Question about Atlas Translator Marcato Atlas 150 Handle for Atlas 150 Pasta Machine
Need a crank - Atlas Translator Marcato Atlas 150 Handle for Atlas 150 Pasta Machine
York C202 crank arm tighten
Here is an article on changing and tightening normal bike crankarms. It should apply to your bike too. If you see a plastic cover, try to take it off and see what you're dealing withm How to Tighten the Crank on Bike
Feb 09, 2017 | Cycling
How do I remove the crank arms
You need a tool like this
Bike Bicycle Cycle Crank Extractor Remover Puller
Sep 23, 2016 | Cycling
Stripped bicycle pedal
Better replace the pedal and most probably the crank arm as well. Sometimes a new pedal can cut the threads true again on the crank arm but the crank arm may need replacement too, depending on the damage. Remember to fit the correct side pedal. The pedal threads differ between left and right and pedals are usually marked "L" or "R".
Jan 04, 2014 | Huffy 26" Womens DS-7 Dual Suspension...
Cranks and then leaves u stranded
if it's not a battery problem. Replace your crank
Jan 02, 2014 | 1998 GMC Jimmy
Changing a crank sensor on a 3.4l 2003 pontiac grand am
If you need to replace that sensor than yes you need to pull the crank pulley. There are two crank sensors on this vehicle. One behind the crank pulley and on on the back side of the engine in the block. Make sure ou are replacing the correct one.
Aug 12, 2012 | 2003 Pontiac Grand Am
Loose crank
It sounds like it is probably a "cotterless" crank, which is now fairly common on modern-day mid to higher level bicycle. These cranks are mounted on the tapered ends of a hardened steel axle. The cranks are aluminium alloy and are easily damaged so they need to be protected when you are tightening them. To properly tighten a cotterless crank, remove the covers that are threaded into the crank over the bolts securing the crank to the axle. Place one crank against a solid point of support (centered on the axle) but protected from damage with a block of wood. Use another block of wood (centered on the axle) with moderately heavy (2 lbs or so) hammer. Strike block of wood as close as you can to the centerline of the axle several times with a heavy blow (like you would need to drive a 16d framing nail). Then tighten the bolts that secure the cranks to the axle and replace the dust covers. Provided the crank didn't become so loose that the tapered sockets on the cranks became mis-shapened, this should solve your problem.
Aug 12, 2012 | Cycling
When i am pedaling hard there is a loud clinking noise, im assuming from my crank. is my crank lose or does it need to be replaced? I've checked to try and remove it myself but can find any screws,...
You need a crank puller. In the centre of the crank, there should be a nut or a cover of sorts, pop the cover off with a screwdriver or other flat tool and then unscrew the nut with a ratchet set or, if you have it the proper bike tool. then use the the crank puller, to pop off the crank. Also, odds are the wrattling sound is your bottom bracket and not the crank. Good luck.
Sep 11, 2011 | Haro Flightline Sport
Can i convert my old one piece crank to a three piece crank using eastern nomad cranks
Yes, but you will need a new bottom bracket (BB). You will need to buy a sealed American type BB.
Dec 26, 2010 | Eastern Nomad BMX Bike Crank 175mm Red
V belt broke rapped around crank pully broke sencer wont crank
The crank balancer pulley needs to be removed so the crank sensor can be replaced. You will need an air impact wrench to remove the pulley bolt and a puller to remove the balancer.
Sep 24, 2009 | 1993 Buick Regal
How to disassemble crank bearing on Schwinn Mesa Mountain Bike
You wil need a couple of special tools, or be fairly creative with the tools you have.
  1. remove the dustcovers in the crank arms at the crank axle
  2. loosen the crank retaining nut/bolt.
  3. thread in a chank puller and pull the crank arms.
  4. remove the lock ring on the adjustable side of the crank axle (Requires lock ring wrench)
  5. remove adjustable bearing cup.
  6. remove axle and bearings
  7. replace or repair as needed.
Once you have it opened up ou can determine if you need new bearings or crank axle.
to assemble, reverse above procedure, insuring bearing play is minimalized.
Hope this helps.
Ed
Apr 16, 2009 | Schwinn Mesa Gs Mountain Bike
Atlas Translator Marcato Atlas 150 Handle for Atlas 150 Pasta Machine Logo
Top Atlas Translator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you an Atlas Translator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
