Question about Kitchen Ranges
Kenwood ks100g gas oven
Gas does not stay alight when ignited
SOURCE: EUROLEC 3572 9506 LPG GAS OVEN
OK sista62, here is your solution. The problem is that the thermocouple that controls the valve supplying gas to the ovenjet is not working. A new thermocouple is available from http://blgas.com.au/online/category4_1.htm and will cost about AUD$40.00.
The control valve is located right behind the knob on the frontpanel (the centre one that controls both the oven and the grill.) You will see two small copper tubes going into the control valve. These are the thermocouple tubes, one comes from the griller and the other from the ovenjet. All the other knobs only have one thermocouple for each of the topplate burners.
If you want to test before you buy, disconnect the thermocouple from from one of the topplate burners and connect it to the one for the oven control valve. Now turn on the topplate burner and keep it going by holding the knob down on the front panel for this burner. Now light the oven burner and it should stay on.
Good luck.
Posted on Feb 01, 2008
jumptrout51
  • 3361 Answers
SOURCE: Oven ignition: gas goes out as soon as control knob is released
Replace the oven thermocouple.
Posted on Mar 15, 2009
  • 23 Answers
SOURCE: The oven of GE Profile range simply stopped igniting
If it is a ge it would have a glow bar ignitor, either a flat rectangle shaped or a round ignitor. That is want the problem is 95% of the time. It is pretty easy to do. The floor of the stove will come right out and it probably has two screws in the back corners you can see. Remove them and the floor will lift out and you can see the burner and the ignitor.
Posted on Jun 20, 2009
protek480
  • 1714 Answers
SOURCE: Igniter working, can smell gas, but gas not getting to burner
Gas valve is not working. Replace
Posted on Jul 23, 2009
tbirdfan1
  • 3051 Answers
SOURCE: gas oven won't light. igniter
Hello there i got disconnected pleas reenter the chat
Posted on Nov 26, 2009
Burner ignitors stay on after burner is lit
Nothing bad can happen if the ignitors stay on but it can be annoying. I remember reading something about this I will try to look it up again.
Mar 26, 2008 | Jenn-Air PRG3010 (NP) Gas Kitchen Range
Grill gas comes on but on release of grill knob, the gas goes off.
I would arrange a service call from a registered gas safe engineer.
Apr 13, 2017 | Electrolux Ovens
Oven will not stay on
try turning the gas up slightly and holding the knob down a few seconds longer after it is alight.
Feb 09, 2013 | Bertazzoni Gas Range
Westinghouse oven LPG 527 wont stay alight and grill wont start
Normally the grill is completely separate to the oven. Press the ignitor before you turn on the grill, as, to ignite, oxygen needs to be present (ie: not flooded with gas) . and you should be able to see the spark from the ignitor in the grill. if you can't, then you may have problems with your ignition pack or ignition leads.
Feb 16, 2012 | Ovens
My ovens wont stay alight i have a twin range gas oven and it just wont stay lit but if i hold the knob in it stays lit
I offer free advice bcuz God is so good!
GAS OVENS
The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
: I offer free advice bcuz God is so good!
Jul 31, 2011 | Belling Ovens
Smeg gas hobs ignite immediately but flame goes out when i let go of the igniter. I have to hold it down for a very long time befor it stays alight. this is time consuming and not right. What is the...
depending on what you mean by " a very long time " -- holding down the gas valve button while the thermo-coupling gets up to the proper temperature is normal. ( normal hold and wait time should be between 10 to 25 seconds, anything longer than that is a sign that the thermo-coupling is bad ).
c...
Jan 02, 2011 | Microwave Ovens
Quattro Plus heater will not stay alight
Does this unit have a thermocoupling?
If so replace it. (6 bucks)
It is the units flame sensor and they routinely go bad.
When they no longer sense flame the unit will shut off gas to the ignitor/burner.
It will only stay lit when you are manualy holding the button.
Dec 03, 2008 | DeLonghi Heating & Cooling
Kitchen Ranges Logo
109 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
