Question about Asko WCAM1812 Front Load Washer / Dryer
Detached black wire from heating element
I pulled a little too hard and detached the plastic/metal connector piece from the actual wire. If anyone knows the jargon I can use to order a new plastic/metal piece, I'll appreciate it.
    Scholar:
  • 155 Answers
You pulled the wire out of the terminal. You need a crimp tool and a terminal of the proper size to crimp the wire back into a terminal. Not hard to do if you have the proper equipment.
Do not solder a wire to a crimp terminal!
Posted on Nov 18, 2013
Testimonial: "Thanks, brah. And I've learned something new today."
How do I repair detached incase wiring
Heating element connections r riveted together - u can't solder them as it would melt when running.
If the wire detached at the element it is near impossible to reattach it.
U would have to remove the rivet and replace it with the wires connected. My experience is that the mica that it is attached to is too fragile to get the ribvet removed.
Oct 06, 2014 | Welding Tools
Asko WCAM 1812 wire
CANT U JUST ADD A NEW WIRE U CUT AND SPLICE INTO IT? ADDING A CONNECTING END
Nov 18, 2013 | Asko WCAM1812 Front Load Washer / Dryer
Maytag Dryer MDE3706AYW has a burnt black wire, did the wire just have a bad day or do I need to replace the heating element and the wire?
All should be good. I think the element had run on due to a bad hi-limit thermostat that you said you replaced.
Oct 17, 2012 | Maytag MDE3706 Electric Dryer
Chipset heat sink not detected system halted
Open the computer. You will probably see a metal wire that looks like a stretched out paper clip over a square black piece of metal. If one end of that is detached from the system board, that's the problem. To repair requires a tech to re solder the clip.
Jun 13, 2012 | Dell Computers & Internet
Dvd tray will not open
Had same problem. Unscrew back TV. Unscrew 2 screws connecting VCR/DVD from TV Base. Unscrew DVD housing on all sides (approx 6 screws). At this point you can see the detached DVD unit. Facing the draw. look under it for a white plastic piece that you can slide to the right that should disengage the DVD's circular rotator from the dvd and slide the door open.
If that does not work disconnect the DVD from the 2 wire connector at the TV motherboard and dissassemble the black plastic DVD unit. Flip it over and manipulate the white plastic gear which will disengage the center rotator.
Sep 08, 2010 | Toshiba MW24FN1 24 in. TV/VCR/DVD Combo
How do i troubleshoot my kenmore model 110 electric dryer. it does not heat while it tumbles. How do I know for sure that it is the heating element.
ok first unplug dryer on the side of the heating element housing you will see the high limit switch black plastic with a sticker and a metal nose pull the 2 wires off check for continuity with ohm meter should be closed if it reads closed put wires back. Now look for a white ceramic rectangle piece it is a thermal fuse pull the wires and chech continuity if it shows closed it also is good. if either of these show open they need replaced. Now if both showed closed unplug wires from heating element check continuity should read continuity. if open element is broken. Now assuming this all shows good. Then it could be the timer or the centrifical switch on end of motor.
Jan 08, 2010 | Kenmore 84832 Electric Dryer
My 2000 e46 bmw heater blower not working, i've checked the fuse
The E46 blower resistor is harder to remove than the E39 .
Open the Glove box.
Remove the three phillips screws across the top of the open box. Remove the two phillip screws that are deeper in on the sides of the open box(nine and three o'clock). Hard to see, use your flashlight. With these five screw removed remove the glove box. Disconnect the flashlight charger plug, and the glove box light connector. Pay attention to the wire routing. Remove plastic cover behind glove box. Locate motor and metal link to one of the a/c doors. Remove the metal arm from the plastic clip. Slide motor out and disconnect. There is an odd shaped black plastic piece with two T-20 or 25 Torx screws that need to be removed.Remove plastic piece. The Final stage is located behind the metal arm for the a/c door.R emove the floor heater duct for more room. You may or may not feel the need. If you wish pull on the leather extension to the center console outward until you hear a loud plastic cracking. Stop. Take a deep breath and know that you have broken nothing important Remove heater duct careful not to break the blend air door cam (white) and the lever connected to it (black).
You can pull that black lever out if you are patient. Back to the final stage now that you have more room. It is the component with the 5 0r 6 large gauge wires on the connector. Push back the black plastic clamp while pulling/wiggling on the connector.
The final stage should come out, then disconnect the connector. Reinstall all. Make sure the heater duct is installed properly if you removed it.
Sep 08, 2009 | 2001 BMW 325
I need to rewind the spring and starter pull cord. I need to understand how all the parts fit together
I had the same problem. I had to take it apart and rewind it manually. To do this:
Step 1:
There are 4-bolts to remove on the orange plastic section the screw into the motor housing (one of them is hidden inside the orange plastic housing, you'll see an opening for it). There are also 3 screws in the black plastic exhaust housing that screw into the orange plastic housing, find those and remove.
Step 2:
Carefully remove the engine from the plastic housing. I didn't disconnect the throttle cable or the electric wires (points) just kind of worked around them.
Step 3:
The mechanism is kind of crappy. There are two black pieces with a spring in the middle, and a metal disc on the bottom with a ribbon coil on the underside of it. The top plastic piece is what turns the flywheel when you pull the cord. The spring in between connects the two plastic piece. This is probably what popped out. There is a piece sticking up on one end, which inserts into the hole in the top black plastic piece. If you remove the little guardrail things you can probably remove just that piece. KEEP TENSIONS ON THE PULL CORD. Once you remove that top black piece, it should start to recoil.
Step 4:
If it did recoil, put the spring back in the top plastic piece, and then put the plastic/spring combo back into the the bottom plastic piece, there is a little groove for the bottom of the spring to slide into. Then put the little guardrail screws back on. Make sure the big metal wire thing hasn't slipped down into the shaft of the weed whacker. That needs to go back into the motor, as it is what gets spun and in turn spins the strings. As you start to put the motor back in, you may have to pull on the pull cord a few times to get the flywheel and plastic piece to line up. Once you hear the motor start to catch, then you should be able to wiggle it back into place and put back all of the screws. Then give it a shot. If it pulls out again, you may have to drill a new hole into the top black plastic piece for that spring to slide into (this is the crappy design part).
Step 5:
If the pull cord didn't retract, you need to remove the other two pieces (lower black plastic piece and metal disc with ribbon). The metal ribbon has a nub on the outside that hooks onto a plastic piece in the bottom of the orange plastic housing. You'll need to wind it around once or twice to "charge" the ribbon, then wind the string back on the black plastic piece. The black piece should slide into the center of the metal disc and catch the inside of the ribbon. Once you get these two together, again, make sure the metal ribbon piece is wound once past normal and then you have to slide both parts together down into the housing catching the metal ribbon loop over the orange plastic nub. It's tricky, it took me a few tries. Once you get that you can try and test the pull cord, you'll see it pull out and feel it retract due to that metal ribbon. Then go back and do step 4, where you put the upper black plastic piece with spring back into place and replace the little metal guardrails.
This whole thing took a few tries, and the pull cord still gets stuck out. It's a major pain to say the least, but after the 5th time fixing it, you'll be a real pro.
Aug 16, 2009 | Homelite Mighty Lite Lawn Trimmer
Bake element split and oven will not heat.
thats an eazy one by a new element from one off our links at fixya and install it with the power off and no theres no reason why this happened it just wore out God bless,tom
Jan 01, 2009 | GE Spectra JBP78 Electric Kitchen Range
Asko WCAM1812 Front Load Washer / Dryer Logo
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
