Question about Breville Irons
Not heating Lcd flashing
How do I fix iron?
If there is no heat, then the heating element has opened and is in need of repair.
Aug 29, 2015 | Rowenta Advancer High Pressure Steam Iron...
Hi iv got a hinari steam generator iron hin001 that comes on and heats up but no steam comes out when you press the button and theres a standby sign flashes on the display can you help me please
don't spend your money on a calc cartrage it will not get it out of standby.
the controll unit carnt tell if it needs replaceing!
if the standby light is flashing it means it carnt heat the steam tank. if the iron is not heating as well it is a buggerd control pcb!
if you live near Newcastle I could fix it for 20 pounds
Paul@rochy.com
Feb 03, 2011 | Maytag MLI7500A Iron
We do not have operating instructions for this iron...Shortly after setting heat to cotton or linen and iron heats up,,heat screen commences to flash, red light goes out and iron cools as if disconnected...
No,
either the thermostat or a sensor is bad..
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jun 13, 2010 | Rival IR800 / IR810 Iron
My iron lights up. when i set the heat choice the green lights on the right flash and it does not heat up
Generally, the lights on the right flash until the desired temperature is reached. When they stop flashing it means the iron has heated to the temp. that you selected. I'm having trouble with mine now, also, so I can't diagnose.
Apr 28, 2010 | Euro-Pro Shark GI490 Iron
I have a steamglide 2200 iron with water tank, it won't heat up. I have tried with the tank full to max and halfwy but it still won't heat up. There is a green flashing light on the side of the base with a...
sir, this is the rare problem. you need to replace your iron's heating coil. due to this these type of problem arisses.
thanks for contacting fixya
Sep 12, 2009 | Irons
Irons Logo
21 people viewed this question
Top Breville Irons Experts
Tom Chichester
Rani wadia
Rani wadia
Are you a Breville Iron Expert? Answer questions, earn points and help others
