Question about Refrigerators
Rfg298hdrs/xaa cool select pantry door pops off all the time. I put it back on correctly i feel, but when i pull the drawer out again it pops back off?
HVACRH20
  • 237 Answers
SOURCE: freezer door won't stay shut
Could be the air pressure created from shutting the refer door is popping open the other one. There are are channels between the two so cool air from the freezer gets to the refer compartment. Try this as a test... s l o w l y close the refer door and see if that keeps the other door from popping open. If that works then it's likely an air channel is frozen up somewhere and you may need to turn the unit off for a day or so to let it thaw out. Moisture from leaking door seals, or doors that were left slightly open overnight can be sucked in and freeze up the air channels. I don't know if you are sort of slamming the door shut or not but the doors need to be shut slowly due to how air tight the new refers are.
Posted on Nov 10, 2006
SOURCE: Freezer side door not locking shut
Mine has been doing this for over a month. Then on Friday it started making a clicking sound a CONSTANT clicking sound. I get home from a marriage retreat for families getting ready to be deployed and gee ALL my food in the fridge is BAD!!!!
My model number is ssh25kfrfww Please give yours. Also my door NEVER locked from day one. As my children are older I didnt think it was a big issue till today.
Posted on Apr 14, 2008
  • 531 Answers
SOURCE: Food in Chef's Pantry drawer freezes, even on warmest setting
check the cold control or the door is not closing proper
Posted on Apr 01, 2009
SOURCE: Broken chef pantry drawer peg
Hi -
And I broke off the peg on the right side and have the same question. Any luck/answers?
Posted on Jul 26, 2010
dr appliance
  • 266 Answers
SOURCE: Our Samsung RF265AB (bottom freezer) is leaking
have a water tank or line leak for water dispensor
Posted on Jan 27, 2011
Can't get rf266abpn cool select pantry drawer back in
There may be guide rails on the underside of the shelf above.
Apr 25, 2016 | Refrigerators
Samsung refrigerator rfg297aarf cannot put cool select pantry drawer back?
I don't remember exactly how that one works but try these two options...
1) tip the front of the drawer up more than 45 degrees and connect the rear to the tracks, then lower the front until the drawer catches on the rails - it will push in and slide out correctly.
2) look under the shelf where the drawer attaches, you may have to get down on your knees and really look in. Pull all moving clips that are in the drawer tracks forward (they may have been moved back while cleaning). Then connect the drawer to the slider clips (it should be obvious how they clip in if you have the slider clips).
Hope one of those was right for your unit.
Cheers
Jun 06, 2015 | Samsung Refrigerators
Cool Select Pantry, to relocate per manual instructions, doesn't slide all the way in.
Cool select Pantry
To remove the pantry - Pull the pantry out to full extension. Tilt up the front side of pantry and pull straight out.
To relocate the pantry - Push the rails to the back of the Refrigerator. Place the drawer onto the rails and slide the pantry back until it is in place.
before install they ask to push the rails to the back of the refrigerator
should be no problem
Jul 29, 2014 | Samsung RFG297AARS Bottom Freezer French...
No water when water filter is replaced for RFG298HDRS/XAA
You are not screwing the new filter in right/ it is not seating. I experienced the same problem; you need to "break the seal" on the new filter.
Apr 03, 2014 | Samsung RFG298HDRS 29 cu. ft. French Door...
I cant get the cool select pantry drawer back in
I just had the same problem. The drawer was removed for cleaning and we could not get it back in; it would slide in with about 3 inches not able to go in. Took everything out that we could and still could not get it to go back in all the way. Finally started looking closer at the metal rails and the sides of the drawer and realized there is a tab on each side that needs to be inserted in the the corresponding hole on the metal rail. With the drawer out, pull the rails all the way out; place the side rails of the drawer on the metal side rails and line up the tabs with the holes and insert. Your drawer should now slide in correctly.
Dec 18, 2012 | Samsung RF265AA Bottom Freezer French Door...
RFG298HDRS/XAA error code 33 E FRIG SEEMS TO WORK FINE CONTROL PANEL IS NON RESPONSIVE TO INPUT
E-33 The initial value of HEX is under "14" for 30 seconds while
a weight sensor in operation.
Nov 27, 2012 | Samsung RFG298HDRS 29 cu. ft. French Door...
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
