Question about Kenmore 72132 / 72134 Gas Kitchen Range
Convert maxitrol regulator#rv47cl natural to propane gas
  • 26 Answers
Some gas ranges cannot be converted. If your model can be converted it normally requires flipping over the regulator diaphragm and also changing orifices for all burners, surface and oven. Most modern new appliances come with the LP orifices located on a card attached to the regulator.
Posted on Nov 20, 2013
  • 10865 Answers
SOURCE: how to convert from natural gas to propane
All stoves in this country come from the factory with orifices designed to use natural gas. To switch over to propane, the orifices have to be changed over. Contact your propane provider and they will obtain the proper orifices for your range. They may even install them for free. good luck.
Posted on Feb 18, 2009
jumptrout51
  • 3361 Answers
SOURCE: Can a kenmore gas stove be converted to propane
Yes.
If you have the owners manual it may tell you the location of the conversion parts that are probably included with the range.
Posted on Mar 12, 2009
  • 138 Answers
SOURCE: how to convert from propain to natural gas
fiddling with gas appliances when you do not know what you are doing is DANGEROUS! do not take chances with your life! are you sure you have the orifices in their correct positions? do you have the "installation instructions" that came with the range? it will have complete instructions on how to convert. give the instructions to a qualified service technician and spend a few bucks to have it done right! please!!
Posted on Aug 16, 2009
  • 464 Answers
SOURCE: i need to change from natural gas to propane serial # NF92903919
some ranges are adjusted on the unit, others you need to go to an appliance parts store and get them to order you a convervsion kit from ng to lp. the model you have given is incomplete i would need the rest to check this further for you. there should be a prefix ahead of the 468130 i.e. 110 - 468130??
Posted on Nov 08, 2009
  • 8404 Answers
SOURCE: HOW TO CONVERT IT TO GAS PROPANE?
Your propane supplier can re-jet your stove to accomodate propane. Give them a call ... they will probably do it for little or no charge.
Posted on Jul 06, 2010
It takes several minutes for the igniter to light the GE cooktop burners.
Mike, do the flames look to be normal size once they do light or are they very small? You may have a bad regulator. The regulator is used to lower the incoming pressure to a safe level to prevent excessive flame size. It sounds as though the regulator is not working properly. However, if the flames are small or uneven levels, check the orifices directly below the caps or on the burner valves for any obstruction such as spillage or cleaner residues. You can replace the regulator with any brand that has a 1/2" in/out pipe thread. Most are available at a large hardware store.
Feb 01, 2016 | GE Cooktops
Can I convert a 450rb from propane to natural gas
The simple answer is yes. However you will need to convert it. Simple process for a gas fitter, they will put a natural gas regulator on and possibly change the jets. Natural gas runs at a higher pressure than Propane. What ever you do, do not run without conversion, it will fail with possible fire or explosion.
Oct 04, 2015 | Kitchen Ranges
How do I know if my Caloric Heritage gas range is propane or natural gas? It is a used stove that was given to us
Stoves are usually sent from the factory set for natural gas. they have to be converted to Propane. If it is set for propane the flame will be very low on natural gas. If set for natural gas on propane the flame will be very large. The orifices for natural gas are much larger than propane orifices. and the regulator is converted acordingly.
Nov 10, 2014 | Kitchen Ranges
How do I convert a natural gas BBQ grill to propane?
You change the nozzle or jet or the complete regulator that regulates the flow of gas. I have seen some company's that will sell you the part or the regulator. You will have to go the the Webber and see if they even offer the part. Or maybe a BBQ dealer who sells and services Webber might do it for you. I know most companies will not sell the part or parts because of the liability. Good luck.
May 21, 2014 | Cook's Essentials Smoothie Maker Work Top...
Can I convert a rinnai rce-229a from propane source to natural gas source
It should be. You should be able to replace the oriface and the regulator. Propane is at a higher pressure than natural gas.
Aug 01, 2012 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Gas stove need to switch to propane
Hotpoint supplies the orifices and instructions with each range for converting. It is just that it is hidden, they attach it to the gas regulator. The regulator is near the bottom back typically. Here is a cut out from your use and care manual.
CONVERTING TO LP GAS (or converting
back to natural gas from LP)
This range leaves the factory set for use with natural
gas. If you want to convert to LP gas, the conversion
must be performed by a qualified LP gas installer.
The conversion instructions and LP orifices can be found
attached to the range next to the pressure regulator.
Keep these instructions and the orifices in case you want
to convert back to natural gas.
May 13, 2010 | Hotpoint RGB745 Gas Kitchen Range
Propane to nat. gas dryer
Good day,
Yes. Two reasons. The orifice that the gas comes out is a different size, and the regulator that determines gas pressure is disabled when using Propane, since propane has the regulator on the tank.
See here.
http://fixitnow.com/wp/2009/03/13/converting-a-gas-dryer-from-natural-gas-to-propane/
If you are not 100% sure what your doing, call a qualified company to perform the conversion. Isn't worth the gamble.
Propane is, unlike natural gas, heavier than air. It can pool in a low spot then ............
Dec 25, 2009 | Whirlpool GGW9200L Gas Dryer
Converting a Propane Thermador 36" range to Natural Gas
I have the same range but need to convert it from natural gas to propane....we should trade...9j antiques
Aug 31, 2009 | Thermador PGR366 Gas Kitchen Range
NAtural gas vs propane
I'll trade my propane regulator for your natural gas hook up.
Mar 27, 2009 | Jenn-Air JLG7130A
Converting stovetop from natural gas to lp
there is a square nut on top of the regulator un screw it and underneath you will find a Cly flip that over should take care of it one side will say ( nat) the other will say( lp) you want lp up
Feb 25, 2008 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Kenmore 72132 / 72134 Gas Kitchen Range Logo
313 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
