Question about Kenmore 66222 Microwave Oven
Kenmore dryer how to remove top to install door switch
    Top Expert:
  • Kenmore Master
  • 12,223 Answers
See the video attached. and fix it. God bless you
Posted on Nov 19, 2013
Where is the fuse on kenmore microwave
Is this an over-the-range (OTR) microwave oven or a counter-top model? Assuming it is an OTR model, your can get to the fuse by first unplugging the microwave, then removing 2 to 4 screws over the grille vent. Remove the grille vent. Depending on the model, you either slide it to the left a little bit (1/4 inch) then pull it out, OR tilt out the top of it followed by the bottom. Now you should see 1 screw that hold the top of the control console in place. Remove it, then lift up on the control console to get past the tabs, and tilt out the top. Now, depending on the model, you may see the fuse behind the control console, or if it's not there, then remove the 1 or 2 screws that hold the metal grill vent that's located above the control console. Remove that metal grill, and your should see the fuse behind it. Sometimes that fuse blows for no good reason, other times it blows because you have a shorted high-voltage capacitor, or you may have a sticking "monitor" door switch.
Jun 25, 2014 | Kenmore 63252 Microwave Oven
How do I adjust the door switchs
Remove the grill on top and there will be a screw for the control panel. Once the control panel is tipped down you can see the door switches . Adjustment is a combination of the switch bracket and door hinge adjustment, You should have access to a Rf leak detector to inspect the door anytime the hinges or latches are serviced.
Eric
Jun 02, 2010 | Kenmore 62622 Microwave Oven
Microwave will not start when time is entered and start is pushed
You got it! One of the door switches is not activating. Take a look at the door itself first. There should be two tabs that stick out. These tabs will engage in the holes near the control panel. If the door does not have a broken tab then the problem is behind the control panel on one of the switches. There are 3 switches back there.
Unplug the power cord, it is usually in the cabinet above the microwave oven. Then take the grille off the top, the screws for the grille are on the top of the unit facing down. With the grill off you will see the one screw on top of the control panel, remove that screw and lift up and out on the control panel this will give you access to view the switches and test them with an ohmmeter.
May 02, 2010 | Kenmore 60654 Microwave Oven
Kenmor microwave 62344 runs but does not cook
Check the door safety interlock system. Remove the cover - test the little switches near the door lock.
These switches fail because we all open the oven door while the oven is operating. Thbis causing arcing and failure. When they fail, the oven doesn't know the door is closed and will not turn on the heat.
Need more help with this ...please ask.
Oct 19, 2009 | Kenmore 62342 Microwave Oven
I have a 721.63263300 counter top SS unit
one of the 2 door switches is bad.they can be accessed by removing the control panel.switch is mounted on door latch assly.switch is about $ 10.00 and easy to replace.
Aug 16, 2009 | Kenmore 62622 Microwave Oven
Model 565.66400, still runs when door is opened?
if unit runs with door open then one of the door switch is stuck closed.there are 2 door switches and they could be assesed by removing the control panel.disconnect wires from top and bottom switches and chkf for continuity.they should be normaly open when the door is open and closed when door is closed.one of them will closed even when door is open.replace that bad one.
Aug 11, 2009 | Kenmore Microwave Ovens
I have a Kenmore model #721.89940490 The door handle broke off and need to replace it, I do not see any screws. how do I access the mounting screws.
You will probably need to take the MW down and remove the outer case to access the hinge for the door.
just received a new door assembly for my Kenmore microwave and spent about an hour searching for help with installation to no avail. , but managed to replace it by prying the small pin out with a flat head screwdriver and removing the door. I reused the pin (after straightening it), and it works great.
The door handle is secured with the two screws from inside of the door. In order to access them you have to remove the inner door frame. You can find how to remove it in the video clip from one of our previous posts.
Aug 03, 2009 | Kenmore 62702 Microwave Oven
Remove Kenmore Mod. # 5648598601 from wall.
A lot of those you can replace the bulb without taking it down. There should be screws at the top that lossen up the vent in the front. Remove the vent, might have to open the door and slide it to the left (a little latch) then you should see a filter that just comes out and behind that is the bulb. I would try that before taking it down Forgot to mention that in the other e-mail.
Mar 04, 2009 | Kenmore 80412 Microwave Oven
Microwave won't heat
The two possible causes are a faulty door switch and a bad magnatron. You can pull the top cover off of the unit and check all of the door switches (there are 2-6 of them all on a common rail, me normally closed)). If the door switches all check out, replace the magnatron, diodesmag-glass_10x10.gif, and capacitor
Oct 28, 2008 | Kenmore 62622 Microwave Oven
Kenmore 66222 Microwave Oven Logo
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
