Kyocera km 3035 copier displays error code c 0630
The scanner starts working from the top tray and 8 pages in the whole machine freezes. The only way to stop it is to turn it off. We finally got an error code of C0630.
leroyal
  • 2120 Answers
SOURCE: What is the code for KM-3035 printer's scanner network card?
Print/Scan System (U) 083H9503 Network Print Controller and Network Scanner
Posted on Feb 13, 2009
  • 66 Answers
SOURCE: 0630 Fault code on KM 5035
you have a defective main PCB. you should contact your nearest service agent
Posted on Mar 21, 2009
  • 241 Answers
SOURCE: Unable to copy with my Kyocera KM-1815. Error code is C3200.
Typicaly the scanner optics would need to be cleaned. Or it could be a scan lamp failure. A Kyocera dealer could help you with this.
Posted on Jun 09, 2010
sodeep
  • 3267 Answers
SOURCE: I have a kyocera km 3035 printer and it started printing solid black pages
You may clear the problem by cleaning the primary corona wire inside the drum unit by sliding the blue tab.Make sure you return the blue tab to the Home position.
Posted on Dec 09, 2011
l_j_duplessi
  • 29 Answers
SOURCE: Kyocera KM 3035 copier display panel says:
the switch in the finisher that get press by a pin that is setuated on the leftside of copier need to be adjusted or cleaded or replace use a small skrewdriver to activate the switch if it work you now to adjust it if not open and test it with a tester swicth the machine of remove the disconnect the finnesher from copier fi problem is gone the finnesher is the reson fi not it is the wireing to the engin board or engen board on copier fi problum is at finnesher it and the switch is working on finnesher the chek wireing to FN board if that is fine and the wireing to the copier is fine and the conector between copier and fn is fine it is the FN board
Posted on Aug 07, 2012
KM 5035 0630 FAULT CODE
Fuser failure , enter service and reset fuser error.
Jul 15, 2014 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
Km-3035 (kyocera) send email from scanner key, eveything seems to go fine, but no one gets emails, going into history of sending I find error E022. manual is no good, it give no codes. searched google, no...
The E022 error indicates -
The mail contained an e-mail address that the SMTP server can not find.
Check to make sure that the destination e-mail address was entered correctly.
The link below will take you to the manufactures web page where you can download the Scan System Operation Guide (Function Edition which list the error codes.
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=11796&rid=14242
If you continue to have a problem you can go to www.gfbm.net for more assistance, also they have some Kyocera setup and troubleshooting information.
I hope this is helpful,
Shawn
Feb 24, 2011 | Kyocera Mita KM-3035 All-In-One Laser...
My kyocera km 5035 has an error code of c 2642. Any suggestions?
C2642 is not a listed error code for the KM-5035.
C2600 is deck conveying motor / desk motor problem.
C4200 is a LSU (laser unit) problem.
Jan 27, 2011 | Kyocera Copystar CS-5035 Copier
My Kyocera KM-5035 receive error code 4200 in PC printing and in photocopy
Hello, This error C4200 indicates a problem with the main Laser Scanner Unit. The laser scanner functions to image onto the drum in the copier. It scans at a high rate of spped, the error indicates it is in trouble.
The Laser scanner would need to be changed.
It is also possible the main PCB is failing (remote chance)
Find a Kyocera Repair Facilty.
Dec 10, 2010 | Kyocera Mita KM-3035 All-In-One Laser...
Check the interlock at the front of the internal finisher where the inner tray locks in. sometimes the connection isn't solid and can lead to this exact problem. 906ing the machine won't fix it as there is essentially nothing wrong with the finisher.
Feb 23, 2010 | Kyocera Office Equipment & Supplies
Print out landscape
Make cassette number 1 8 X 11. Load paper portrait in tray 1
Mar 08, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Feb 12, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
SYSTEM ERROR
error 610 machine kyocera km-3035 ????
Nov 05, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
ID Code for KM-3035
i want to change the id code for km 3035 kyocera how to chang
Jul 30, 2007 | Kyocera Mita KM-3035 All-In-One Laser...
69 people viewed this question
k24674
