Question about Crafts & Hobbies
How to remove crazy glue from my finger tips - Crafts & Hobbies
Remove crazy glue from glass
Crazy glue crystallizes when in cures; when it sticks on glass it can be scrapped with a sugar edge razor, or other sharp edge object.
Mar 08, 2015 | Cars & Trucks
How do I remove krazy glue on finger tips?
Use an acetone-based nail-polish remover.
Sep 20, 2014 | Cars & Trucks
There is no way to remove it, other than file it down or scrape it off.
Dec 06, 2013 | Crafts & Hobbies
Broken key in ignition of 1995 nissan 200sx...Any helpful tips on removal? Im using dental tool picks and anything else small enough to fit...
I use crazy glue and some patient and work fine. Put a little on the other side of the broken key, push back into ignition and hold for a couple of minutes until dry, when removing pull fast, if fail try again. I have a Sprinter and the keys are prone to breaking already happen twice and both time I got it out with crazy glue.
Oct 18, 2013 | Nissan 200SX Cars & Trucks
What solvent will remove crazy glue from sktn
Acetone or ordinary nail polish. See here.
Mar 06, 2013 | Car Audio & Video
HOW TO REMOVE CRAZY GLUE FORM ARBORITE
I would try either:
a) a razor blade and hot soapy water
b) acetone (nail polish remover)
c) if there is alot of it and neither of the previous 2 solutions worked, you can buy superglue solvent
Dec 14, 2012 | Elmer's Instant Krazy Glue
How do I remove crazy glue from control panel? The cover over the plus control(to raise oven temperature) was coming off so I thought I would glue it back on! Bad idea ....now that control remains...
Not to much can repair / remove the crazy type glues once they are applied to plastics and plastic overlays. Some people attemp to use these not knowing that some types of plastic will not bond. most of the solvents that can desolve the glues will also damage the panels.
Mar 27, 2012 | GE Microwave Ovens
How can I remove a lodged oil dip stick? Top part of grip has broken off. Someone tried to remove it but lodged it in further down.
Needle nose plyers.
If those wont reach in far enough - you might have to remove the dipstick tube..
Jul 22, 2009 | 2004 Nissan Sentra
Tray Error
Paper switch has been knocked off. Remove the tray and look inside about halfway in, on the right side near the gray roller that grabs the paper, you will probably/hopefully see a black switch (LED), with a retractable 'finger' that 'swings" in and out, which is what detects the paper. Hopefully the finger hasn't been broken off. The switch may be hanging down. If you have the extra tray installed on your copier, check it, to see how it "clips on".
If the clipping mechanism to attach it to the frame is broken, you can try gluing it in with crazy glue, or ABS cement is the best.
Please rate me.
Mar 30, 2009 | Ricoh Aficio 180 Laser Printer
Razer Krait Mouse's Roller too smooth, it slips from my finger
try putting a little super glue on the tip of your finger and spread it around .. wait for the glue to dry and see what happens .... it works for me and glue will come off
Mar 23, 2009 | Razer Krait Mouse
Crafts & Hobbies Logo
50 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
