Did it come with oil at one time? I found a free manual at
http://homeappliance.manualsonline.com/manuals/mfg/singer/7442.html
You have to register (free)...choose to skip the popups (2)...and you can save the manual to your hard drive.
I checked the manual...you don't need to oil the machine...but page 61-63 shows cleaning...and it's basic. You take the two screws from the throat plate, remove the bobbin case & brush the inside of the machine bed out...I use a small artists plastic bristle brush, or a small childs tooth brush.
Hope this helps.
May 14, 2010 | Singer 7442 Mechanical Sewing Machine
How do i thread a singer samba 1 correctly?
Thread on the reel pin, make sure the presser foot is up and the takeup lever at the top, take the thread to the left and through the top guide which is directly above the tension unit, take the thread down the right hand side and round the tension unit back up the left side to the take up lever, thread the takeup lever right to left, follow the guides all the way down to the needle and thread front to back.
Feb 27, 2010 | Sewing Machines
I need a bobbin for my singer Samba 4
You can get the bobbins very cheaply on ebay or from your local Singer or dealer, you must use Singer bobbins.
Oct 20, 2009 | Sewing Machines
White Sewing 1418 Mechanical Sewing Machine Logo
23 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
