Plasma TV Anti glare coating worn off
I have a jvc pd-42dv2 plasma tv. Over the last 2-3 years we the anti-glare coating has worn off from improper cleaning. Is it possible to repair this?
  • 3 more comments
  • judejude Dec 05, 2007
    I accidentally rub off the anti glare coat on my JVC lcd TV any advice?
  • lil gallo Dec 17, 2007
    how do i clean the screen without messing up the screen
  • jazzywazzy Jan 01, 2009
    I also have and LCD television, and unknowingly used the wrong cleaners on it and now the screen is foggy. What can I do to fix it?
  • Anonymous Mar 15, 2009
    Ya - someone sprayed windex on our screen,and we haven't been able to fix it sine. Can we put some kind of oil on it or something?
  • Anonymous Mar 31, 2014
    The anti-glare coating on my plasma TV has been damaged by windex. Any way to retreat the glass?
Reflection off of screen
Plasma TV's are known for their glare and reflection issues, you can still fix it by buying a third party anti-glare filter and applying it on your television. For example, "ViewGuard" makes filters that goes up to 65" in size. It is not cheap though, depending on the size of your television.
Of course, the best solution is to adapt your room accordingly. If the glare is caused by the sun light coming from the windows, installing curtains on your windows or moving your television to a better spot is a very effective way to reduce the glare and the reflections on your television.
If the glare is caused by the room's lights, the best solution is to install ceiling spot lights with a dimmer.
Hope that helps!
Mar 19, 2014 | Samsung 51 Class Plasma 1080p 600Hz Smart...
Jvc customer service
can i take the channel locking off my JVC television without the control, if so how?
Jan 10, 2014 | JVC PD-42X795 42 in. Plasma Television
My 2 year old sprayed kitchen cleaner over my plasma screen and it stained is there any thing i could do to restore it back ?
No, the screen or glass front is a part of the the entire display panel which costs as a part more than the set did when new.
The coating on the screen is photo chromic and anti glare in nature much like the coating on expensive camera lens.
I had a used one with similar damage and the only thing short of replacing the panel was we used very fine rubbing compound and carefully removed ALL the coating on the screen.
Picture was brighter but any glare from indirect light showed a loss of brightness.
Either live with it or replace the set. Most sets in the owner manual have warnings about what not to use when cleaning a screen.
May 15, 2012 | Televison & Video
I have the newest version of this plsma TV. It is one month old. I tried to clean some areas of the screen with a micro fiber cloth and a dab of windex in 1 corner of the cloth, not realizing that the...
You have damaged the outer protective screen. Only replacement will fix. Water only on a damp cloth should be used to clean. However, the outer screen can be changed. Since the tv is almost new you will have to contact Samsung at www.samsungparts.com through customer service at 1-800-627-4368 9AM to 8:30PM Eastern time. When changing the outer screen be sure to never touch the inner screen after removal. You have to take the back off the set to get to the screws holding the baziel or "plastic frame" to remove the outer screen. I have never taken a screen off of a set that new so I advise you exercise patience when removing. Have the product code ready for customer service to locate the proper protective screen. And serial number.
Oct 23, 2011 | Samsung PN64D7000 3D Plasma TV
JVC PD35D30 Plasma won't turn on anymore...
Yeah, I was going to suggest power supply issue. Plasmas IMHO, are not worth spending the money to fix. Its the reason why they are so cheap these days in comparison to LCD's. I had a 50" Samsung Plasma that went out on me within 2 years (E Buffer board and XMain problem). Its not about the manufacturer but more about the Plasma technology. Do a few searches about plasma and you will find a lot of problems with these tv's. Id say cut your losses, sell the TV for parts and buy a more reliable technology
Jun 07, 2010 | JVC PD-42WV74 42 in. Plasma EDTV
JVC PD-42DX6BJ plasma 42 inch black horizontal lines over the pic
Here's a link to order the original the JVC upper Y-buffer board and lower Y-buffer board for this model from a major parts distributor if needed:
JVC "PD-42DX6" Replacement Part Upper Y - Buffer Board (LJ41-02760A)
JVC "PD-42DX6" Replacement Part Lower Y - Buffer Board (LJ41-02761A)
Based on the symptoms: It is possible that the Y-buffers are faulty, which may require the replacement of the Y-sus board as well. You may want to get a local technician to diagnose the unit and provide a second opinion.
Apr 01, 2009 | JVC PD-42DX6 42 in. Plasma Television
Techwood 42 plasma
if you still need the fix for this repost i have just repaired mine i had a 1 inch thick line just off centre .this is a easy fix no parts required.
Apr 19, 2008 | JVC PD-42WV74 42 in. Plasma EDTV
Need a display tuner jvc pd-42wv74
guess what? I have the EXACT same tuner that u're looking for... my place was broken into and they TOOK the tv monitor... but left behind the tuner . smart thief. if u're interested in buying this tuner to make ur tv complete again. (its in MINT condition) email me at FAIR1968LANE@aol.com and put in JVC PD 42wv74 plasma tv in subject so i d know who it was. thanks.
Feb 01, 2008 | JVC PD-42WV74 42 in. Plasma EDTV
Televison & Video Logo
3,892 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
