Question about Refrigerators
Faulty Fridge/Freezer sandstrom ssc3st12 fridge freezer. Internal fridge light not working and led display keeps going off and fridge door alarm not working. 12 months old 14 October 2013
  • 2427 Answers
SOURCE: fridge freezing
Your fan in the fridge is proberally going bad,, check your fan
Posted on Jan 09, 2008
hotuna
  • 288 Answers
Low freon charge will cause the compressor to run continuously, as it never reaches the set temperature. This will also cause excessive ice buildup as well. I am assuming this little fridge doesn't have an automatic defrost. If it does look at that next. You didn't say, but does it reach proper temperature? Go to the back where the compressor is. Feel the lines coming out of the compressor. the low pressure, or larger one, it may have insulation around it, should be cold. If you cant tell (sometimes these small compressors they look the same size) its the line leading inside the freezer. Feel about 1 foot away from the compressor, if possible. Next feel the high or small pipe, this one is going to the outside coil. This should be very warm, but not cool and not real hot. This goes for the compressor too. A 134A system sometimes is very hot when low on freon.
SOURCE: WHIRLPOOL AMERICAN SIDE BY SIDE FRIDGE /FREEZER
I had probably the same problem. After a little discussion with the factory they sent a technician as a "Good Will Gesture." The technician told me it was the control board down by the compressor. I overheard a conversation between he and his central repair office that it was a common problem. The factory would not admit it. I have a feeling the electronic control board he replace (which would have cost several hundred bucks) was probably made in China. Now I'm having more problems with my Ohio made Whirlpool side-by-side. The freezer is working fine, the fridge is not very cold. By the way, the internal lights was one of the keys to the problems.
Posted on Jul 10, 2009
projdoc
  • 2237 Answers
SOURCE: Bosch Fridge Freezer (about 12 years old) has
the main board is most likely bad.
Posted on Nov 13, 2009
duane_wong
  • 6826 Answers
SOURCE: My fridge is an E442BRE
If resetting the refrigerator repeatedly is undesireable, then I would see what the alarm is for.
I checked the website for fisher & paykel and they have a nice lineup of refrigerators.
However, when I tried to look up the red and green flashing light problem in their online manuals, it didn't refer to that problem.
I would try to contact the company directly at the following link: to see what could be done
http://www.fisherpaykel.com/customercare/contactus/
Good luck on this repair.
Posted on Nov 06, 2010
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
Fridge light bulb
Not sure how the light socket only has 6V supply? The bulb for this fridge is a pretty standard 15 Watt/230V SES lamp. If you are sure the current lamp is OK I would suggest the door lamp switch has issues. Try pressing and releasing the door switch manually and check that it functions ok without getting stuck or any sluggish movement. This action in itself may fix the problem.
Jan 18, 2014 | Miele KFN8462S Bottom Freezer Refrigerator
I need to repair my GE profile refrigerator
The first thing you need to determine is if the compressor is coming on. If it isn't then the problem is in the lower section, PCB, start relay or capacitor or compressor. If the compressor does come on, then it sounds like your main board is the problem.
Jan 19, 2012 | GE Profile Stainless Bottom-Freezer...
Whirlpool fridge freezer alarm s20D RSB33AG-B
Hi, you have a common problem with your control boards; there is a cheap fix if you can use a soldering iron or you can have your modules repaired.
Let me know
bb
Aug 31, 2009 | Whirlpool Freezers
LG Fridge door constantly beeping when closed
On the display panel press the right key that turns the door alarm on and off
Jul 10, 2009 | LG LFC25760ST 25 Cu. Ft. Panorama French...
Whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted
whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted. the temp display on freezer shows - - flashing
May 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore 5355
There is a fan inside the freezer which circulates cold air through the air diffuser and then through the return duct at the bottom of the fridge. This fan may not be working. You should be able to hear it when you open the freezer door. If you cannot hear the fan going with the door open, keep the door open and press the button that switches the internal light off. The fan should run. If no fan running in freezer test for supply to fan. The fan may be faulty or the thermostat which is in line with the fan could be faulty.
Oct 29, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
87 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
