Question about Fisher Audio Players & Recorders
Fisher receiver rs 737
I have a fisher receiver rs 737. The standby button is lit, however when I push the button to turn the unit on to full power nothing happens. What can I do to resolve this problem?
No answer, but...
I have a similar problem... I can power up my rs-911, then about 3-5 sec. later, it shutsdown (standby light still on)... What in the tarnation is going on? All 3 fuses are OK.?.
Posted on Feb 03, 2015
JULIANFIX
  • 975 Answers
SOURCE: dead
IT COULD BE A FUSE , needs to be replace , if your handy , you can do it yourself , open unit , and check where the power supply is .look for a tiny glass tube type fuse , replace , and try again , hope this helps , please rate , AJ
Posted on May 07, 2008
  • 4234 Answers
SOURCE: Kenwood Receiver KR-a5020 receiver won't come out of standby
The unit is in what is commonly known as "protect" mode. This means that a problem has been detected in the final output stage of the amp and the outputs are shutdown to prevent further damage to either the receiver or speakers. This should not be a difficult repair for a service shop. Expect a parts cost in the $25-$40 range. Add in the local labor rate for the total repair cost.
Dan
Posted on Nov 28, 2008
  • 3 Answers
SOURCE: brand new avr588 receiver is turned on....is on for five seconds and then cuts off to standby
Hi donnie025,
I can't believe you haven't received an answer before now.
The red flashing light normally indicates that the protection circuit has been tripped. It can be caused by something as simple as a short in a speaker wire. Even if there is one strand of loose wire that makes contact with the back of the receiver, another wire, etc. it can cause a short. To protect itself the receiver will simply shut down.
1st. I would suggest disconnecting all the speaker wires from the back of the receiver. Then turn on the receiver (obviously you won't hear any sound) and see if the receiver does the same thing. If it does you should try disconnecting all of the source components (DVD player, Cable box etc.) and try again. If it still does it the receiver is bad and needs to be serviced or exchanged if you still can.
2nd. If the receiver stays on after you disconnect, then turn off the receiver and connect one speaker at a time, then power on the receiver at test it after connecting each speaker. This way if it suddenly shuts down after connecting a speaker you know which speaker or wire to check.
Let me know how it works out for you, I hope this helps if you haven't figured it out already.
Matt @ OneCall
www.onecall.com
twitter.com/onecalldotcom
Posted on Feb 28, 2009
SOURCE: Kenwood vrs-7100 surround sound receiver turns on and shuts off
The audio amplifier IC are fried
Posted on Aug 12, 2009
Bulldog AV
  • 52 Answers
SOURCE: after turning ON the power/standby switch, the
Is the red light flashing at first?
The unit may be going into protect mode. Lets hope it has done the job and the receiver has protected itself from failure.
Protect mode can result from speaker wires touching each other or the Amps2_bing.gif metal case. Check that first.
It can also be caused by unstable ohm loads if too many speakers2_bing.gif are connected to any of the outputs especially zone 2.
If you can remove all speaker wires and turn the unit back on. If it stays on, turn the volume down on the main zone and zone 2 if connected. Then reconnect speaker wires.
Posted on Nov 24, 2009
How to fix power button on model 737 fisher receiver
open the top cover, remove the front panel cover , find the micro power switch and clean it with a contact cleaner
Nov 29, 2016 | Fisher Audio Players & Recorders
What would cause a Fisher RS-884 to not power on?
start checking with your power soket, then power cable, and electrical fuse on unit. Furter is power supply or worse...
Nov 05, 2014 | Audio Players & Recorders
What can I do with a amp tuner fisher rs-851 in standby?
If by "standby" you mean the amp is trying to power up, check for speaker protection issues. Speaker wires and/or speaker issues may be causing the speaker protection mode to keep your Fisher speaker lines disconnected from amp.
Jun 02, 2014 | Audio Players & Recorders
Stuck in standby mode on Fisher RS-911A receiver
Does it power up or straight to standby? If it is on but in standby it could be speaker protection issues...check speaker wires and/or speakers for issues. If it's straight to standby and no power, it's repair shop time.
Jan 02, 2014 | Fisher Audio Players & Recorders
Power Problem with Fisher RS 9015
Glad it helps, thanks also for choosing Fixya for assistance!
Aug 13, 2012 | Audio Players & Recorders
Today i went to turn on my receiver and the standby light is on, but wheni push the power button nothing happens.
Try to unplug the AC cable from the wall for a couple of minutes, in order to clear any trouble program. Then plug in AC cable again, with power button off, and press power on in receiver. Do not attempt to use remote for a while. Hope this will help. Flavio/Brazil
Sep 18, 2010 | Audio Players & Recorders
None of the buttons on front panel works. I pressed each one but nothing is happening. I just got this through ebay.
Turn the power button on. It should light the switch. Turn it on from standby, it should light up the front panel. Then the switches should work.....unless one of the buttons got pushed in during shipping and it is still stuck in the pressed position. Check that all the switches push back when pressed.
Mar 18, 2010 | Harman Multimedia AVR-354 Receiver
I have an Onkyo TX-8511 Receiver. The unit has power because the standby light is on, but nothing happens when I press the power button or try and turn it own with the remote. I have Onkyo HTS907 that...
You have two devices that won't power on. Doesn't that suggest a source power problem? Did they ever or never work where you are now or anywhere else? Or did you just come back from overseas and forget to set them up for U.S. power?
And you're not daisy-chaining the two units together, are you? That's a no-no. There's a wattage limit to what can be connected to the convenience outlets. Power amps are not usually supported.
Try isolating the two units and shoot each bug separately. Plug them in somewhere else. Disconnect speakers and try again.
C'mon back with the results.
May 08, 2009 | Audio Players & Recorders
379 people viewed this question
Top Fisher Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
SHARCNET-USA
SHARCNET-USA
Are you a Fisher Audio Player and Recorder Expert? Answer questions, earn points and help others
