Question about Food Mixers
How to open bosch hand blender to change the electric cable?
Sunbeam hand blender won't rotate
Your blender probably needs replacement.
Jan 02, 2014 | Food Mixers
I seem to have lost the instruction manual for my mixer. I would like to use the immersion blender, but I can't figure out how to attach it to the mixer body. The shaft on the blender is too short to...
Hi
The blender does not attach to any of the two holes for the whisks.
You need to push back the sliding cover in the center, bottom part between and behind where the whiskers attach. This will uncover a third attachment possibility, where you insert the blender and twist it a quarter turn into place.
Dec 13, 2010 | Braun M880 MultiMix Hand Mixer
Blender attachment does not work
It could be the drive belts. There are three. One for the motor to the belt drive. one from belt drive to bowl mixer spindle. one from belt drive to mixer spindle. mine started to do the same thing. I ordered the belts from Bosch.
Jun 08, 2010 | Bosch 700 Watts MEK7000 Concept Series...
Blade not wrkong
I think they are all the retaining nuts are reverse thread
May 18, 2010 | Robot Coupe MP600 750 Watts Hand Mixer
Noisy, high pitched whirring MUM6622UC/01 Bosch Universal Mixer
My wife's bosch mixer had a similar problem but it was a very loud grating problem. I talked to the bosch dealer in Utah, sorry, I've forgotten which one-- the one that does the repair. This is typically what happens: the seal on the blender wears out, which results in fluids from the blender dripping into the motor, onto the upper motor bearing. So, the upper bearing corrodes and is what is causing the bearing failure and the loud noise (needed hearing protection to operate it). I was lamenting the cost and time it would take to ship the mixer both directions (not actually that much compared to the price of the mixer), and he said he would sell me the bearing and the bottom replacement part of the blender that was leaking. So, I did the repair myself, but it took awhile, and I had to build a puller for the bearing to get it off the shaft, modifying a harbor freight gear puller. But it now is back to new. So, it was a success for me, but i would recommend anyone who isn't very mechanical to just send it off to Utah (again, I forgot the place, I think they talk about the shop in one of the other posts), and you will have a better than new machine.
Nov 08, 2009 | Bosch 700 Watts MUM6622 Universal Series...
Teeth keep stripping on the Bosch blender.
Is there a lubrication issue? Is there a bind or load to the drive after the gears? What has changed since it worked well? P{ancake batter would not be sufficient load to eat gears. Are you changing speeds under load?
Oct 04, 2009 | Bosch Food Mixers
Can't get the drive coupling off my Bosch Universal to replace it
I have had my Bosch Universal Mixer with the Blender and Food Processor Attachments since 2005, and I've loved it since the day I got it... that is, until the blender broke while my son was crushing ice to make slushies...
I figured out the "drive coupler" was stripped and needed replacing, but I couldn't figure out how to take apart the "blade assembly" which includes the "drive coupler" part...
My retailer, Pleasant Hill Grain, sent me the following email:
"I am not aware of any printed instructions for removing the old coupling and
replacing with the new. We recommend holding on to the blades with 1 hand and a
towel and using a needle nose pliers to unscrew the old coupling. You would put
the new coupling on in the same manner.
If these instructions do not work, I would suggest contacting the Service
Dept at Kitchen Resources in Utah. Their phone is 800-692-6724."
I still couldn't figure out how to take apart the blade assembly, so I did end up calling the distributor, Kitchen Resources...
Dave, the tech @ Kitchen Resources, answered my call on the first ring...
Once I explained my problem, he started giving me the same instructions Pleasant Hill Grain gave
me... I explained to him that holding the blades tightly wasn't working for me.
As it turned out, holding the blades did not secure the drive shaft because
the drive shaft was broken off INSIDE the blade assembly - which is why I could
not unscrew the old drive coupling part.
Dave's next question revealed the true issue at hand... my Blender Attachment has the blade assembly made of plastic - they switched to plastic
in 2005 because the metal assembly turned black in dishwashers.
Bosch just recently went back to using metal for this part - apparently the
plastic blade assembly didn't hold up.
Kitchen Resources - the U.S. Bosch Distributor - is sending me a new blade
assembly - no charge, he said it's covered under warranty. Woo Hoo!
Best of all, I hadn't yet purchased the replacement drive coupling part, because
I wanted to know how to go about replacing the part before ordering a new part.
With shipping this part would have been a $50+ repair - you have to love
customer service of that caliber!
[Aside: You really don't need to ever put this part in the dishwasher - wash
the inside with by putting hot water and perhaps a little dish detergent inside
the blender and turning it on - rinse the outside under the sink... no
dishwasher needed! ]
Mar 23, 2009 | Bosch MUM6610 Universal Series Stand Mixer
Bottom Slide Cover (Part 2a in the manual)
See the description for the speed problem and repositioning of the slidere at this link. The slider should snap back in place easily if everything is ok. The slider also operates a switch inside the mixer. This switch is intended to only allow you to run on full power when using the hand blender. You may need to open up the mixer to check this switch is not stuck in the activated position permanently. Otherwise consider the description of the speed problem in the link.
Jun 17, 2007 | Braun M880 MultiMix Hand Mixer
Food Mixers Logo
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
